  • Autumn Reign
  • Autumn Reign
29 Nov 2025 13:18
Low voltage limit/home switch configuration was created by Autumn Reign
Category: Basic Configuration
I have finally gotten my first LinuxCNC machine homing! It is a XXYZA machine. I am quite happy with my progress and everything I have learned. The machine appears to be holding tolerances well while jogging and I am very excited to start running gcode here shortly.
However, I am getting an oddity with my home switches while homing. It's a low voltage system for signals and having spent a lot more time with all of this I realize that a 12 or 24 volt communication voltage and some daughter cards would have kept some of my troubles in the realm of programming and less in the realm of electrical engineering. I have a 6i25 running to a bank of CL86Y's and 4 functioning home switches (XYZA) from 0V to GPIO pins that are normally closed, one for each axis. I think I am making some sort of pullup/pulldown or other fundamental signal error in my home switches.
With my attached hal/ini configs while homing if I start with switches depressed everything homes great. X and A homing are disabled while I am playing with settings but they work when enabled. Halshow shows my switches working as expected. Diag goes "yellow" when the switch is hit and resumes "red" when released. Sometimes I have seen an unexpected flicker, and the shielded wire is not yet grounded. All other cables are shielded and grounded so I think EMI is minimal, but I will be grounding the shield shortly regardless. However, if I start off of switches the axis will pulse forward and then stop after a move of no even length and throw an error about not being on a switch when backing up, as if it was transitioning from search_vel to latch_vel.
I don't mind starting the machine homing by hand, but I am concerned my home switches are triggering the 6i25 IO while I would be normally operating. This seems like it cannot be a great thing to be doing, but maybe it would not be relevant.
If you have any suggestions to get more reliable performance, I would appreciate leaning on all of your experience.
File Name: Autumn_2025-11-29.ini
File Size:6 KB
File Name: Autumn_2025-11-29.hal
File Size:15 KB
  • abu
  • abu's Avatar
29 Nov 2025 12:52 - 29 Nov 2025 14:27
LinuxCNC latency and jitter improvements with PREEMPT_RT kernel parameter tuning
Warning: I have a machine with a 12-core Intel i7 (numbered 0 to 11). The numbers shown in this answer will vary depending on the number of cores in each machine. Do not use Ctrl+C/Ctrl+V. You must read the articles cited in the thread. The calculations for the numbers are there.
Ladies and gentlemen, this looks promising!
It seems that POSIX realtime (PREEMPT_RT kernels) is finally working decently.
This is my machine (linuxcnc info):
The file:    /tmp/linuxcnc_info.txt
can be posted to a forum or a web site like:
     pastebin.com
in order to provide information about the linuxcnc
system and configuration.
VIEWER=kate
                Date: sáb 29 nov 2025 19:36:45 CET
            UTC Date: sáb 29 nov 2025 18:36:45 UTC
        this program: /home/xiuser/linuxcnc/scripts/linuxcnc_info
              uptime:  19:36:45 up  1:04,  1 user,  load average: 0,35, 0,50, 0,79
      lsb_release -a: Distributor ID:    Debian
Description:    Debian GNU/Linux 12 (bookworm)
Release:    12
Codename:    bookworm
            linuxcnc: /home/xiuser/linuxcnc/scripts/linuxcnc
                 pwd: /home/xiuser
                USER: xiuser
             LOGNAME: xiuser
                HOME: /home/xiuser
              EDITOR:
              VISUAL:
            LANGUAGE:
                TERM: xterm-256color
           COLORTERM: truecolor
             DISPLAY: :0.0
             DESKTOP: lightdm-xsession
        display size:     3360x1080 pixels (889x285 millimeters)
