02 Aug 2024 11:33
Replied by Cant do this anymore bye all on topic LinuxCNC-RIO - RealtimeIO for LinuxCNC based on FPGA (ICE40 / ECP5)
Should RTAI be used with Ethernet ?
I thought RT_PREEMPT was the go, at least with the hostmot2 Ethernet driver.
  • Aciera
  • Aciera's Avatar
02 Aug 2024 11:31 - 02 Aug 2024 14:51
Replied by Aciera on topic Homing with Absolute Encoders (Again)
Maybe immediate homing works for you, see section 6.14:
linuxcnc.org/docs/html/config/ini-homing.html#_immediate_homing
[edit]
Actually I think the above will still zero your position so not what you are looking for. Your solution is likely a custom homing procedure.
linuxcnc.org/docs/devel/html/man/man9/homecomp.9.html
[edit]
All nonsense see below.
02 Aug 2024 11:29
ARP & Ping are handled internally via the W5500, the only control is whether to respond to a ping or not.
After looking at info on the W5500 I read, whilst theoretically it can run an 80Mhz clock for real life 33Mhz is the max recommended.
As I said the packet issue seems to be random, you can have a period of 20000 packets be fine then you can 3 periods when the packets go south every 5000 packets and then be good for another 30k.
According to wireshark when the packets are delayed the data is good, no issues there.
Just wondering if rather than a combined r\w function in the driver whether it could be split. I have a feeling the Hostmot2 driver has seperate r\w functions. Maybe with a few functions added in between the read & write functions it may help.
  • Mecanix
  • Mecanix
02 Aug 2024 11:28 - 02 Aug 2024 11:29
Your consideration is much appreciated!! You're way too cool bud, thank you for what you've done for this community so far, no joke, it's EPIC <-- repost, take it.
Have a look and see if that's feasible. Problem on my side is not about keyboarding stuff but the Linuxcnc RTAI rather. I honestly wouldn't know where and how to test all that up, prolly would shave a month+ off my short life just to learn (min).
Side note; anyone telling you he/she's an expert in verilog and/or parallel-thinking is utterly lying to you. Bet there is only 5 persons on earth who master that brilliant e.e. mess of a codebase... (/rant_over lol)
  • meister
  • meister
02 Aug 2024 11:27
if we get rid of the errors in the w5500, i would of course always prefer this interface to the esp, as it is faster, reduces the parts and you don't have to program the esp as well.
Of course, the (r)mii interface would be even better, but the w5500 will do for now :)
  • meister
  • meister
02 Aug 2024 11:18
my knowledge of verilog is extremely limited and i would be happy to have someone with me who is more familiar with it.
I'm the last person who would complain about someone getting things to work in RIO that I'm too stupid for :)
i will test the new driver later at home, the integration into RIO is not so hard.
all what rio 'know' about the w5500 plugin is here:
riocore/plugins/w5500/
so, more or less, copy the new files into this folder and editing plugin.py:
changing list of verilog files:
self.VERILOGS = ["w5500.v", "SPI.v"]
and add the new pin:
self.PINDEFAULTS = {
            "w5500_rst": {
                "direction": "output",
                "invert": False,
                "pull": None,
The only thing missing is this in the w5500.v:
         input [BUFFER_SIZE-1:0] tx_data,
         output [BUFFER_SIZE-1:0] rx_data,
         output reg sync = 0,
         output reg pkg_timeout = 0
sync: goes to 1 if a new package is received
pkg_timeout: goes to 1 if no package received for a while (parameter TIMEOUT)
tx_data: the data to send
rx_data: the received package
pkg_timeout is needed to trigger the error state of the CNC
sync is needed for multiplexed data
BUFFER_SIZE depends on the configuration and will be set while generating the rio.v
  • Sandro
  • Sandro
02 Aug 2024 10:51 - 02 Aug 2024 11:01
Hello everyone
I am having issues setting up my homing sequence for absolute encoders on my Ethercat servo dirves. I have read trough a few topics here on the forum but did not find the solution to my problem.
Background: I have Lichuan Ethercat servo drives with 23bit absolute encoders. From testing I have found out, that the encoder tracks 512 turns (-256 to +256) which combined with my 5 mm pitch ballscrews gives me a effective range of -1280 to +1280 mm. I need a distance of 0 to 1000 mm on my machine. On startup of LCNC, my encoder reports the correct absolute position of my axis. I have setup the homing sequence as follows:
HOME_ABSOULTE_ENCODER = 2
HOME                    = 0
HOME_OFFSET                = 0
HOME_SEQUENCE            = 0
HOME_SEARCH_VEL            = 0
HOME_LATCH_VEL            = 0
HOME_IGNORE_LIMITS        = YES
#HOME_USE_INDEX          = NO
To the issue: Let's say on startup I am at some random position e.g. 833 mm. LCNC now requires me to press the home button before I am able to switch to teleop mode or issue MDI commands. What happens now, is that the position of the axis is set to 0 and my two soft limits of 0 mm and 1000 mm are applied. This however is in my opinion not correct since the soft limits are now actually at 833 mm and 1833mm. This would lead to a crash if I were to move the axis. I need the homing sequence to keep the 833 mm absolute position value and apply the soft limits at the effective 0 mm and 1000 mm. Basically I need it to just set the "homed" flag and be done with it.
Hope I was able to describe issue somewhat clearly. Any ideas?
Thank you and greetings
02 Aug 2024 10:42
Replied by tommylight on topic Error at startup
Error at startup
Category: Configuration Tools
cannot gain I/O privileges - forgot 'sudo make setuid' or using secure boot? -parallel port access is not allowed
Why is there stuff for parallel port?
