  • andypugh
  • andypugh's Avatar
25 Jan 2026 16:57
Replied by andypugh on topic How to fix "Queue is not empty after probing"
This feels like possibly a race condition, I wonder what happens if the queue-empty check is just disabled?
(ie, I wonder if it indicates a real problem?)
  • andrax
  • andrax's Avatar
25 Jan 2026 16:52
[solved] XHC-WHB04B-06 rotary knob button feed rate not work
I use gmoccapy.
So far, I have found that these two signals control the feed rate:
gmocacapy.spc-feed.value
gmocacapy.spc-speed.value
  • andypugh
  • andypugh's Avatar
  • andypugh
  • andypugh's Avatar
25 Jan 2026 16:48
Replied by andypugh on topic HAL Edits for RS485 / VFD Spindle Control
Category: HAL
If this is your whole HAL file then the problem is that you have connected the HAL "net" to the VFD but not to the motion contoller.
# Connect HAL pins to motion controller
net spindle-vel-cmd-rpm-abs  	hy_vfd.speed-command
net spindle-cw       			hy_vfd.spindle-forward
net spindle-enable        		hy_vfd.spindle-on
net spindle-ccw        			hy_vfd.spindle-reverse
net spindle-at-speed   			hy_vfd.spindle-at-speed
This creates "nets" with names like "spindle" enable but there is nothing at the other "end"
Try:
net spindle-vel-cmd-rpm-abs  	spindle.0.speed-out => hy_vfd.speed-command
net spindle-cw       			spindle.0.forward => hy_vfd.spindle-forward
net spindle-enable        		spindle.0.on => hy_vfd.spindle-on
net spindle-at-speed   			spindle.0.at-speed <= hy_vfd.spindle-at-speed
The => are optional and ignored by the computer.
linuxcnc.org/docs/stable/html/man/man9/m....html#SPINDLE%20PINS
  • JT
  • JT's Avatar
25 Jan 2026 16:37
Replied by JT on topic Reload gcode
Reload gcode
Category: Flex GUI
Sorry, I must have got distracted when changing the variable name and didn't finish changing every occurrence. The bug has been squashed.
JT
  • andypugh
  • andypugh's Avatar
25 Jan 2026 16:36
Replied by andypugh on topic PiBot Pendant
PiBot Pendant
I have sent a query about how it interfaces. If it is USB HID then it will probably work fine with hal_input. Otherwise it might need a specific driver.
  • andrax
  • andrax's Avatar
25 Jan 2026 16:26
motor-0-position error beim Abbremsen aus 4-7,5 m/min
Category: Deutsch
dein Fehler könnte möglicherweise noch eine weitere Ursache haben.
Da dies beim abbremsen und hohen Geschwindigkeiten passiert, kann es sein, dass dein Servotreiber die überschüssige Generatorenergie
vom Servomotor nicht wegbekommt und sich dabei der Zwischenkreis entläd.
Hast du Bremswiederstände installiert?
  • andrax
  • andrax's Avatar
25 Jan 2026 16:09
I have a question about the configuration of the XHC WHB04B-06.
I already asked this question in the German forum but unfortunately did not receive an answer.
First of all, the handwheel works perfectly except for the rotary knob button.
Here I can only set the increments. But I also want to control the feed rates.
I think the settings need to be adjusted here:
# GUI feed rate related signals can be used when program is running moving GUI slider
net pdnt.feed-override.scale whb.halui.feed-override.scale halui.feed-override.scale # needed for both FeedOverride+/- and rotary knob button
net pdnt.max-velocity.value whb.halui.max-velocity.value halui.max-velocity.value # needed for Mpg mode : button feed position% * max-velocity = Mpg feedrate
# take feed override min/max values from/to the GUI
net pdnt.feed-override.value halui.feed-override.value whb.halui.feed-override.value # GUI feed rate related signals
net pdnt.feed-override.increase whb.halui.feed-override.increase halui.feed-override.increase
net pdnt.feed-override.decrease whb.halui.feed-override.decrease halui.feed-override.decrease
I just don't know which ones?
  • MaHa
  • MaHa
25 Jan 2026 16:03
Reload gcode was created by MaHa
Reload gcode
Category: Flex GUI
After a break, when running my machine, i can load a gcode file. But trying reload or edit crashes with following error:
  File "/usr/lib/python3/dist-packages/libflexgui/actions.py", line 147, in action_reload
    if gcode_file:
NameError: name 'gcode_file' is not defined. Did you mean: 'nc_code_file'?