                PATH: /home/xiuser/linuxcnc/scripts:/home/xiuser/linuxcnc/bin:/home/xiuser/.local/bin:/home/xiuser/linuxcnc/bin:/home/xiuser/linuxcnc/scripts:/home/xiuser/linuxcnc/tcl:/usr/local/bin:/usr/bin:/bin:/usr/local/games:/usr/games
uname items:
         nodename -n: HPi7
      kernel-name -s: Linux
      kernel-vers -v: #1 SMP PREEMPT_RT Debian 6.12.57-1~bpo12+1 (2025-11-17)
          machine -m: x86_64
        processor -p: unknown
         platform -i: unknown
      oper system -o: GNU/Linux
/proc items:
             cmdline: BOOT_IMAGE=/boot/vmlinuz-6.12.57+deb12-rt-amd64 root=UUID=6dec6435-2cb8-427a-9697-c8d82ce45bdb ro net.ifnames=0 skew_tick=1 nosmt=force kthread_cpus=0-5 irqaffinity=0-5 rcu_nocb_poll rcu_nocbs=6-11 nohz=on nohz_full=6-11 isolcpus=6-11 intel_pstate=disable amd_pstate=disable idle=poll cpufreq.off=1 cpuidle.off=1 intel_idle.max_cstate=0 amd_idle.max_cstate=0 nowatchdog nosoftlockup i915.force_probe=!4680 xe.force_probe=4680
          model name:  12th Gen Intel(R) Core(TM) i7-12700
               cores:  12
             cpu MHz:  3685.961
             parport:
              serial:
Versions:
                 gcc: gcc (Debian 12.2.0-14+deb12u1) 12.2.0
              python: Python 3.11.2
                 git: git version 2.39.5
          git commit: 2cee0486b4
                 tcl: 8.6
                  tk: 8.6
               glade: glade 3.40.0
linuxcnc_var all:
     LINUXCNCVERSION: 2.10.0~pre0
LINUXCNC_AUX_GLADEVCP: /usr/share/linuxcnc/aux_gladevcp
LINUXCNC_AUX_EXAMPLES: /usr/share/linuxcnc/aux_examples
            REALTIME: /home/xiuser/linuxcnc/scripts/realtime
                 RTS: uspace
          HALLIB_DIR: /home/xiuser/linuxcnc/lib/hallib
              PYTHON: /usr/bin/python3.11
This is the latency histogram before tuning:
And this is the histogram after the changes...
First change: A new kernel that includes the new Intel Xe video driver, which will replace the venerable i915. Xe is in kernels >= 6.12.
Second change:
the GRUB_CMDLINE_LINUX_DEFAULT boot line in Grub. Now cmdline is:
Note: force_probe => i915 OFF and Xe ON. My video device ID is 4680. Yours may be different. lspci gives the ID for each machine.
Third change: Modifying kernel parameters at runtime:
sudo sysctl kernel.timer_migration=0
sudo sysctl kernel.sched_rt_runtime_us=-1
  • Muzzer
  • Muzzer
29 Nov 2025 12:46
Updating from LINUXCNC - 2.8.4-23, Mint 20.3 - gmoccapy lathe structure
Category: Gmoccapy
Aha. Many thanks - commenting out that duplicated line did the trick, so I now have the machine moving in closed loop, homing correctly and e-stopping safely. That's a great step forward and it feels as if I'm getting close to getting this sorted out.
I now have to get the xhc-whb04b-6 MPG connected up (currently commented out) and the spindle vfd doesn't respond, so I'll need to check that out too.
Andy Pugh's macros don't show up in my GUI. I have the tab showing up but clicking on it does nothing - none of the graphics appear. There are several gmoccapy lathe sims that work but something's not right in my setup. Again, I'm not clear what files need to be where and what configs need to be set up. Is there any documentation for the lathe macros that I can refer to?
Many thanks
  • endian
  • endian's Avatar
29 Nov 2025 12:17 - 30 Nov 2025 07:27
Replied by endian on topic Reduce read-all timing 7i76e + 7i77
hello PCW,
base thread or servo thread latency is way under 6us ...
here are statistics
Warning: Spoiler!
what to do next please? regards and thanks
  • Aciera
  • Aciera's Avatar
29 Nov 2025 12:09
Replied by Aciera on topic StepperOnline A6 Servo
Category: EtherCAT
trivkins: already exists
Looks like you are trying to load the kinematics module twice.
I can see one in your screen shot:
'loadrt [KINS] KINEMATICS'
Generally a bit difficult to help with just snippets of information.
