  • Lcvette
  • Lcvette's Avatar
19 Oct 2025 23:03
Replied by Lcvette on topic increment 4 MPG jog wheels with Basic Probe
Category: QtPyVCP
That's a much easier method! Glad you got it sorted out!
  • Lcvette
  • Lcvette's Avatar
19 Oct 2025 23:02
New Probe Basic install - error during install.
Category: QtPyVCP
Glad you got it sorted, I will add this to the docs for the next release
  • sconisbee
  • sconisbee
19 Oct 2025 20:36
Feed per rev G95 way too fast was created by sconisbee
Category: Basic Configuration
Hi, Sorry, please bear with me, I'm new here and relatively new to LinuxCNC.I've been converting an old Boxford 240 TCL to LinuxCNC running on a Pi5.
Everything is running fine(ish) there are still some glitches and errors that crop up and the odd latency warning too (stepping is done on an EC300 running remora so I'm not so worried about the latency warning).
However... i've gotten to the point of testing, and for some reason in G95 and feeding at 0.1mm/rev the axis runs at way faster rate, 10x maybe more.Anyone have any idea what is going on?  The only other thing to note is that I am having issues with LinuxCNC seeing my index pulse, but it is seeing the count from the single encoder (100 slot disk with a second slotted opto switch for index so not quadrature).
I'm assuming that its possible the feed issue could be linked to that.
The other issue I am having is when i run a program, it won't run through automatically.  The only way it will run is by me hitting the single step through button.  I'm wondering if that is linked to the encoder also as perhaps LinuxCNC isn't seeing "at speed" so isn't letting the program run?
hal and ini attached.  Please forgive the messy files, once they are running right I'm planning on cleaning them up.
  • sconisbee
  • sconisbee
19 Oct 2025 20:13
Replied by sconisbee on topic Remora - ethernet NVEM / EC300 / EC500 cnc board
Good Evening,
I'm relatively new to LinuxCNC having come from Mach 3 on mills previously.  Having found mach3 limited for lathes I have moved over to LinuxCNC.  I have been/have converted an old Boxford 240 TCL to run on new steppers, and LinuxCNC running on a Pi5 connected to an ec300 running the remora firmware.
Everything in general is working fine, except the spindle encoder.  Annoyingly, it is not a quadrature encoder.  It is a 100ppr slotted disk with an additional index pulse.  Currently, this is feeding directly into the Pi5, which is reading the 100ppr but missing the index.
So, my plan is to move the encoder and index over to the ec300.  While i understand that the ec300 has a dedicated index input, I am unsure on using an encoder with remora.  I've read the docs, and have run through this thread but my head is spinning trying to get things straight.
Does the EC300 have the ability for a hardware encoder?  if not, software would work too, I'm just not sure how to set up the encoder component as I do not have a B phase.
On the hardware side, I'm going to have to work out some electronics as the encoder as it stands is running on 3.3v with schmitt triggers for conditioning.  So I will have to come up with something to level shift this to 24v.
Any help that could be given on the remora side of things would be greatly appreciated.
  • clayton2ndtry
  • clayton2ndtry
19 Oct 2025 20:09
Replied by clayton2ndtry on topic burning iso to USB drive
9660. The DVD drive fails BIOS diagnostics. Spindle error. I am ordering a replacement drive. In the meantime, I used a USB DVD drive. The 2.9.2 disk would not boot. But an ancient disk from Sherline called EMC2 did boot and install from that USB DVD drive. This is so ancient that Update Manager does not work. I put 2.9.4 on the DVD. While trying to install, it complained about unmounting media failing. I suspect 2.9.4 ISO lacks the smarts to handle a USB DVD drive. I have successfully installed 2.7.14 before so that is next.
  • Sandro
  • Sandro
19 Oct 2025 19:53
Replied by Sandro on topic MonoKrom - QtPyVCP GUI for PlasmaC and Mill
Category: QtPyVCP
Hello everyone
After seeing your video (looks really great by the way), I wanted to check out MonoKrom as well. However, following the instructions on the QtPyVCP repo, I fail at the step of installing MonoKrom itself. The apt source seems not be available anymore.
www.qtpyvcp.com/install/apt_install.html
$ sudo apt install python3-monokrom
Greetings Sandro
  • ihavenofish
  • ihavenofish
19 Oct 2025 19:46
Replied by ihavenofish on topic Mini wannabe datron build
Category: CNC Machines
Progress. I cut the end frames down from the old machine so chips don't build up at the ends of the rails. this lets me reduce the safety margins and I get about 310mm y travel now. Also made a new top plate for the Z which increases clearance 10mm, and ups the travel to 112mm. Much smaller than the new version, but we don't have that yet sooo :P
19 Oct 2025 18:21
Replied by tommylight on topic Any progress on QTLazerC or
Category: Other User Interfaces
Since no one stepped in, i do recall that discussion but not the end result.
I did refrain from posting there as i still vigorously maintain that capacitive sensing has no business near a plasma machine, as proven by a quick glance at new industrial machines.
I did remove plenty of fully functioning capacitive sensors from industrial plasma machines and replaced with float switch. It never fails.
19 Oct 2025 18:12
Replied by tommylight on topic burning iso to USB drive
What model of OptiPlex ?
  • DavidR8
  • DavidR8
19 Oct 2025 17:39 - 19 Oct 2025 22:31
Category: QtPyVCP
Working on fixing the broken install.
I wasn't able to do that previously because I was not the root user. Some google sorted me out there.
I'm pleased to report that I have successfully installed Probe Basic!
This is a huge win for me because Linux and LinuxCNC have been my nemesis since I first tried using it in 2021 when I built my PrintNC router. I gave up because I simply did not know what I was doing. Four years on, and three CNC build later I have a modicum of a clue now.
Each of the posts in the thread represent more learning for me and your help has well, helped me get to where I wanted to be.
Thanks all!
  • Lcvette
  • Lcvette's Avatar
19 Oct 2025 17:32
Category: QtPyVCP
just for clarification, in Linux with any program when installing in terminal, if dependencies are missing they will cause an installation error, you need to read the terminal after each command to verify if the installation was successful or if there was a complication that needs to be addressed, it will give you any clues as to what is wrong very clearly.  so in your example, there are missing dependencies as shown in the terminal boxed in red outline.  the solution is to immediately run after that installation command the following command shows in red text.  that should resolve and then the previous installation will continue automatically and complete.  now if you ignored any of the dependency errors in previous installation lines for linuxcnc, hiyapyco, qtpyvcp, you would need to go back and rerun those in the correct order from the docs and running the dependency fix directly after each.  the order is important because each item is a dependency of the previously installed component.
linuxcnc > hiyapyco > qtpyvcp > probe-basic
  • DavidR8
  • DavidR8
19 Oct 2025 16:52
Category: QtPyVCP
Just machine control. I'll try the apt install.
  • PCW
  • PCW's Avatar
19 Oct 2025 16:19
hm2_modbus, mesa modbus, vfd modbus, mesambccc - example configs/intro?
No that references Mesa Modbus and several userland modbus interfaces
that use kernel serial port/USB serial port drivers.
  • Lcvette
  • Lcvette's Avatar
19 Oct 2025 16:12 - 19 Oct 2025 16:15
Category: QtPyVCP
When you see errors like the missing dependency shown in the top line of your screen shot, those are what stop the installation from proceeding. While installing, if you encounter those, you can auto install them by running:
sudo apt --fix-broken install
which will gather all of the missing dependencies on your system and install them.
  • robh
  • robh
19 Oct 2025 16:12
Displaying 12481 - 12495 out of 12889 results.
Time to create page: 0.885 seconds
