  • DerKlotz
  • DerKlotz
31 Oct 2025 12:10
Joint 2 on limit switch error -> Z Axis was created by DerKlotz
Category: Basic Configuration
i get the "Joint 2 on limit switch error". I have a Mesa 7i76e and you can find my configuration for Joint 2 attached.
I tried several things but still with no success.
Please help
  • Hakan
  • Hakan
31 Oct 2025 11:06
Stepper online A6 Servo motor as Spindle motor
Sounds good. Let's hope it keeps that way.
I ran the RPi4 for some time and it was ok, so the Rpi5 should be ok too?
Latency isn't so much of an issue now with the "-" sign.
That "should" keep it on track (sync).
You can check if it isn't doing so great with the value of the pin lcec.0.pll-reset-count
If that is way above 1 there may be a problem.
First thing to do then is to increase lcec.0.pll-step to 10000 which is max, or something in between say 5000,
setp lcec.0.pll-step 10000
If pll-reset-count then keeps increasing you need to work on the latency.
The main reason I switched to Intel-based is that the gui became more and more
sophisticated and needed more and more processing power to function smoothly.
I am hesitant to recommend a setup, there are many that works fine.
For ethercat I would definitely look for an Intel network adapter,
the rest is more form factor, power draw, cpu performance.
I have had good luck with the N100/N150 mini pcs. Intel network adapter though.
  • Will_cnc
  • Will_cnc
31 Oct 2025 10:05
Replied by Will_cnc on topic Stepper online A6 Servo motor as Spindle motor
Having tested the machine this morning , the Juddering on the servo drives appears too of stopped for the time being?
Could it be due to the pi not being powerful enough and having bad latency? Yesterday I had a few windows open running whilst running linux .
If this is the issue is it worth upgrading from the pi5 to something with more powerful ? .
Any suggestions on reasonable priced upgrade options
  • Hakan
  • Hakan
31 Oct 2025 09:19
Looks fine so far.
Can you start linuxcnc to see if any useful message comes out to explain jerkiness.
You can also try to temporarily remove/comment out the dcconf line for the spindle driver only in the ethercat.conf.
  • Will_cnc
  • Will_cnc
31 Oct 2025 09:14
here is the result of running sudo dmesg
[ 4.057274] Bluetooth: HCI UART protocol Broadcom registered
[ 4.083683] brcmfmac: F1 signature read @0x18000000=0x15264345
[ 4.087327] brcmfmac: brcmf_fw_alloc_request: using brcm/brcmfmac43455-sdio for chip BCM4345/6
[ 4.087734] usbcore: registered new interface driver brcmfmac
[ 4.291603] brcmfmac: brcmf_c_process_txcap_blob: no txcap_blob available (err=-2)
[ 4.291861] brcmfmac: brcmf_c_preinit_dcmds: Firmware: BCM4345/6 wl0: Apr 15 2021 03:03:20 version 7.45.234 (4ca95bb CY) FWID 01-996384e2
[ 4.393502] Bluetooth: hci0: BCM: chip id 107
[ 4.393719] Bluetooth: hci0: BCM: features 0x2f
[ 4.394870] Bluetooth: hci0: BCM4345C0
[ 4.394873] Bluetooth: hci0: BCM4345C0 (003.001.025) build 0000
[ 4.426812] Bluetooth: hci0: BCM4345C0 'brcm/BCM4345C0.hcd' Patch
[ 4.462459] macb 1f00100000.ethernet eth0: PHY [1f00100000.ethernet-ffffffff:01] driver [Broadcom BCM54213PE] (irq=POLL)
[ 4.462471] macb 1f00100000.ethernet eth0: configuring for phy/rgmii-id link mode
[ 4.469213] pps pps0: new PPS source ptp0
[ 4.469263] macb 1f00100000.ethernet: gem-ptp-timer ptp clock registered.
[ 4.470153] warning: `iwconfig' uses wireless extensions which will stop working for Wi-Fi 7 hardware; use nl80211
[ 4.470300] ec_master: loading out-of-tree module taints kernel.
