  • Creative25
  • Creative25
13 Sep 2024 23:56
Replied by Creative25 on topic Building a chain driven Plasma table.
I just tried viacomstructor.
It seems to generate Gcode that can run on a qtplasmac sim configuration.
However it looks like it does not generate lead ins that I selected under leads. Is there something I do wrong?
  • royka
  • royka
13 Sep 2024 23:04
Replied by royka on topic Can the OPI5 be Configured to Run LCNC?
That's a pretty impressive result! From which board is this?
13 Sep 2024 22:39
Replied by tommylight on topic Showstopper Plasma Cutter retrofit
Category: Show Your Stuff
OK, so the machine is usable, right?
Personally i never use ohmic sensing and i have removed quite a few of existing ones from old industrial machines as they were very flaky and more trouble than worth, but Rod has made some good work on making it very usable, so i might just give it a try ... when i get a torch with a shield.
Sorry i can not help more with it.
  • SteveatSteelCut
  • SteveatSteelCut
13 Sep 2024 22:20
Replied by SteveatSteelCut on topic Showstopper Plasma Cutter retrofit
Yes it has a float switch.
ideally the float switch is only there as a backup if it doesn't sense the material.  I.e. due to rust or oil.
  • machinedude
  • machinedude's Avatar
13 Sep 2024 21:48
What do you really get for a $350 desk top engraver ?
i'm wondering if Stepper-online and Leadshine are tied together somehow? the software is just about identical? anyways Leadshine  has a quick start guide for the programming software that is much more helpful than what Stepper-online has which is nothing basically. I just found the quick start guide so looks like i need to spend some time searching through that for clues. i managed to read a drive and got that part sorted out so that's a little bit of progress :)
  • CCCNC
  • CCCNC
13 Sep 2024 21:39
Replied by CCCNC on topic 7i96 Probe Problem
7i96 Probe Problem
Thank you!
This helped me a lot, I now have consistent probe result. Thanks to debouncing there is no more "Probe tripped during non-probe move".
Let´s make some chips! :-)
/T
  • Trevy3
  • Trevy3's Avatar
13 Sep 2024 21:17
Replied by Trevy3 on topic Weird Multi Axis MDI Issue in QTDragon_HD
Category: Qtvcp
I am also on 2.9 as seen in the ini file.
13 Sep 2024 21:10
Figuring out the pins for unknown VFD to hook to 7i96s
COM to spin-
AI1 to spinout or Aout
+10V to Spin+
  • Ronatron42
  • Ronatron42
13 Sep 2024 21:05
Hi, I am trying to hook up a VFD to my 7i96s.  I have a picture of the pinout for the VFD but I am having trouble determining which pins need to attach to the 7i96s and where they should be plugged in.
13 Sep 2024 20:06
  • Irritant
  • Irritant
13 Sep 2024 19:45
Tool Table Understanding was created by Irritant
Category: Installing LinuxCNC
Hi Guys, you helped me find an error in LinuxCNC and gave me the fix. So here I go again.
In the tool table what does the Z setting actually do? I have a workable setup but in the table I have set the Z to .5", and then if I home to the top of the work and then touch off .5" above this it seems to work. Am I on the right track here? So if I set the table Z to 0 then I could touch off on the work?
When I ran this a number of years ago I was in the habit (I think) of touching off Z on the work and then if would make some clearance above the part and ready to run.
Thanks!
  • meister
  • meister
13 Sep 2024 19:21 - 13 Sep 2024 19:28
Jogging via Camera-Image and mouse/touchscreen
Category: Other User Interfaces
little Preview:
www.youtube.com/shorts/VGWusrDVHlg
will also add functions to mark points in the image to setup/start touchprobe routines
SourceCode: multixmedia.org/camjog.py
Calibration via:  axis.[x|y].jog-scale
don't know how to fit the pyqt5 'window' into the tab (size)
  • Aciera
  • Aciera's Avatar
13 Sep 2024 19:12
Replied by Aciera on topic jog diameter lathe
jog diameter lathe
Category: Basic Configuration
I'm not positive but I don't think G7/G8 extends to jogging, so that would be the normal behavior I guess.
  • COFHAL
  • COFHAL
13 Sep 2024 19:05 - 13 Sep 2024 19:07
Notes from installation of ethercat on Raspberry Pi 4
Category: EtherCAT
With this image I was finally able to get ethercat working, with the image for Pi4 that is on the LINUXCNC page it was never possible.
It looks like the release manager has not released the  2.9.3 Image I gave them. Try this one
drive.google.com/file/d/1Fg2CPTezUyrRFrO.../view?usp=drive_link
  • greg23_78
  • greg23_78
13 Sep 2024 18:52
Replied by greg23_78 on topic jog diameter lathe
jog diameter lathe
I've done some tests with machining programs in diameter mode and it takes it well. but I'm still jogging in radius, is that normal?
Displaying 21331 - 21345 out of 24607 results.
Time to create page: 0.410 seconds
