  • Cdub
  • Cdub
28 May 2025 14:41
Replied by Cdub on topic M62-M68 codes not working
Category: Plasmac
Gotch ya. How do I add the key? When I try to save it to trusted.gpg.d it says I do not have the proper permissions
  • Aciera
  • Aciera's Avatar
28 May 2025 14:40
Replied by Aciera on topic Fehler in Dokumentation entdeckt
Category: Deutsch
I've passed this on.
github.com/LinuxCNC/linuxcnc/issues/3458
Thanks for reporting.
  • zz912
  • zz912's Avatar
28 May 2025 12:29
Replied by zz912 on topic Gmoccapy 3.5.0 - opinions needed
Category: Gmoccapy
We can't decide anything, but we have the amazing Pull Request tool.
Norbert or Hans merged all the important PRs I made. Or they directed me on how to edit these PRs to make them acceptable to them.
I'm writing this here because I think it's a shame that you'll do some work that ends up in the depths of the forum.
  • unknown
  • unknown
28 May 2025 12:06
Replied by unknown on topic LinuxCNC compatible industrial PC
Atom is the cpu.
I've had good results with 3rd gen 4 core i5s, specifically Lenovo M73 tower, works well enough for software step generation.
Ex corporate PCs (x86/64 platforms)seem to be best bang for buck, RPi5 with a NVMe drive are quite quick, latency is usable, I've had one on the test bench communicating with a 7i92 for a few weeks with no issues. Spent a few weeks in January putting together the RPi Linuxcnc images that are for upload.
Odroid have a good range of compact x86/64 boards, I have an earlier model H3 plus that's been in for 4 or 5 years.
Asrok J series MB work well, either 4 or dual core.
  • Aciera
  • Aciera's Avatar
28 May 2025 12:06
Replied by Aciera on topic Gmoccapy 3.5.0 - opinions needed
Category: Gmoccapy
Personally I would choose option 3.
I have suggested to make individual GUIs more self contained and modular. Would clearly make the code base bigger but it would be a lot easier to maintain things in the long run an also make it a lot easier to clean out the outdated and broken ones.
But neither Gmoccapy nor any of the other guis are my projects so it is not my decision to make.
  • Aciera
  • Aciera's Avatar
28 May 2025 11:59
Replied by Aciera on topic woodpecker.ini - cant be loaded
Actually, it does run on 2.9.4 after installing 'python3-pyqt5.qtopengl' as suggested in the debug output but there are clearly other problems:
  • unknown
  • unknown
28 May 2025 11:58
try isolcpus=2,3
  • zz912
  • zz912's Avatar
28 May 2025 11:44
Category: Gmoccapy
There are several options:
1) do nothing (worst option for me)
2) test some basic GUIs and accept that it might break other GUIs
3) make your own offsetpage widget for Gmoccapy
I prefer 2) Over time, the GUI will have to be tidied up
  • zz912
  • zz912's Avatar
28 May 2025 11:28
Replied by zz912 on topic woodpecker.ini - cant be loaded
I agree with you. Reducing at least the non-functional GUIs would be nice.
github.com/LinuxCNC/linuxcnc/issues/1762#sim
  • h_munktell
  • h_munktell
28 May 2025 11:18
Replied by h_munktell on topic Dust Collection Shoe with independent Z control
Interesting. I have just built a W, z attached dust shoe myself and started to look into getting it into HAL. Think I have almost the same requirements as you with manual override, auto-follow, park when tool changing etc. Would you mind sharing your ini file as well? And the rest of your HAL files, I'm missing the components used in your HAL above.
  • Aciera
  • Aciera's Avatar
28 May 2025 11:11
Category: Gmoccapy
i would but I have no idea which other guis use this widget so I cannot test.
  • workshop54
  • workshop54
28 May 2025 10:06
Replied by workshop54 on topic LinuxCNC compatible industrial PC
I started with the latency tests, but then I found the script to run latency tests.
The best result I got with with latency-histogram --nobase was about 230000
I logged every change I made and the results after the change, which gives me some nice insights what happens, but I cannot get the latency any lower.
I mentioned the "Atom platform", but I don't have enough experience with hardware to know exactly what you mean by that. I can make an educated guess, but that's basically it.
So instead of looking for PC's of a specific brand and type, would it be better to look at platforms that work well?
  • endian
  • endian's Avatar
28 May 2025 09:30
resolved-- Regarding the data reading offset issue of the ether cat IO module
Category: EtherCAT
When I was testing this signal input, I found that when I turned on LED0, the corresponding IO PIN was lit up at pin number 16. Similarly, the output position was also the same. In summary, the data I currently receive has been shifted by 16 bits. Additionally, I have attached my XML and the test results from Beckhoff (they are all OK). Could someone kind-hearted please tell me why?
Can you share whole config to better understanding please? I am interested in the two masters from your configuration ... how and if it is working? thank you
but defenetely you can not let 32bit lenght for halType="bit" I think ...
<pdoEntry idx="6000" subIdx="01" bitLen="32" halPin="bit-in" halType="bit"/>
Check actual config over, then you will can read active configuration from online slaves... then just copy paste
ethercat pdos -v
28 May 2025 09:27
Spindle Speed Settings only from file, no MDI possible?
Might also need $0 for the first spindle, so
M3 $0 S12000
Displaying 2836 - 2850 out of 24889 results.
Time to create page: 0.283 seconds
