  • Todd Zuercher
  • Todd Zuercher's Avatar
07 Nov 2025 10:48 - 07 Nov 2025 10:49
Replied by Todd Zuercher on topic Delta Servo ASD-B2,
Delta Servo ASD-B2,
I'm afraid we really don't have enough information to help you.
We have to assume that the new drive isn't configured the same as your old one. Are both the new and old drives the same model and version? (There are different models of Delta Servos that are the same size and look simular, but the motors from an older one are not compatible with a newer drive or vice versa.)
Do you have a back up of all of the parameters from the old drive? Assuming that your new drive is the same model as the old one, you would need to load the parameter settings from the old one to the new one in order for it to behave as before. If you don't have either a software backup of the parameters, or written down paper copy of the parameter settings, then you will have to figure out what they need to be. We can't really help you with that though unless you tell us how the motor/drivev is mis behaving.
  • hermann1976
  • hermann1976's Avatar
07 Nov 2025 09:12
Replied by hermann1976 on topic Tipps für aktuelle LinuxCNC Hardware gesucht
Category: Deutsch
Hi Gartenzwerg,
ich habe deinen Post leider zu spät gelesen. Ich hätte noch einen Tipp für ein passendes Mainboard:
Asrock-n100dc-itx   inkl. CPU   -  und Parallel Header
Ich setze das bei meinem CNC Umbau einer Langlochbohrmaschine (Zinkenfräse) ein und macht einen guten Job. (Latenzen um die 8000), nur verwende ich nicht den Par. Port sondern über Lan.
Nur weil ich neugierig bin - von wo bist du im Osten Ö? : ich komme aus dem 3 Länder Eck: Stmk - Bgld - NÖ
lg
  • Hakan
  • Hakan
07 Nov 2025 07:26 - 07 Nov 2025 07:49
Help with Inovance IS620N Servo Drive - Stays in PREOP
Category: EtherCAT
Yes more info is needed. I think you had that type of problem before, endian?
There is one setting. After reading through the esi file I see there is only DC sync supported, no async or sm sync.
Add this line to the xml file after the     <slave idx="0" line
      <dcConf assignActivate="300" sync0Cycle="*1" sync0Shift="0"/>
Edit. You already have that. It's early...
  • rodw
  • rodw's Avatar
07 Nov 2025 06:26
Replied by rodw on topic Ethercat HAL driver
Ethercat HAL driver
Category: EtherCAT
I think Intel is now promoting PREEMPT_RT and have their own optimized RT kernel so the linuxcnc/ethercat stuff is just a tutorial for their users...
  • laurentl38
  • laurentl38
07 Nov 2025 06:16
Diameter tool probing with toolsetter, basic probe
Category: QtPyVCP
Thanks for the documentation and this details, I'll read it carefully.
As for G-code, I'll have to delve deeper into it; for now, I'm far from mastering it.
  • emresensoy
  • emresensoy
07 Nov 2025 06:02
Replied by emresensoy on topic Fiatech exhibition - 9 axis ethercat setup
Category: Show Your Stuff
I put a simple stepper motor in the last row to show visitors that it can drive Ethercat motors along with stepper /dir motors.
YOu can find detailed information at;
www.egerobotics.com/ethercat-dig32-io-interface
www.egerobotics.com/ethercat-digital-analog-io-board
www.egerobotics.com/ethercat-encoder-interface
www.egerobotics.com/ethercat-pwm-rc-servo-interface
  • endian
  • endian's Avatar
07 Nov 2025 05:11
Category: EtherCAT
try
ethercat debug 1
then
sudo dmesg | egrep EtherCAT
show current config
ethercat pdos
  • deltafox24
  • deltafox24
07 Nov 2025 04:33
Replied by deltafox24 on topic Rotary axis in Qtdragon_hd
Category: Qtvcp
Doesn't anyone use a rotary axis anymore, and does no one know what the problem might be?
  • Lcvette
  • Lcvette's Avatar
07 Nov 2025 04:01
Replied by Lcvette on topic Changing colors in Probe Basic
Category: QtPyVCP
Not really, it's codes in Python in the vtk, and any updates will over write your edits.
  • Lcvette
  • Lcvette's Avatar
07 Nov 2025 03:59
Category: QtPyVCP
Because there are different methods to measure diameter and different toolsetter types, it's a very per situation basis. You just need to write in the macro code for it. There is allot of previously functionality for it already in basic. Start by reading the rs274ngc code documents and looking over the existing subroutines for probing. It's really not too difficult if you have a decent gcode understanding. Nothing like writing program python for example.
The manual is short, look at the section reviewing subroutines. I have attached it for your reference. Also view the linuxcnc docs section regarding owords.
This browser does not support PDFs. Please download the PDF to view it: Download PDF
06 Nov 2025 23:39
Can't reverse after homing on 5-axis parallel breakout
Category: Basic Configuration
Thanks, chips are being made as we speak. And I am feeling more comfortable now it is working again (it is amazing how edgy having bits of the workshop broken makes me feel.
You are welcomed, and i am glad.
As for edgy, have you seen my shops? I am edgy all the time, one of them is organized chaos:
The other is in much better condition:
  • daveansell2
  • daveansell2
06 Nov 2025 23:22 - 06 Nov 2025 23:23
  • tar_san
  • tar_san
06 Nov 2025 23:12
How to set current encoder pos to current position while homing by Driver.
Category: EtherCAT
Thanks. I'm almost solving this problem and finalize my project. After that, I'm planning to share my "Lichuan-EtherCAT" project .
06 Nov 2025 22:26
... that's a day I won't get again.
Yes, but you did learn something, so not wasted.
Report back when making chips. :)
Displaying 11356 - 11370 out of 12835 results.
Time to create page: 2.158 seconds
