  • Hakan
  • Hakan
25 Oct 2025 16:35
Stepper online A6 Servo motor as Spindle motor
What have you tried? Which Leadshine drive model?
I am going to propose to use PV mode. It is similar to a vfd.
You just give a speed and the driver ramps up and down as needed.
I have not tried it myself, and I don't have a driver to try it so it is up to you.
I foresee that the cia402 component needs modification, it only handles csp and csv.
  • melayate
  • melayate
25 Oct 2025 16:30
Mesa7i96s and Postep60-250? was created by melayate
I just migrated from Mach4 and Pokeys57cnc, and was hoping to keep Postep60-256 drives in my new setup. I wired postep drive to Mesa 7i96s as follows: Postep pins 1/2/3/5, 2 to TB1 pin1 (GND) / 3 to TB1 pin5 (DIR+) / 5 to TB1 pin3 (STEP+) and 1(enable) to TB3 pin13 (OUT-).
I have been at it for about a week now, I can’t figure out what I am doing wrong. Using Pncconf wizard, the home/limit/ estop are working but the drives are not getting enabled and the stepper motors are not getting any pulse.
any help would be greatly appreciated, thank you in advance!
ps! I am very new to Linuxcnc, migrating from Mach for almost 2 decades.
  • Cooped-Up
  • Cooped-Up
25 Oct 2025 16:30
Replied by Cooped-Up on topic Maho MH800e Retrofit Project
Category: Milling Machines
Well I had that set to 0 so I figured it would stay at 0 but perhaps I should make it set to be further in the other direction
  • MaHa
  • MaHa
25 Oct 2025 16:05
linuxcnc.command().mdi() vs .program_open()
I log data the following way, LOGAPPEND extends the file, while LOGOPEN overwrites with new content
(LOGOPEN,/home/user/NcFiles/LOGs/probepoints.ngc)
(LOG,#<X_OFFS_K>    #<Y_OFFS_K>    #<ANG>    #<OFFS_P>)
(LOG,#1    #2    #3    #4)
(LOGCLOSE)
  • abs32
  • abs32
25 Oct 2025 15:58 - 25 Oct 2025 16:00
  • meister
  • meister
25 Oct 2025 15:37
Replied by meister on topic Tipps für aktuelle LinuxCNC Hardware gesucht
Category: Deutsch
backlash should be seen an all part,
first i would try to repeat it with very slow feed rates
  • DerKlotz
  • DerKlotz
25 Oct 2025 15:08 - 30 Oct 2025 13:22
Replied by DerKlotz on topic XHC-WHB04B-4 error during compile
Just noticed that the handwheel is (probably) already available in the newest linuxcnc. I tried it via a 5 year old YT Video. It is probably much more easy for the basic functions.
I try to do it now...
  • scsmith1451
  • scsmith1451's Avatar
25 Oct 2025 15:08
Replied by scsmith1451 on topic linuxcnc.command().mdi() vs .program_open()
You folks have been awesome helping a retired guy get into LinuxCNC. Thank you for your patience as I get my machine working properly.
One lase issue.
The .ngc probe code is working flawlessly, however, the (probeopen filename.txt) is not opening a file and therefore not capturing the measurements. what might be the problem and how do I resolve it?
Kind regards
25 Oct 2025 14:39
Replied by tommylight on topic Tipps für aktuelle LinuxCNC Hardware gesucht
Category: Deutsch
Seems like backlash, lots of it, not lost steps.
  • juergen-home
  • juergen-home
25 Oct 2025 13:57 - 25 Oct 2025 14:11
Replied by juergen-home on topic Additional hardware-button for coolant
Category: Gmoccapy
Slightly changed from my  gamepad pendant forum.linuxcnc.org/47-hal-examples/57498...tion-selector-switch
Maybe this works.
# Activate coolant / mist
# A single joypad button will start and stop the coolant.
# coolant on-off with toggle2nist
loadrt toggle names=tog_0   # Load N components for logical NOT operations
addf tog_0 servo-thread
loadrt toggle2nist names=tog2nist_0   # Load N components for logical NOT operations
addf tog2nist_0 servo-thread
# this toggle in front of toggle2nist is needed for regular toggle2nist.comp in 2.9.6
net net-joy-coolant-toggle tog_0.in  <= input.0.btn-base3 # here is the button
net net-button-start tog2nist_0.in <= tog_0.out
net net-coolant.is-on tog2nist_0.is-on <= halui.coolant.is-on
net net-coolant-off tog2nist_0.off => halui.coolant.off
net net-coolant-on tog2nist_0.on => halui.coolant.on
  • heaven
  • heaven
25 Oct 2025 13:43
Mesa smart serial or PktUART or serial over RS232 or udp for robot joints
As I know, you can use a smart serial UART to read the Yaskawa ABS encoder, but you need to make a custom component to handle it, including 2 elements: a UART channel and an increment encoder channel.
1st: read the ABS encoder at the initial state
2nd: set the abs position by summing up the abs and increment
  • abs32
  • abs32
25 Oct 2025 13:21 - 25 Oct 2025 18:26
how to get rid of the probed dumping non-probe mode error?
Colleagues, there is Probe. And there is a constantly appearing error
probe tripped during non-probe mode
To combat this error, I specified the following in the configuration file -
loadrt select8 count=1
addf select8.0 servo-thread
net probe-in select8.0.enable
net motion-mode motion.motion-type select8.0.sel
net probesel select8.0.out5 motion.probe-input
The error frequency is immediately sync. However, with such a conciguration, the g38.4 and g38.5 command does not work
When you enter (midi mode) the g38.5 command (options), nothing happens. And when you enter the g48.4 command (parameters), nothing happens either, but an error message appears - probe is already clear when starting g38.4 or g38.5 move, while in fact the sensor is in the "contact is" state and this is visible with the eyes - contact with the body is and the contact LED is lit.
This error disappears and the g38.4 + g38.5 commands are executed normally if "those" entries in the configuration file are deleted.
The question is: how to get rid of the probed dumping non-probe mode error?
  • Hakan
  • Hakan
25 Oct 2025 12:53
Help with Delta E3 Ethercat drives - hal and ethercat-conf.xml
Category: EtherCAT
I guess you should use Probe Basic or QtDragon or some other cute hmi.
Now the ethercat part is sorted, just normal linuxcnc config left.
  • Gartenzwerg
  • Gartenzwerg
25 Oct 2025 12:50
Replied by Gartenzwerg on topic Tipps für aktuelle LinuxCNC Hardware gesucht
Category: Deutsch
Also da hats was, ich verliere anscheinend Schritte auf Y
Wo kann ich da ansetzen?
Displaying 8116 - 8130 out of 16961 results.
Time to create page: 0.560 seconds