If not, start over, make a new config, do not fill info at random.
  • Grotius
  • Grotius's Avatar
02 Aug 2024 10:41
Replied by Grotius on topic Trajectory Planner using Ruckig Lib
Hi Arciera,
The feedrate is set from -100 to 0 to 100 % in the gui. It's like adaptive feed.
I have to add a overide like up to 120%, but that's peanut's to do.
If the feedrate is set at 100% the gcode feedrate is exact that value. For jogging it takes the gui settings page feedrate.
So at -100% the motion goe's in reverse, also doing reverse with endvelocity. Taking the vo as endvel.
Testing a surface, this file is huge so i did a memory preview cleanup first :
Ok after testing a few gcode files, i have seen a few things in the optimizing algo. I will document these and report.
  • Mecanix
  • Mecanix
02 Aug 2024 10:21
i prefer the WT32-ETH01, cheap and available
Understood, thanks for the advice/heads up. I have placed an order for the WT32-ETH01 and will receive this within 36~48hrs. I'll update.
As important; For your review and consideration, Oliver.  I've quickly re-wrote a w5500 UDP protocol driver featuring a robust state machine and both a soft & hard reset (set on hard rst atm - preference). The SPI is a high-performance 50meg judging from the initial tests carried (see attached Gowin project/ZIP file). Additionally, please pardon my arrogance and persistence in trying to get this w5500 badboy to work; the reasoning behind is not fueled by my potential $1.99 investment losses (lol) I assure you, but more or less by the enthusiasm of that wizzy part being as simplistic as they come - let alone a ridiculously low-cost BOM and beyond ease for hardware implementation. All good reasons if RIO is to be adopted by makers like myself (iThink).
You guessed; I wouldn't know where to begin neither would know how to implement this into RIOCore. Therefore I leave it to you to investigate that possibility (or feasibility rather).
  • RotarySMP
  • RotarySMP's Avatar
02 Aug 2024 10:08
Replied by RotarySMP on topic Weiler 160 CNC Retrofit
Category: Show Your Stuff
That is nice that they used switches. Schaublin embeded Hall sensors into the bed of the 125-CNC. I hope they dont fail.
  • RotarySMP
02 Aug 2024 10:07
Replied by RotarySMP on topic Verify my Mesa selection
Category: Driver Boards
That makes sense.
  • RotarySMP
02 Aug 2024 10:06
Replied by RotarySMP on topic Ebosa 140 CNC retrofit
Category: Turning
Nice work.
I downsize pictures to 1000 pixels on the long side before uploading them.
  • Lpkkk
  • Lpkkk
02 Aug 2024 10:04 - 02 Aug 2024 10:06
Remora RT1052 nvem pinouts was created by Lpkkk
Hello
Can anyone share remora pinouts for nvem RT1052 board?
I'm trying to set limit switches by adding :
net X-min remora.input.00 => joint.0.home-sw-in joint.0.neg-lim-sw-innet Y-min remora.input.02 => joint.1.home-sw-in joint.1.neg-lim-sw-innet Z-min remora.input.04 => joint.2.home-sw-in joint.2.neg-lim-sw-in
To my hal, but without proper pinout diagram I'm not sure which pin is for remora.input.00 etc.
I've tried by connecting like on drawing in attachment, unfortunately without success.
Also is estop and probe pin counted as a inputs or separately?
  • captain-panda
  • captain-panda's Avatar
02 Aug 2024 09:55 - 03 Aug 2024 10:08
Gravograph Engraving Machine(s) Conversion (Updated)
Category: Basic Configuration
Dear All,
Figured it out with extended reading - thanks for this great forum! - and a bit of creative try-and-error.
All 3 axes are set up and calibrated, homing works like a charm :)
Next and last open issue is the spindle - but I don't expect much difficulty with that. Otherwise there'll be another post here ...
ORIGINAL POST:
I've started a project to convert a 30-year-old engraving machine (Gravograph UNICA) to LinuxCNC running on a Raspberry PI 4 with a MESA 7C80. I have several Gravograph machines of various sizes available and am looking to roll out my conversion to most of them, if it works out as planned. These machines may be old, but as such they're solid and reliable. Also they are simple as there's just one stepper and one limit switch per axis and the spindle motor to control. The main reason for conversion is that the UNICA machine only runs on it's own Gravograph-unique operating system with a tiny monochrome CRT screen and propietary keyboard, with no communication port. The other, larger machines can communicate via serial port, but they also require Gravograph-only software ...
So far, I got the Raspberry PI, 7C80 and LinuxCNC up and running to the point that the x-axis stepper is operational by using linuxcnc.hal and linuxcnc.ini from this thread:
forum.linuxcnc.org/42-deutsch/52725-3-ac...esa-7c80-und-raspi-4
As far as I can tell, there's no wizard available (stepconf etc.) for configuring the MESA 7C80, so I need to work with the config files directly(?)
I modified linuxcnc.ini so that the stepper runs smoothly, and added three lines for the limit switch and homing. The stepper now starts running when I home the machine in LinuxCNC, and the program is apparently waiting for the limit switch to be triggered.
This is where I'm currently insecure and would like to ask for assistance:
  • What terminals to connect the limit switch to at the 7C80?
  • How to set it up as a NC contact (Switch opens when x-axis home position is reached)?
  • How to set up homing to move the spindle towards home at first if the home switch is not triggered, and then move a short distance away and back to the final home position?
    This is my current linuxcnc.ini:
    File Name: linuxcnc.ini
    File Size:4 KB
    Thank you for reading and thanks in advance for any answers!
    Best regards,
    Erik
    captain-panda
Displaying 24001 - 24015 out of 25070 results.
Time to create page: 0.515 seconds