/usr/bin/linuxcnc: Zeile 977: 11062 Abgebrochen             $EMCDISPLAY -ini "$INIFILE" $EMCDISPLAYARGS $EXTRA_ARGS
  • andrax
  • andrax's Avatar
25 Jan 2026 15:47
Replied by andrax on topic StepperOnline A6 Servo
Category: EtherCAT
Hi, I have now made some changes and am not experiencing any more problems for the time being.
1. I had Ethercat running on two network cards.
I have now combined them into one card and made sure that it has an Intel chip.
2. I have made the following changes in ethercat.xml:
appTimePeriod="1000000" >>> appTimePeriod="2000000"
sync0Shift=“25000” >>> sync0Shift="50000"
Since then, the errors have disappeared and the servos are ready immediately.
3. I have attached ferrite cores to the Ethercat cables.
The ferrite cores for the servos have been ordered.
  • timo
  • timo
25 Jan 2026 14:57 - 25 Jan 2026 15:19
Replied by timo on topic Best controll board for LinuxCNC
As I understood open loop drivers and motors are existing and are kept in the system. (for the time beeing) :-)
It is probably difficult to answer the question. What makes a controller better (best)?
  • cheap? (two parallel ports (PCIe cards) in old office PC)
  • least amount of re-wiring? (existing parallel port machine?)
  • cheaper? (but not a bit of documentation) ( FPGA cards of unknown origin)
  • Is wasted time cheaper than money spent?
  • easy to set up? ( pnc config)
  • upgradable? (linear scales, tool changer, rigid tapping, closed loop positioning, linear motors)
    I used an old parallel port machine, changing form mach3 to LinuxCNC was 90% figuring the "charge pump" out (no re-wiring, all in software), then the computer quit service and the replacement had no parallel port. (a 10$ PCIe card fixed that).
    Having problems to get an encoder running a Mesa card (6i25 with daughter card) went into the machine. (solving the spindle encoder issue)   (it still is a Frankenstein mixed Mesa and Parallel port).
    Greetings Timo
    p.s. the UC300ETH is that working with linuxcnc? Some older threads stated it does not work.
    forum.linuxcnc.org/27-driver-boards/2982...moothstepper-to-mesa
  • 2tinker
  • 2tinker
25 Jan 2026 13:57 - 25 Jan 2026 14:00
Replied by 2tinker on topic How do I lubricate correctly?
Category: Milling Machines
Does anyone have experience with this grease gun?
www.sorotec.de/shop/Professionnal-Grease...set-120ccm-6796.html
At €100, it's not realy cheap!
  • freemoore
  • freemoore
25 Jan 2026 12:16
7i80HD+7i48+7i42TA+7i84 Mesa firmware request (morbidelli author 503 retrofit)
Category: Driver Boards
Thanks. Now waiting on delivery of a 7i52 to test those serial ports, no luck via 7i42ta.
However, I've had trouble from the start with the 7i48 card - the 7i80HD-16 wouldn't read its encoders at all, and the 7i80HD-25 had some trouble, using encoder.00 to .03.
Last night we tried using the 7i48's encoder.04 channel with one axis at a time, and found that all 3 worked perfectly. Then we tried adding all 3 axes, at which point no aspect of the 7i48 works at all: the +15V, -15V and 3.3V lights come on, but there is no +/-10V from any AOUT port, and no encoders are read through any channel.
If a cascading fault is possible (caused perhaps by the one attempt with a 24v encoder) then I seem to have bricked my board, though I don't know if that's consistent with channel .04 having worked perfectly for half an hour of testing last night.
Please would you remake the above firmware for the 7i80HD-16? I would like to try to rule out the fpga board as the thing that's broken here, before we order another 7i48. I'd note that the reason I tried the 24v encoder was that the 7i48 wasn't reading encoder info at all to start with, though when I switched to the HD-25 it appeared to partially work, making me thing that the HD-16 firmware may have had an error.
If you have any other suggestions I'd be grateful to hear them.
  • Aciera
  • Aciera's Avatar
25 Jan 2026 11:29 - 25 Jan 2026 11:35
Replied by Aciera on topic LinuxCNC S-Curve Accelerations
To come back to your original question, if I were to look at the gcode running on those machines, would I see more code running in G61or G64 mode?
Generally, how important is constant velocity along the toolpath for your applications?
  • Becksvill
  • Becksvill
25 Jan 2026 10:32
Replied by Becksvill on topic LinuxCNC S-Curve Accelerations
Agreed it's outside the scope of the OP
Just once again thanks for everything.
I'll go back to watching and hoping you guys get this running nicely
Cheers andrew
Displaying 3631 - 3645 out of 17144 results.
Time to create page: 0.217 seconds