[ 4.470306] ec_master: module verification failed: signature and/or required key missing - tainting kernel
[ 4.475936] EtherCAT: Master driver 1.6.8 1.6.8.g2543cc5-1+27.1
[ 4.476617] EtherCAT: 1 master waiting for devices.
[ 4.490862] zram: Added device: zram0
[ 4.628070] ec_generic: EtherCAT master generic Ethernet device module 1.6.8 1.6.8.g2543cc5-1+27.1
[ 4.628086] EtherCAT: Accepting 2C:CF:67:24:E6:CD as main device for master 0.
[ 4.628096] ec_generic: Binding socket to interface 2 (eth0).
[ 4.645137] EtherCAT 0: Starting EtherCAT-IDLE thread.
[ 4.747291] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
[ 4.747296] Bluetooth: BNEP filters: protocol multicast
[ 4.747300] Bluetooth: BNEP socket layer initialized
[ 4.752789] brcmfmac: brcmf_cfg80211_set_power_mgmt: power save enabled
[ 5.129671] Bluetooth: hci0: BCM: features 0x2f
[ 5.131033] Bluetooth: hci0: BCM43455 37.4MHz Raspberry Pi 3+
[ 5.131037] Bluetooth: hci0: BCM4345C0 (003.001.025) build 0342
[ 5.131328] Bluetooth: hci0: BCM: Using default device address (43:45:c0:00:1f:ac)
[ 5.150144] Bluetooth: MGMT ver 1.23
[ 5.155700] NET: Registered PF_ALG protocol family
[ 6.530993] macb 1f00100000.ethernet eth0: Link is Up - 100Mbps/Full - flow control off
[ 6.537016] EtherCAT 0: Link state of ecm0 changed to UP.
[ 6.545022] EtherCAT 0: 4 slave(s) responding on main device. Re-scanning on next possibility.
[ 6.545024] EtherCAT 0: Slave states on main device: PREOP.
[ 6.545025] EtherCAT 0: Re-scanning now.
[ 6.545194] EtherCAT 0: Scanning bus.
[ 7.356283] EtherCAT 0: Bus scanning completed in 808 ms.
[ 7.356289] EtherCAT 0: Using slave 0 as DC reference clock.
  • hanz24
  • hanz24
31 Oct 2025 08:12
Long initialization of Ethercat on servo drive SV660N
Category: EtherCAT
The problem is eoe from my driver. It's solved with onceloved's help with change some byte in the sii file and write it to the driver. Thanks for all who helped so far.
  • mariusl
  • mariusl's Avatar
31 Oct 2025 05:55
Replied by mariusl on topic USB activity causes network error
Category: Plasmac
Also what USB dongle?
I have a rtl8192cu based USB WIFI dongle on this test machine
and it seem to have no effect on latency when plugged/unplugged
Have you done the usual optimizations?
DKMS driver for RealTek Ethernet chips
Turn off IRQ coalescing on Intel Ethernet chips
in grub file isolcpus = last processor
pin Ethernet IRQ to last processor
 It means that the network message could not be compete in one cycle.
Actually it's worse than that, with default settings, it means 5 read requests in a row timed out
so usually means multi-ms latency...
I use the TP=Link TL-WN823N WiFi dongle.
The Ethernet chip is Intel on the PC.
I have not turned of IRQ coalescing (don't know how)
I did isolcpus but I am not sure that I did it correctly. It has 4 processors.
Pin Ethernet IRQ to last processor - I have not heard about that so no I have not done that either.
Seem like I have a lot of things that could contribute to the problem
I did do latency tests on the PC's and they all seemed to perform very well with no noticable peaks at all
  • mariusl
  • mariusl's Avatar
31 Oct 2025 05:45
Category: Plasmac
Tommy I usually make use of nmtui or the network manager
  • Hakan
  • Hakan
31 Oct 2025 05:37
Here it looks fine. Saw it in the first ethercat-conf.xml you attached.
