  • Cooped-Up
  • Cooped-Up
05 Oct 2025 20:41
5i25t firmware screwup was created by Cooped-Up
Category: Driver Boards
Awhile ago I had been trying to set up my mesa electronics for a conversion I would like to do. I needed to flash the proper firmware for a 7i77 and a 7i74d and I found the firmware and flashed it. But then it was no longer recognized by the readhmid command or the computer. I have done the fallback jumper thing and am able to flash the firmware and do the reload command and I see it has changed the pins but then when I power cycle and move the jumper it is not recognized again on boot up. What am I doing wrong?
  • bentiggin
  • bentiggin
05 Oct 2025 20:41
Replied by bentiggin on topic Hypertherm hsd130 interface
Category: Plasma & Laser
I believe the high frequency parts are on the other side of the wall to the left. Pic attached of what i think is the high frequency parts.
The torch- and work+ have been identified so that shouldn't be a problem.
  • MatthiasCNC
  • MatthiasCNC
05 Oct 2025 19:19
Replied by MatthiasCNC on topic CiA 402 in 1.15.0
CiA 402 in 1.15.0
Category: EtherCAT
 When I remove that, the following error occurs.
File Name: linuxcnc.txt
File Size:6 KB
File Name: sudodmesg.txt
File Size:57 KB
If I understand correctly, he has a problem with 6040, which would be the control word.
Unfortunately, I don't understand what the problem is with it. It is present in both files.
  • Aciera
  • Aciera's Avatar
05 Oct 2025 19:01
toggle2nist hangs when pressing an other button at the same time
Category: HAL
To toggle program run/stop you would need to use :
loadrt toggle2nist names=tog2nist0
addf tog2nist0 servo-thread
net net-mist.is-on tog2nist0.is-on <= halui.program.is-running
net net-mist-off tog2nist0.off  => halui.program.stop
net net-mist-on tog2nist0.on  => halui.program.run
05 Oct 2025 18:30 - 05 Oct 2025 18:32
Replied by tommylight on topic Retrofitting HURCO BMC30
Category: Milling Machines
forum.linuxcnc.org/30-cnc-machines/33529...20p-retrofit?start=0
There should be some configs attached there for BMC20, might help you get an idea but i do not think neither use Carousel component.
Edit,
this one uses gray code for 8 tools i think, was way to long ago.
forum.linuxcnc.org/30-cnc-machines/31792...-sbz-130-01-retrofit
  • Aciera
  • Aciera's Avatar
05 Oct 2025 18:13 - 05 Oct 2025 18:50
Category: HAL
The problem is that stopping a program will also switch off coolants (mist and flood). This is inbuilt behavior so by connecting 'halui.program.stop' in your hal example you are clearing 'tog2nist0.is-on' which upsets the logic.
When 'tog2nist0.in' goes true and 'tog2nist0.is-on' is false it sets 'tog2nist0.on' to true until 'tog2nist0.is-on' goes true. It then sets 'tog2nist0.on' to false. (So it basically produces a pulse on 'tog2nist0.on').
See the logic diagram in the manpage:
github.com/LinuxCNC/linuxcnc/blob/0bc97e...nts/toggle2nist.comp
In your case:
When 'tog2nist0.in' goes true it sets 'tog2nist0.on' to true which causes a program stop which forces 'tog2nist0.is-on' FALSE so the component waits forever with 'tog2nist0.on' True.
One way around this would be to change the component to have a maximum waiting time for 'tog2nist0.is-on' to change state.
[edit]
Attached is a modified component.
As an example set '.pulse_length' to 1000. Mind you it will only fix the lockup state not the flawed logic behind the hal construct.
File Name: toggle2nist.comp
File Size:4 KB
  • Ayden25
  • Ayden25
05 Oct 2025 17:17
Replied by Ayden25 on topic 7i76eu connection issues
cnc@CNC:~$ ip a
1: lo: <LOOPBACK,UP,LOWER_UP> mtu 65536 qdisc noqueue state UNKNOWN group default qlen 1000
link/loopback 00:00:00:00:00:00 brd 00:00:00:00:00:00
inet 127.0.0.1/8 scope host lo
valid_lft forever preferred_lft forever
inet6 ::1/128 scope host noprefixroute
2: enp0s25: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc fq_codel state UP group default qlen 1000
link/ether 18:a9:05:29:cb:8b brd ff:ff:ff:ff:ff:ff
inet 10.10.10.1/24 brd 10.10.10.255 scope global enp0s25
inet6 fe80::1aa9:5ff:fe29:cb8b/64 scope link
  • BigDo
  • BigDo
05 Oct 2025 16:54 - 05 Oct 2025 16:55
Results of latency test, list of computers tested for use with LinuxCNC
  Mainboard Asus P5E3 Pro
i first tested it with NVIDIA GForce GT 620  - Unexpected realtime delay on task 0 with period 25000
and now with a old RV370 [Radeon X300] that makes the change.
