  • Moutomation
  • Moutomation
26 Aug 2024 07:13 - 26 Aug 2024 07:42
Replied by Moutomation on topic İnstall glade
İnstall glade
Category: Gmoccapy
Normal buttons were created, but I copied these buttons from the 6 button examples. That's probably why it works. I think the reason why the toggle buttons are not visible is that I cannot add it to the configuration line you mentioned.
Secondly, I can change the ramps and limits from the gui, but no matter what I did, I could not change the calibration value.
There's probably something wrong somewhere
example:
testpanel3.hal:
net xvl ini.xmax_accelaration <=  testpanel3.hal_xacc-f it's work
net xmul cia402.0.pos-scale <= testpanel3.hal_xmul-f it's doesn't work
net cia402.0.pos-scale <= testpanel3.hal_xmul-f it's doesn't work
setp cia402.0.pos-scale testpanel3.hal_xmul-f it's doesn't work
sets cia402.0.pos-scale testpanel3.hal_xmul-f it's doesn't work
  • Aciera
  • Aciera's Avatar
26 Aug 2024 07:10
Replied by Aciera on topic durchmesser stimmt nicht
Category: Other User Interfaces
Wenn's immernoch nicht läuft bitte die aktuelle config zippen und posten.
  • Aciera
  • Aciera's Avatar
26 Aug 2024 07:08
Replied by Aciera on topic Is software Estop allowed
Category: HAL
I don't have a problem with raising awareness about safety, there are a few post of mine on this forum where I have suggested safer procedures than what was being used. The statement I do not agree with is this one:
Linuxcnc ‘gate keepers’ should warn users that - software estops are not allowed - for safety sake.
It's enough of a struggle to try and keep the existing code base and its documentation even halfway updated with the volunteers we have. If you would like to add information about safety then I would invite you to add to the wiki:
wiki.linuxcnc.org/cgi-bin/wiki.pl
  • CFE
  • CFE
26 Aug 2024 06:33
Replied by CFE on topic #<holes> = 3 - Unexpected behaviour
Category: Plasmac
Thank you Phil, I will have a deeper look here too.
  • phillc54
  • phillc54's Avatar
26 Aug 2024 06:10
Replied by phillc54 on topic #<holes> = 3 - Unexpected behaviour
Category: Plasmac
No worries, this is distracting us from your main issue anyway.
I really don’t know what is going on with the velocity as it works fine here. I will have a play in the morning and see if anything odd happens.
  • karlhe
  • karlhe
26 Aug 2024 06:06
Replied by karlhe on topic durchmesser stimmt nicht
hallo,
die sind alle in der .ini..
karlhe
  • CFE
  • CFE
26 Aug 2024 06:02
Category: Plasmac
No success Phil, I still get the M190 related error, see screenshot attached. I must admit I have never used sim configurations, so this is out of my depth :(
  • phillc54
  • phillc54's Avatar
26 Aug 2024 05:54
Category: Plasmac
My bad...
Need to remove the ~ from the beginning of the second line:
cp /usr/share/doc/linuxcnc/examples/nc_files/plasmac/m_files/* ~/linuxcnc/nc_files/m_files/
  • seyad
  • seyad
26 Aug 2024 05:49
Ethercat installation from repositories - how to step by step
Category: EtherCAT
 I am using your recent image only but i con't able to intall ethercat -master following this
  • CFE
  • CFE
26 Aug 2024 05:28
Category: Plasmac
Hi Phil,
I get this :
plasma@plasma:~$ mkdir -p ~/linuxcnc/nc_files/m_files
plasma@plasma:~$ cp ~/usr/share/doc/linuxcnc/examples/nc_files/plasmac/m_files/* ~/linuxcnc/nc_files/m_files/
cp: cannot stat '/home/plasma/usr/share/doc/linuxcnc/examples/nc_files/plasmac/m_files/*': No such file or directory
This is out of my territory I am afraid :(
  • phillc54
  • phillc54's Avatar
26 Aug 2024 05:15
Category: Plasmac
There must be an issue with pathing differences between package installs and run in place installs...
Try this as a workaround from a terminal:
Then restart linuxcnc again.
26 Aug 2024 05:14
Replied by Cant do this anymore bye all on topic Editing Bitfile on 7i97t for extra smart serial connections
Category: Driver Boards
So many acronyms, I just assumed the db prefix was a database file name. Then again Daughter Board makes sense.
Thanks again
  • suspension
  • suspension
26 Aug 2024 04:59
Versa probe Z height after automatic tool length measure
Sorry cmorley, I was away from home so could not reply. I have attached a simple g-code program where this issue became visible.
File Name: man_3_3.ngc
File Size:9 KB
  • CFE
  • CFE
26 Aug 2024 04:52
Category: Plasmac
Hi Phil,
It seems having to do with missing "M190" and this section in the ini file :
[RS274NGC]
RS274NGC_STARTUP_CODE = G21 G40 G49 G80 G90 G92.1 G94 G97 M52P1
PARAMETER_FILE = metric_parameters.txt
SUBROUTINE_PATH = ./:../../nc_files
USER_M_PATH = ./:../../nc_files/plasmac/m_files
But that's as far as I can get ?
Displaying 22486 - 22500 out of 24899 results.
Time to create page: 0.390 seconds
