  • Milkof
  • Milkof
15 May 2025 16:00
Mesa 7I96 + Stepper online CL86T Wiring connections
Category: Driver Boards
 Hello everyone,
I wanted to ask a favour of some more experienced users than myself.
I am making the electronics with the 7I96 and the CL86T drives, the connections for the motor management I managed to connect.
Now I am missing the limit switches e-stop and Z-Finder, could you kindly check on the attached diagram if the connections are correct?
Milko
15 May 2025 15:43
Why does it seem like everyone here is Australian?
I am not in Australia.
I do like Australia, with all the creatures that can kill people easily, mostly because of people.
  • langdons
  • langdons
15 May 2025 15:27
It seems all permanent, long-standing members, contributors, moderators, etc. are Australian.
Why is this?
Why would a place with a hot climate have lots of people who work with heat-producing machinery in a room that likely has no A/C?
Machines likely need cooling water (fresh, not salty), a rarish thing in Australia.
I suppose close proximity to Asia is nice, but is kinda counterracted by the fact that it's far away from the USA (though Trump is successfully making proximity to the US less desirable).
  • langdons
  • langdons
15 May 2025 15:17
[SOLVED]linuxcnc Latency test ambiguous results
Didn't TommyLight literally say that?
  • DarkPhoinix
  • DarkPhoinix
15 May 2025 14:46
Replied by DarkPhoinix on topic [SOLVED]linuxcnc Latency test ambiguous results
Today i try a new MB with HDMI exit! The youtube video test is DUMP!
Try stress test + glxgear for your system dont lose time!
  • kubes
  • kubes
15 May 2025 14:19
Replied by kubes on topic Show your screens
Show your screens
Category: QtPyVCP
@ anfänger
Nice work on the update to probe_basic.  The status tab is perfect!  I see this is an older post, but maybe you can share the update or some notes on how you made it.  I want to create something very similar.  Newbie here and not sure where to start.
  • SteepLearningCurve
15 May 2025 14:16
Replied by SteepLearningCurve on topic None of the axis are moving - using mesa 7i92t with 7i76u
Category: Basic Configuration
Hi All
Yes, the W4 jumper on the 7i92t was down, and it is now up.
The linuxcnc config loads,  the inputs also work , and there is also movement on the motors :)
A very very big thank you, to the knowledgeable folks on this forum, for sharing your valuable time, wisdom, and knowledge with me, it is greatly appreciated.
As a person new to Linuxcnc , there are so many things that we don't know.
Be braver than me, post a question sooner than I did.
(For folks reading this post in the future, the wiring currently is differential, and seems to be working fine).
  • DarkPhoinix
  • DarkPhoinix
15 May 2025 14:01 - 15 May 2025 14:04
Replied by DarkPhoinix on topic Remora - ethernet NVEM / EC300 / EC500 cnc board
Warning: Spoiler!
Thanks for reply,
I have set 12800 and testing some gcode only with Y working.
I don't want to cause problems when all the stepper and spindle are physically working.
  • PCW
  • PCW's Avatar
15 May 2025 13:50
Replied by PCW on topic Question on Servo analog output scaling
Yes, unless you set the analog scale so that it equals
the velocity in machine units per second at 10V, (and FF1 ==1.000),
You will need to tune FF1 using halscope.
Here is a long thread about this tuning:
forum.linuxcnc.org/10-advanced-configura...to-example-mesa-7i77
  • cmorley
  • cmorley
15 May 2025 12:30 - 16 May 2025 13:14
Replied by cmorley on topic Error in tool_offsetview.py
Category: Qtvcp
You bet. I will look at it as soon as I can.
  • langdons
  • langdons
15 May 2025 12:29
  • cmorley
  • cmorley
15 May 2025 12:25
Replied by cmorley on topic Manual Toolchange + Abs Z Probe (QtDragon)
Category: Qtvcp
Can you post the changes you made?
  • Esaber
  • Esaber
15 May 2025 12:16
Replied by Esaber on topic Esab Ultrarex UXD-P2000 Upgrade Project
Category: Plasma & Laser
Hi Tommy. Thanks for the instructions. Will let you know how it goes.
  • buergi
  • buergi
15 May 2025 12:14
Replied by buergi on topic mesa 7i73 4x8 keypad problems on KEY8 input
Today I managed to modify the hex file as proposed above by removing the EOF lines are sorting the sections. This way I succeeded flashing and all buttons of the matrix keyboard are now finally working. Thanks Peter for the firmware.
I really wonder why all the tools, I also tried more modern versions of the MPLAB X IDE, are not able to properly read the original hex format.
  • JT
  • JT's Avatar
15 May 2025 11:31
Best practice for installing custom Python packages in LinuxCNC?
Why not just build a deb and install your package?
github.com/jethornton/simple-deb
github.com/jethornton/simple-pyqt5-deb
Or if you're using Flex GUI you can just add it to your ini and it gets imported.
gnipsel.com/linuxcnc/flexgui/python.html
JT
Displaying 4246 - 4260 out of 24346 results.
Time to create page: 0.424 seconds