There is no reason the PV mode should cause problems with other drives.
Check the output of "sudo dmesg" the last say 20 lines are of interest.
  • little_sparky
  • little_sparky
31 Oct 2025 03:59 - 06 Nov 2025 00:52
Replied by little_sparky on topic Rods "Spaceship" Scratch built Plasma Cutter build
Category: Show Your Stuff
EDIT: SOLD!
_____________________________________
hey all, sorry to bring up an old thread, but I thought I might be able to offer something to help someone out there complete their own plasma build.
I bought this Everlast 50s plasma off Rod some time ago to start my build at a time where I couldn't afford a Hypertherm. The plasma and all of Rod's information from this thread and others of his on the WWW allowed me to build my own CNC plasma on a budget with absolutely no prior experience in electronics. The CNC rapidly allowed me to upgrade to a bigger Hypertherm machine so now I would like to offer somebody else the opportunity to buy the same Everlast 50s for their own build.
A 45A Hypertherm is around $4,150 and a Unimig is around $1,549, so I think $750 plus shipping is a fair price considering it will come with a machine torch and consumables. I am located in Melbourne if pickup is preferred.
See link below for more details on the unit. PowerPlasma 50S.pdf
31 Oct 2025 01:58
Replied by tommylight on topic ARE YOU KIDDING ME YOUTUBE !!!
[ All internet traffuck appears to come from the same place because of how they appear to have the servers/vpn/whatever set up and YouTube then requires a sign in to view it.
Router, yes, that can also do that if the NAT (Network address translation) is ON, so all the PC's inside the network look as the same and only PC to the internet. Consequently the PC that youtube see's has a lot of users with different user names, hence the need for login to discern between users (and the ability to push tailored adds).
Thank you for reminding me, i forgot about that.
  • snowgoer540
  • snowgoer540's Avatar
31 Oct 2025 01:43
Replied by snowgoer540 on topic ARE YOU KIDDING ME YOUTUBE !!!
and that could mean that the internet at work triggers something on YouTube that makes it
think that my computers at work are  bots of some kind. (strange that it didn't yesterday)
FWIW this is how it is at my place of employment. All internet traffuck appears to come from the same place because of how they appear to have the servers/vpn/whatever set up and YouTube then requires a sign in to view it. Probably more specifically it’s likely because many of my coworkers appear to use YouTube to play music all day long. But to your point some days it will let me watch whatever I clicked on and some days it requires a sign in.
Some days I have to verify I’m not a bot just to do a simple google search.
  • unknown
  • unknown
31 Oct 2025 00:49
Replied by unknown on topic ARE YOU KIDDING ME YOUTUBE !!!
No difference between the two here. Chasing "Net Zero" is pushing up prices everywhere, killing industries, especially anything to do with getting metals from ores. I'm almost starting the to those in charge don't actually want the population to build anything, except for housing that will built by imported Indians trained to be builders.......yeah that'll work. Yes they are targeting Indians nationals for this.
Short of houses, lets bring in more people to build houses...that will need more houses, bring some more people to bring in more houses....that will need more houses...rinse & repeat.
  • unknown
  • unknown
31 Oct 2025 00:42
Replied by unknown on topic Which LinuxCNC HW for 2026+?
Those figures look pretty good, where did you get your kernel from or did you build it yourself.
  • AkkiSan
  • AkkiSan
31 Oct 2025 00:35
Replied by AkkiSan on topic Which LinuxCNC HW for 2026+?
Thank you very much for your suggestions.
Seems like there is indeed a lot of fine tuning or trial and error necessary.
Even with limits set to 99999, this happens; and on one system, I also got the probe error, although my „probe flipflop“ was held in reset.
So far, my first working setup >2.8.4 is the RPi/7c81 combo,
but with that working, I hope to find some time to learn more about your proposals for the Ethernet solution.
Thx,
AS
Displaying 7876 - 7890 out of 16732 results.
Time to create page: 1.311 seconds
