  • kubes
  • kubes
15 May 2025 14:19
Replied by kubes on topic Show your screens
Show your screens
Category: QtPyVCP
@ anfänger
Nice work on the update to probe_basic.  The status tab is perfect!  I see this is an older post, but maybe you can share the update or some notes on how you made it.  I want to create something very similar.  Newbie here and not sure where to start.
  • SteepLearningCurve
15 May 2025 14:16
Replied by SteepLearningCurve on topic None of the axis are moving - using mesa 7i92t with 7i76u
Category: Basic Configuration
Hi All
Yes, the W4 jumper on the 7i92t was down, and it is now up.
The linuxcnc config loads,  the inputs also work , and there is also movement on the motors :)
A very very big thank you, to the knowledgeable folks on this forum, for sharing your valuable time, wisdom, and knowledge with me, it is greatly appreciated.
As a person new to Linuxcnc , there are so many things that we don't know.
Be braver than me, post a question sooner than I did.
(For folks reading this post in the future, the wiring currently is differential, and seems to be working fine).
  • DarkPhoinix
  • DarkPhoinix
15 May 2025 14:01 - 15 May 2025 14:04
Replied by DarkPhoinix on topic Remora - ethernet NVEM / EC300 / EC500 cnc board
Warning: Spoiler!
Thanks for reply,
I have set 12800 and testing some gcode only with Y working.
I don't want to cause problems when all the stepper and spindle are physically working.
  • PCW
  • PCW's Avatar
15 May 2025 13:50
Replied by PCW on topic Question on Servo analog output scaling
Yes, unless you set the analog scale so that it equals
the velocity in machine units per second at 10V, (and FF1 ==1.000),
You will need to tune FF1 using halscope.
Here is a long thread about this tuning:
forum.linuxcnc.org/10-advanced-configura...to-example-mesa-7i77
  • cmorley
  • cmorley
15 May 2025 12:30 - 16 May 2025 13:14
Replied by cmorley on topic Error in tool_offsetview.py
Category: Qtvcp
You bet. I will look at it as soon as I can.
  • langdons
  • langdons
15 May 2025 12:29
  • cmorley
  • cmorley
15 May 2025 12:25
Replied by cmorley on topic Manual Toolchange + Abs Z Probe (QtDragon)
Category: Qtvcp
Can you post the changes you made?
  • Esaber
  • Esaber
15 May 2025 12:16
Replied by Esaber on topic Esab Ultrarex UXD-P2000 Upgrade Project
Category: Plasma & Laser
Hi Tommy. Thanks for the instructions. Will let you know how it goes.
  • buergi
  • buergi
15 May 2025 12:14
Replied by buergi on topic mesa 7i73 4x8 keypad problems on KEY8 input
Category: Driver Boards
Today I managed to modify the hex file as proposed above by removing the EOF lines are sorting the sections. This way I succeeded flashing and all buttons of the matrix keyboard are now finally working. Thanks Peter for the firmware.
I really wonder why all the tools, I also tried more modern versions of the MPLAB X IDE, are not able to properly read the original hex format.
  • JT
  • JT's Avatar
15 May 2025 11:31
Best practice for installing custom Python packages in LinuxCNC?
Why not just build a deb and install your package?
github.com/jethornton/simple-deb
github.com/jethornton/simple-pyqt5-deb
Or if you're using Flex GUI you can just add it to your ini and it gets imported.
gnipsel.com/linuxcnc/flexgui/python.html
JT
  • unknown
  • unknown
15 May 2025 09:24
Replied by unknown on topic Combined MESA board order for Australia.
Yeah sorry about that mate.
Shipping is a killer to Down Under. I've used shipito as a forwarder and gotten good value on previous occasions.
I've previously used a Spartan 6 Dev board\Colorlight board (spartan 6 based ones are hard to find now) as a smart serial card based on Mesa's 7i90 hostmot2 firmware. Unfortunately it only supports digital I\O and 4 encoders for use as hand wheels. No analogue nor keyboard functions and not quite as compact as the 7i73.
  • Krulli_Fräser
  • Krulli_Fräser
15 May 2025 07:40
Replied by Krulli_Fräser on topic Question on Servo analog output scaling
I had FF1 at 0.05 before and increased it to 1.000
However, the axis began to vibrate and commanding a jog resulted in a really high follow error, so the machine engaged the e stop.
  • stenly
  • stenly
15 May 2025 06:41
Replied by stenly on topic Deckel-Maho DMU 50T
Deckel-Maho DMU 50T
Category: Milling Machines
Thank you all for the responses!
I inquired with iC-Haus and it looks like the chips will work just fine for me. I'm currently in contact with them to get a price offer. Even better that they're based in the EU.
It'll take a bit of time to cobble together a PCB with said chips, but it's looking promising and I'll post an update with the results.
  • cakeslob
  • cakeslob
15 May 2025 04:35
hey murph, i think scott said the outputs were just optocouplers or something like that, see if you can filter through his recent posts,
pheonix, like spyder said its based on application, but start with like 800-1600 and if you get following errors its too high
  • MakeMe12
  • MakeMe12
15 May 2025 04:25
Replied by MakeMe12 on topic Combined MESA board order for Australia.
I didn't mean for this to turn into a debate.
I have had great support from Mesa and they make quality parts.
The freight is not their core business but is the weight around their necks for sales into Australia.
I was just hoping to get a better deal if able to combine costs. Better products and service and reasonable freight.
Displaying 4096 - 4110 out of 24484 results.
Time to create page: 0.408 seconds
