  • PCW
  • PCW's Avatar
29 Nov 2025 19:13
Replied by PCW on topic 7C80 on RPI5
7C80 on RPI5
Category: Driver Boards
If you bought the card from Mesa after March 2025, it will already have up-to-date firmware
The firmware is available from Mesa's web store (in the specifications tab of the 7C80)
  • pgenns24
  • pgenns24
29 Nov 2025 17:21
Replied by pgenns24 on topic 7C80 on RPI5
7C80 on RPI5
Where can i get the updated firmware?
I have connected the 7C80 to raspberry Pi 5.
Thank you,
  • Hakan
  • Hakan
29 Nov 2025 17:17
Machine fails to get past G1 "spindle-at-speed" issue EtherCAT spindle
Category: EtherCAT
Not the same, stat-at-speed looks for two bits in the statusword from the drive.
There is a genuine mistake made there.
But actual speed should work nevertheless, I'll take a look at that also tomorrow.
Do you see any actual speed from the lcec.0 component?
  • Will_cnc
  • Will_cnc
29 Nov 2025 16:53
Category: EtherCAT
Hi Hakan
thanks for your help , I'm using the cia402pv component you put together, I can't seem to get the drive to feed back the velocity of the motor could this maybe be another issue ?
  • Hakan
  • Hakan
29 Nov 2025 16:31 - 29 Nov 2025 16:31
Category: EtherCAT
I seem to have made a mistake in the cia402pv component with the stat-at-speed pin..
I'll look at that tomorrow. If you just want to mill you can comment out the spindle-at-speed signal and
setp Spindle.0.at-speed 1
  • Will_cnc
  • Will_cnc
29 Nov 2025 16:10
Category: EtherCAT
Hi everyone,I’ve recently finished mounting my machine to its base and tidying up the wiring, so I decided to try running a quick program to see if everything was working properly.Machine Configuration:
  • Controller: Raspberry Pi 5
  • Servos: 3 × Leadshine EL8 servo drives with 400 W motors (EtherCAT)
  • Spindle: 1 kW StepperOnline drive (EtherCAT)
The program starts fine, but the machine seems to get stuck at the first G1 command.After doing some reading, it looks like this could be related to the “spindle-at-speed” signal in the HAL configuration.Because I’m using EtherCAT, I’m not sure where this needs to be handled:
Should the spindle-at-speed signal be configured in the HAL file, or Is it something that needs to be set up in the .comp file for the EtherCAT drive?
Any guidance or examples on how to handle this signal within an EtherCAT setup would be really appreciated. when the spindle is running currently I am having no feedback from the drive to record the actual speed ?
  • rodw
  • rodw's Avatar
29 Nov 2025 15:12
Is there any way to use Pncconf Wizard to set up 7i97T with 7i73 pendant board?
Searching the forum for MPG will finds a number of MPG implementations and hal file examples.
Or you could've read the docs.
linuxcnc.org/docs/stable/html/examples/mpg.html
skip using the encoder and use the mesa MPG terminals
29 Nov 2025 15:11
Replied by tommylight on topic Low voltage limit/home switch configuration
Category: Basic Configuration
some examples form my machines, see on the right side a row of 3 relays, those are for inputs and they isolate the machine part from electronic part, so less interference and no need for good shielded cables (i can no find good cables here):
forum.linuxcnc.org/show-your-stuff/38547...uild?start=30#165873
Or the "arduino" relays as seen here
forum.linuxcnc.org/show-your-stuff/38547...ild?start=110#172157
  • rodw
  • rodw's Avatar
29 Nov 2025 14:58
LinuxCNC latency and jitter improvements with PREEMPT_RT kernel parameter tuning
Found another one
blog.loriowar.com/how-to-reduce-jitter-on-linuxcnc
This one at least mentions network latency. In my view this is more important than system latency where you are not using software stepping.
  • Hakan
  • Hakan
29 Nov 2025 14:47
Replied by Hakan on topic AX58100
AX58100
Category: EtherCAT
That should work. It's a 16-bit encoder counter so be prepared to handle overflow.
TIM2/TIM5 are 32-bit so better to use that when you do your own. There is only one 32-bit though.
  • Unlogic
  • Unlogic
29 Nov 2025 14:41
Replied by Unlogic on topic Schaublin 125-CNC retrofit.
Category: Turning
I added the following HAL code to the configuration of my mill to keep the spindle on for a few seconds after the spindle is disabled just to get the nice smooth ramp down you are looking for:
# --- timedelay before disable spindle output for deceleration ramp --- #
loadrt timedelay names=timedelay.spindle-enable-soft-stop
addf timedelay.spindle-enable-soft-stop servo-thread
setp timedelay.spindle-enable-soft-stop.on-delay 0
setp timedelay.spindle-enable-soft-stop.off-delay 3
net spindle-enable => timedelay.spindle-enable-soft-stop.in
net spindle-enable-soft-stop <= timedelay.spindle-enable-soft-stop.out
net spindle-enable-soft-stop => hm2_7i96s.0.7i84.0.0.output-01
For more information see my post here: forum.linuxcnc.org/12-milling/50559-opti...sion?start=70#309845
  • rodw
  • rodw's Avatar
29 Nov 2025 14:41
You have not said what voltage you are using.
The rationale behind 24 volts being more or less standard for industrial systems is that it is more resistant to triggering from noise because a much greater voltage fluctuation is required to trigger false readings.
I think you have already diagnosed the issue.
Also using an industrial power supply like a Meanwell MDR-60-24 won't break the bank. I have lost count of people reporting issues when they use 5 volt plug packs...
  • rasmus
  • rasmus
29 Nov 2025 14:27
Replied by rasmus on topic carousel.comp scale questions.
Thank you.
The encoder is not 1:1 to the ATC Carousel, but mounted directly on the carousel shaft.
The relation is more about 43:1but not exactly, I did a hack reprogramming of the carousel.comp, but not nice and maybe not that thought trough, needs to be tested.
If it does not work i will have a look on the counts mode and see if that will work better.
  • vibram
  • vibram
29 Nov 2025 14:07 - 29 Nov 2025 14:46
Replied by vibram on topic AX58100
AX58100
Category: EtherCAT
Hello
I bought the following card (still waiting for it) and it seems to have TIM8 CH1 and CH2 available
fr.aliexpress.com/item/1005008473184616....gatewayAdapt=glo2fra
This browser does not support PDFs. Please download the PDF to view it: Download PDF
  • Sekai
  • Sekai
29 Nov 2025 13:29
Replied by Sekai on topic Chinese Mesa 7I92 from aliexpress NEW
youre right about the bob, but for now i dont have a bob.
For now i'm new to mesa card in general.
Displaying 10711 - 10725 out of 11230 results.
Time to create page: 0.342 seconds
