  • whj5
  • whj5
17 Mar 2026 02:56
Replied by whj5 on topic Ethercat auto configurator.
Category: EtherCAT
It shows a 404 error on Codeberg, and the videos on YouTube won't open at all.
  • georgio
  • georgio
17 Mar 2026 02:19
Installing Linuxcnc on new pc Using Debian 12.13 and Linuxcnc 2.9.8 mesa 7i76eu
Category: Installing LinuxCNC
Promise!!! I am hoping that moment is coming soon like any minute I got up to line 197 hal c by commenting out and now I have the stepgen parts. It is amazing that i can have joints 1 and 3 work and o and 2 not work for stepgens. I have checked ini and trivkins and joints all line up correctly shows xyyz and 4 joints but only 2 work with the exact same text in each section???? I will take Rod's suggestions and see if i can get further ahead. One good constilation is I am learning lots all I have to do it put it together before I have a brain anyerism -LOL
Thanks again
  • georgio
  • georgio
17 Mar 2026 02:12
thanks Rodw,
I will try that I have been doing similar things in terminal and when get so bogged down I just comment them out and move on and will come back to them later.
I appreciate your help,
Thanks again,George
  • currinh
  • currinh's Avatar
17 Mar 2026 01:14
Replied by currinh on topic Trouble with XFCE (trixie) timed logouts
I think that behaviour was when I had the auto login set up. On power up the computer logged me in without entering user/pw. When it auto logged me out it did come back with a user/pw screen. But I think that timed out and the auto login kicked in.
I am sure, under the configuration changes I made above, that I left the computer logged in with linuxcnc running. When I checked on it later it was running the XFCE desktop but had closed linuxcnc. I'm fairly sure it did a logout/auto login which closed linuxcnc.
I'm also sure running 2.9.8 it logging me out after a set time, between 30-60 minutes. Without auto login it waits with a user/pw screen.
Beyond my comprehension. If you find any insight please let me know. But for now I have 2.9.4 up and running.
Thank you. Hugh
  • rodw
  • rodw's Avatar
17 Mar 2026 00:18
The way to push ahead is to note the error and comment out the line causing it with a #
Then when it opens, open halshow (eg. axis menu: show hal configuration)
Then review the pins. You might just have a minor typo. then edit the commented out line to use the correct pin name
  • rodw
  • rodw's Avatar
17 Mar 2026 00:11
Replied by rodw on topic Trouble with XFCE (trixie) timed logouts
Sorry that did not work for you. Seems odd that settings would force a logout/login. we have not experienced that behaviour
Please note if you log out, its expected you will have to log in again.
  • mmmboost
  • mmmboost
16 Mar 2026 23:44
Replied by mmmboost on topic Mesa 7i96S MPG encoder on P1
Category: Driver Boards
Hello PCW,
I hope to get some help from you again.
I tried to make a custom bit file consisting of these two files 7i96s_2pwmd and 7i96sd_mpgp1. 7i96s2pwmd for pwmgen (Stepgen 4-) and 7i96sd_mpgp1 for mpg on P1.
I used the enfinity software, but it doesn't work because of a version conflict.
Do you know which efinty version works with the 7i96s firmware from the homepage ? Thanks a lot
Did you ever get this working? From the description, this sounds like the firmware I need.  Would you mind posting the bin file?
  • Lcvette
  • Lcvette's Avatar
16 Mar 2026 23:09
Replied by Lcvette on topic Probe Basic Errors after successfully probing
Category: QtPyVCP
i just tried to replicate your warning, but i was able t stop and make adjustments and report without running into any of those error pop up. those are actually linuxcnc statement stating that your entered parameters would cause an over travel event, are you certain the parameters you entered would be tool paths within the constrained machine motion envelope?
16 Mar 2026 22:59
LOL, i feel sorry for the keyboard! :)
It is hard for now, but after a while everything starts to fall in place and make sense.
Changing one single thing at a time and testing is much more productive and easy to roll back in case of failure.
  • kello711
  • kello711's Avatar
16 Mar 2026 22:53
Replied by kello711 on topic Probe Basic Errors after successfully probing
Category: QtPyVCP
what is your machine setup like regarding tool offsets?
My machine overall is a router style setup with a 30 in x 30 in work area. My spoil board is ~24 in x24 in. The spoil board corner is not at (0,0), well inside the machine soft limits. My tool table only has Z offset and Diameter. After probing the corner of the spoil board, the G54 offsets were: X=5.0161, Y=1.1693, and Z=-7.4953. Z probe Z offset is 2.3607 and cutting tool Z offset was 1.8513.
T1   P1   D+0.125000 Z+3.566440 ; 1/8 end mill Sample Tool
T2   P2   D+0.062500 Z+0.100000 ; 1/16 end mill Sample Tool
T3   P3   D+0.201000 Z+1.273000 ; #7 tap drill Sample Tool
T4   P0   D+0.236200 Z+3.688692 ; 6mm DLC End MILL (DSA1F-D6.0-L22)
T5   P0   D+0.196900 ; 5mm DriLL
T6   P0   D+0.255900 ; 6.5mm dRILL
T10  P0   Z+3.791137 ; 6MM COUNTER BORE
T11  P0   D+0.984000 Z+2.056925 ; BAP - EAP300r (C12-25-80-3T)
T99  P99  D+0.078500 Z+2.285087 ; 3d Probe
T100 P0   ; SPINDLE NOSE
16 Mar 2026 22:41
An all-in-one control panel based on Raspberry Pi and 15.6" touchscreen
Category: Show Your Stuff
Very nice, thank you, and also thank you for sharing the files on GitHub.
16 Mar 2026 22:37
Replied by tommylight on topic Pathpilot Spindle speed control for a lathe
Category: PathPilot
Moved to "pathpilot" section.
  • PCW
  • PCW's Avatar
16 Mar 2026 22:23
Axis position shift during helical boring - Fusion 360 Personal + Mesa 7i96s + C
5. NOT step timing: Tested DIRSETUP/DIRHOLD at 2000, 5000, and 10000ns. 5000 was slightly better but didn't solve it.
If changing the step timing changes anything that suggests that something is marginal
electrically or timing wise
Have you tried doubling the step time?
Are the drives step/dir connections single ended or differential?  (single ended is suggested for opto-coupled inputs)
Does the DRO show the error? if not it's most likely not the Trajectory Planner
  • grandixximo
  • grandixximo's Avatar
16 Mar 2026 22:10
Replied by grandixximo on topic LinuxCNC S-Curve Accelerations
There already is some basic merging, I'm sure it can be improved upon
  • belovictor
  • belovictor
16 Mar 2026 22:07
Just wanted to share the control panel I've built for my VM32 CNC conversion project. The aim was to get away from a typical PC+Monitor setup and build an all-in-one control panel for LinuxCNC which can be mounted on the mill cabinet and control the mechanics through MESA board. I published the resulting models for this build in a Github repo:  github.com/belovictor/linuxcnc-control-panel
You can also find the panel build video on my YouTube:
Best regards,
Victor Belov
Displaying 736 - 750 out of 17460 results.
Time to create page: 1.729 seconds