  • mooser
  • mooser
29 Nov 2025 11:20
Replied by mooser on topic 7i84u probably toasted
Category: Driver Boards
With the jumper removed, connected to field power and the 7i96s connected:
Nothing between 1 and 3 pins on W1
22.8v between 1 and 2, nothing between 2 and 3
carefully removed the IC, still nothing between 1 and 3 and the status lights are still the same.
Ah well, it was an expensive evening
M
  • DemonClaW
  • DemonClaW
29 Nov 2025 11:14
Replied by DemonClaW on topic StepperOnline A6 Servo
Category: EtherCAT
I just got my first servo, too. But even after all Iread here i wasnt able to get it running maybe one of you already had the same problem or im just doing the same mistake over and over again.
Thanks for your help
  • PCW
  • PCW's Avatar
29 Nov 2025 10:32
Is there any way to use Pncconf Wizard to set up 7i97T with 7i73 pendant board?
Adding a simple probe input does not require adding any components, basically just
making some connections in the hal file, something like:
 net probe hm2_7i97.inmux.00.input-15 =>  motion.probe-input
 or perhaps
net probe hm2_7i97.inmux.00.input-15-not =>  motion.probe-input
depending on the probe polarity.
Adding a MPG will typically require at least one components as a mux component
is often used to select between jog increments.
Searching the forum for MPG will finds a number of MPG implementations and hal file examples.
  • PCW
  • PCW's Avatar
29 Nov 2025 10:21
Replied by PCW on topic Chinese Mesa 7I92 from aliexpress NEW
With a 7I92, you would normally chose firmware that matches the
pinout of the breakout board you use. The G540x2 firmware is made
to match the pinout of the Gecko G540 4 Axis step/dir drive.
A commonly use breakout board (BOB)  is the Sainsmart "Mach 5 Axis CNC" breakout
For the, you would use  "5ABOB" firmware
  • zz912
  • zz912's Avatar
29 Nov 2025 10:20 - 29 Nov 2025 12:20
Replied by zz912 on topic GTK little probe screen
Category: Gmoccapy
Little probe screen was added to master branch.
github.com/LinuxCNC/linuxcnc/pull/3643
I will be happy for feedback.
  • Tinker
  • Tinker
29 Nov 2025 10:16
I really don't even need to use the 7i73, all I am really trying to do is add a probe input and set up this MPG for my 7i97T. I really don't know how to add custom components to hal and ini files from scratch. I will admit that I do need to read up on the process...
  • mooser
  • mooser
29 Nov 2025 10:03
Just received the other email, (didn't make the connection to you)
I'll try as you suggested, nothing to loose at this point.
Thanks so much for the help
M
  • Sekai
  • Sekai
29 Nov 2025 10:01 - 29 Nov 2025 10:04
Replied by Sekai on topic Chinese Mesa 7I92 from aliexpress NEW
Ok. got it to work with the intel itx board. the fujistu minipc is hopeless.
I got it with 7i92_G540x2D firmware, kind of weird to setup the pins. Is there a simple firmware?
For reference i'm planning to use an lathe like 400x1000 3 tons with live tooling so no Y axis (X axis, Z axis and C-axis)
Edit: BTW i used a chinese usb stick (USB 3.0) and when i install the linuxcnc it gave errors (like the password for the wifi did not work or it refuse to install grub loader, so i use another usb and it works like charm).
  • PCW
  • PCW's Avatar
29 Nov 2025 09:58
Replied by PCW on topic 7i84u probably toasted
As I mentioned in our email communications, the 3.3V power supply may be shorted out
by the damaged chip (there may be more than one unfortunately). So if that is cleared,
communications may work. Also as I mentioned, damage to the I/O section of the 7I84U
is unlikely to propagate to the serial interface side as that is galvanically isolated (2KV!)
from the I/O side.
  • mooser
  • mooser
29 Nov 2025 09:58 - 29 Nov 2025 11:04
You might check if there is 3.3V (measure from W1 pin 1 to 3, pin 1 should ++3.3V)
Lack  of 3.3V may mean damaged 3.3V regulator or shorted part.
M
Displaying 10726 - 10740 out of 11230 results.
Time to create page: 0.345 seconds