LinuxCNC pc tests, version 20200930, started 05.10.2025 17:24:07
General info:
ASUSTeK Computer INC.,  System Product Name
Bios version 0504, dated 09/29/2009
Chipset: Harddisk is non-rotational, ie. SSD
The amount of swap currently used is 0
CPU related data:
model name    : Intel(R) Core(TM)2 Quad CPU    Q8300  @ 2.50GHz
cpu cores    : 4
stepping    : 10
cache size    : 2048 KB
RAM related data:
Maximum Memory Module Size: 2048 MB
Maximum Total Memory Size: 8192 MB
Maximum Capacity: 8 GB
Installed Size: 2048 MB (Double-bank Connection)
Enabled Size: 2048 MB (Double-bank Connection)
GPU related data:
product: RV370 [Radeon X300]
product: RV370 [Radeon X300 SE]
configuration: depth=32 driver=radeon latency=0 resolution=1920,1080
configuration: latency=0
Parallel port related data:
number of parallel ports is 0
Os and desktop related data:
PRETTY_NAME="Debian GNU/Linux 12 (bookworm)"
Should the info below not match with your machine,
kindly post the output of pstree here, including a brief
desciption of your desktop environment, window manager and
display manager. Tia
https://forum.linuxcnc.org/18-computer/39370-script-for-automated-testing-of-computer-latency
Desktop environment : lightdm
Windowmanager       : Xfwm4
Displaymanager      : lightdm
Kernel related data:
Kernel 6.1.0-30-rt-amd64
GRUB_CMDLINE_LINUX_DEFAULT="quiet isolcpus=2,3"
Cpu idle driver: acpi_idle
Kernel modules data:
Check if pcspkr is loaded: [0;32mNo, which is good![0m
Check if snd modules are loaded: [0;32mNo, which is good![0m
Keyboard & Mouse related data:
Number of mice: 1
Mouse 0 : PixArt Lenovo USB Optical Mouse
Mice  attached to USB:
Lenovo M-U0025-O Mouse
Keyboards attached to USB:
Fujitsu Siemens Computers Fujitsu Keyboard
LinuxCNC related data:
LinuxCNC version is: 2.9.6
Preparing for latency test:
Started glxgears No. 1, 2, 3, 4, 5
Started firefox with 'https://www.youtube.com/watch?v=KUXGVfmrEN4&list=RDKUXGVfmrEN4&start_radio=1', WID
Command for latency test is:
su cnc -c  "latency-histogram --nobase  --sbinsize 1000 --nox 2>&1 | tee -a 1759677845.lat &"
Latency testing loop started So 5. Okt 17:24:22 CEST 2025,
should end after So 5. Okt 19:24:22 CEST 2025
[GFX1-]: Couldn't sanitize GL_RENDERER "ATI RV370"
Manual termination requested at 05.10.2025 18:28:50
Swap useage: prerun: 0, running: 0
CPU core temperatures:
[attachment=72110]Bildschirmfoto_2025-10-05_18-34-03.png[/attachment]
  • tlightus
  • tlightus
05 Oct 2025 16:54
Replied by tlightus on topic Potential All-in-One Single Board Computers
After a bit of tweaking I let it run overnite and got this:
  • PCW
  • PCW's Avatar
05 Oct 2025 16:45
Replied by PCW on topic 7i76eu connection issues
Having a field I/O fault is normal until LinuxCNC is running
(if nothing else, there will be a watchdog fault)
What does the command
ip a
return?
  • JackRay
  • JackRay
05 Oct 2025 16:29
Five-Axis RTCP Features: G43.4 and G43.5 Equivalents in LinuxCNC
Category: G&M Codes
Hello,I am very interested in your conversation because I am experiencing the same problems. I use NX Simen and, of course, no LinuxCNC post-processor. So I have to make do with a post-processor that is as close as possible to Fanuc. I have an XYZBC configuration. trt. and I can't get a compliant configuration. I use NX Builder to modify the post-processor, but some, such as G43.4, are not interchangeable.Thank you for your help.
  • heaven
  • heaven
05 Oct 2025 16:25
Recompiling the motmod modules to expose pos-cmd pins
This method uses simple_tp in teleop mode, so it doesn’t synchronize velocity and acceleration. I’m trying to hack it to work in coordinate mode instead. that way, we’ll be able to control LinuxCNC by sending continuous waypoints through HAL pins.
I don’t fully understand how coordinate mode works yet; I just discovered where the calculations take place in the code:
github.com/LinuxCNC/linuxcnc/blob/master...tion/control.c#L1332
  • Hakan
  • Hakan
05 Oct 2025 16:24
Replied by Hakan on topic CiA 402 in 1.15.0
CiA 402 in 1.15.0
Category: EtherCAT
Remove "./" from the line
loadusr -W ./lcec_conf ethercat-conf.xml
  • MatthiasCNC
  • MatthiasCNC
05 Oct 2025 16:12 - 05 Oct 2025 16:19
CiA 402 in 1.15.0
Category: EtherCAT
Hello, thank you for your reply.
I think it has helped me a little.
I have rewritten my files and based them on “lcec_configgen.”
I found the problem.
There was a second hal file in which it was hidden.
cia402.hal:16: insmod for lcec failed, returned -1HAL: ERROR: pin 'lcec.0.3.out-01' not found
Now I always get this error.Debug file information:Note: Using POSIX realtime./ethercat.hal:15: execv(./lcec_conf): No such file or directory./ethercat.hal:15: waitpid failed ./lcec_conf lcec_conf./ethercat.hal:15: ./lcec_conf exited without becoming ready2729Stopping realtime threadsUnloading hal componentsNote: Using POSIX realtime
File Name: cia402_2025-10-05.ini
File Size:4 KB
File Name: ethercat-c...0-05.xml
File Size:7 KB
File Name: ethercat.hal
File Size:5 KB
File Name: Log.txt
File Size:2 KB
​​​​​​​What could be the reason for this? Thank you
  • Ayden25
  • Ayden25
05 Oct 2025 15:49
Okay I looked around and saw that the card should run without feild power all together. I have setup a static ip for 10.10.10.1/24
I can ping 10.10.10.10 with success but if I run up addr it still isnt visible. Maybe that's usual. Still on the linux cnc end of things with the updated 10.10.10.10 address for the card I am still getting it as unreachable
Displaying 9226 - 9240 out of 16969 results.
Time to create page: 0.700 seconds
