08 Nov 2025 14:37
Replied by tommylight on topic problem with homing
problem with homing
Category: Basic Configuration
I have a problem with homing in the lcnc sim.
You say that and go on to show actual hardware pins, so are you using a simulation or real hardware?
  • fsabbatini
  • fsabbatini
08 Nov 2025 14:05 - 08 Nov 2025 14:07
Emco retroffit + added subspindle + bar loader
Category: Show Your Stuff
Hi everyone!
This machine was an old emco, retroffite with new electronics, designed and built a subspindle where tailstock was and designed a cnc bar loader for 6meters longs bar.
As you can see in the videos, the spindle and subspindle rotates simultanseously for cutting the part off
Video
Hope you like it and have a nice weekend!
  • Hakan
  • Hakan
08 Nov 2025 13:46 - 08 Nov 2025 13:46
MonoKrom - QtPyVCP GUI for PlasmaC and Mill
Category: QtPyVCP
Yes, trixie uses python3.13. I guess it would be fine in bookworm with 3.11.
It turned out the tool_db issue was just a setting in xyz.ini. The tool program is in /usr/bin.
I have played around a bit and yes it looks very very nice.
The material handling looks awesome.
So I'll turn it into a real machine, for my plasma cutter.
  • CaliusOptimus
  • CaliusOptimus
08 Nov 2025 12:13
Replied by CaliusOptimus on topic Lathe project needs a turret
Category: Turning
What a neat little turret! Cool company too, I've got one of their booster pumps.
That turret is too small unfortunately. Will be taking some decent cuts on this lathe so I ordered a tormach turret. Pricey, but those guys are so great with tech support... one call and they were willing to explain all of the electrical details I needed to integrate it.
  • Aciera
  • Aciera's Avatar
08 Nov 2025 11:11
Replied by Aciera on topic MonoKrom - QtPyVCP GUI for PlasmaC and Mill
Category: QtPyVCP
the 'imp' module has been removed in python 3.12
  • Philip Lydin
  • Philip Lydin
08 Nov 2025 10:56
Replied by Philip Lydin on topic Subroutine error
Subroutine error
This line in the ini was the problem "TOOL_CHANGE_POSITION = 0 0 410". My z limit is 300....
  • djdock99
  • djdock99
08 Nov 2025 10:11
Replied by djdock99 on topic Maho mh800w retrofit
Category: Milling Machines
It’s been 9months since I got near this project. But back at it again.
I’ve been working my way through pnc config and inputting all the axis info from the manuals and finally starting to wire up the mesa boards.
Big thanks to the feral engineer on YouTube with his Linux cnc bare bones series as this helped me understand what data needs to go where..
Linear scales are now connected up and reading in the correct directions.
I have finally decided on what way to wire each axis and name each axis. I’m sticking to the original Maho horizontal spindle configuration with the y axis moving the table up and down. This way in the future trouble shooting in the future will be less confusing as everything will match the original manuals.
Once if got as far as I can with pnc configuration I’ll make a second configuration for the vertical spindle which I will use the most.
  • karlhe
  • karlhe
08 Nov 2025 09:43
Replied by karlhe on topic booten dauert lange 1min 30 sek , alles ok
Hallo tommy ,
vielen Dank, das hat funktioniert....
karlhe
  • Hakan
  • Hakan
08 Nov 2025 09:18 - 08 Nov 2025 10:17
Category: QtPyVCP
At least got it up and running.
1. Had to replace "import imp" in  /usr/lib/python3/dist-packages/qtpyvcp/app/application.py
with "import importlib.util"
and on line 159
        #module = imp.load_source('python_vcp', pyfile)
        spec = importlib.util.spec_from_file_location('python_vcp', pyfile)
        module = importlib.util.module_from_spec(spec)
        spec.loader.exec_module(module)
This comes from the python3-qtpyvcp apt package.
Is it qtpyvcp to blame or trixie that doesn't provide the imp module?
2. Missing [PLASMAC]SLAT_TOP in ini file. Added
SLAT_TOP=0.0 in PLASMAC section.
I guess it could be given a default value as is done for so many variables when they are missing.
3. Locale problems. <string>:1: SyntaxWarning: invalid decimal literal
Started linuxcnc with
debian@plasma$ LC_ALL=C linuxcnc xyz.ini
and it gives me a Monokrom screen.
Edit.
The LC_ALL=C wasn't needed.
But this one needs attention:
Note: Using POSIX realtime
!!!!db_init: </home/james/dev/venv/bin/plasma_tooldbpipe> not executable
emc/task/taskclass.cc 169: can't initialize DB_PROGRAM.
emc/task/taskclass.cc 188: can't load tool table.
  • Sandro
  • Sandro
08 Nov 2025 07:59
Replied by Sandro on topic MonoKrom - QtPyVCP GUI for PlasmaC and Mill
Category: QtPyVCP
Yes I forgot to mention this. I have tested with the Plasamac postprocessor as well (the one I normally use with my QtPlasmac setup) with the same result. It works, if I deactivate the plasma_gcode_preprocessor in the Filter section of the INI but then I can obviously not use any of the advanced Monokrom features like hole detection.
  • rodw
  • rodw's Avatar
08 Nov 2025 06:36
Replied by rodw on topic USB activity causes network error
Category: Plasmac
Try this command and review results when complete
sudo chrt 99 ping -i .001 -c 600000 -q 10.10.10.10
The max reading is usually the first entry as it connects so look at average and standard deviation.
  • rodw
  • rodw's Avatar
08 Nov 2025 06:17
Help with Wireless Handwheel XHC-WHB04B-6 (wrong Product ID)
@Rod,
We can not edit your youtube videos on your youtube studio! :)
how is the html code for grin?
That's quite an old video now. There are more reasons  in 2.10  to grin :)
In  2.10 there is a change to how Deb files are built by doing it the Debian way which installs all the dependencies for you. It is described in the building linuxcnc docs for 2.10. I do remember testing it prerelease and it was sooo simple,,, except for building the docs.
  • hanz24
  • hanz24
08 Nov 2025 06:09
problem with homing was created by hanz24
problem with homing
I have a problem with homing in the lcnc sim. First, i jog the axis xz and then try to home all axis, and it's works. But when i try to do that again, its only homing for the x axis, and z axis didn't go to the home coordinate. Already check the ini file and it's all same with x and z axis, what can i do to solve this.
And i also want to try to jog a-axis with external push button, is this hal configuration enough to do that
setp halui.axis.a.jog-speed 100
net jog-a-plus-raw debounce.0.0.in <= hm2_7i98.0.gpio.001.in_not
net jog-a-plus debounce.0.0.out => halui.axis.a.plus
net jog-a-minus-raw debounce.0.1.in <= hm2_7i98.0.gpio.005.in_not
net jog-a-minus debounce.0.1.out => halui.axis.a.minus
  • rodw
  • rodw's Avatar
08 Nov 2025 06:07
Category: QtPyVCP
there should be a specific post processor for Plasmac shipped with Sheetcam (before QTplasmac) Try it and read the file as there are notes at the top.
@Tommy, line numbers in linuxcnc are optional and Sheetcam has settings to generate with and without.
  • rodw
  • rodw's Avatar
08 Nov 2025 06:02
Replied by rodw on topic New and Working RTAI debs for 2.9
Category: Installing LinuxCNC
If you use 2.10, there are some changes to make it easier by doing it the Debian way (to a Deb file). The Debian way installs all the required dependencies so check the 2.10 Docs. Otherwise there is a how to video on my MrRodW YouTube channel
Displaying 11311 - 11325 out of 12800 results.
Time to create page: 0.409 seconds
