  • PCW
  • PCW's Avatar
25 Sep 2025 20:14
Going from Devian 10 to 12 has created problems
Here's a script for 6.17-rc1-rt1 that works for me on Mint 22.1
There may well be different dependencies on your system
File Name: makert6.17...-rt1.zip
File Size:0 KB
unzip, chmod +x  then sudo
And yes, Debian does seem to have a talent for making awful RT kernels
  • rodw
  • rodw's Avatar
25 Sep 2025 20:06
(Solved) Initialization code for a rintelligent ECT60 fails when run on an ECR60
Category: Driver Boards
6077 is actual torque which probably can't be read without encoders so delete it. Not sure about 60fe, I never used it.
I would get the docs from rtelligent for both drives. there isn't really much difference between the ECT and ECR aside from some I/O and encoders.
Sometimes you need to reset to factory defaults as covered in the docs.
  • RotarySMP
  • RotarySMP's Avatar
25 Sep 2025 19:55
Replied by RotarySMP on topic Lathe Macros
Lathe Macros
Category: Other User Interfaces
I worked it out, by playing around with adding an M5 to the end of Chamfer. It rereads it each time, so I didn't need to restart LCNC.
  • rodw
  • rodw's Avatar
25 Sep 2025 19:46
Ooops, I got that wrong go for kernel 6.16
  • rodw
  • rodw's Avatar
25 Sep 2025 19:36
It's more of a kernel/driver issue than hardware/Linux Distribution issue.
I think the world has got more complex and there are standards like energy efficient Ethernet (EEE) that the kernel has to support today in this world of power conservation. they all add up.rtt min/avg/max/mdev = 0.100/0.114/26.854/0.321 ms, pipe 2 As you say it is sometimes slow. This can be affected by the initial ping when its connecting but it can be EEE kicking in. Check the doc for how to disable that. (I am not convinced that it is still disabled by default.
One of the issues here is that there is no RT ethernet drivers. Ethercat gets around this by writing their own drivers but for the most part now depends on the generic ethercat driver which is not real time which they say is mostly good enough (except for some realtek).
The only other trick which has worked with 2 core PC's in the past is to compile the kernel yourself because Debian seems to make some odd choices in their kernel version. If you go down this path, I would download the 6.1.17 kernel source and the matching 6.1.17 RT patch. I would do this to build a Deb on another PC with more cores or it will take you many hours/ even days. Perhaps PCW can provide some guidance on the necessary steps. Unfortunately, I have lost my scripts....
  • RotarySMP
25 Sep 2025 19:35
Lathe Macros
Hi Andy,
Are the macros reread from the drive each time they run, or loaded once at start up?
The reason I ask, is I need to change the G76 Q value to 4.5° to cut my Schaublin collet draw tube buttress thread, and was wondering if I can just edit it with LinuxCNC active, or whether I should shut down, edit, and then restart?
Have you considered making flank angle a data entry box on the Macro page?
Cheers,
Mark
  • PCW
  • PCW's Avatar
25 Sep 2025 19:30 - 25 Sep 2025 21:53
Stepper Motor Speed does not match MaxVel
Category: Basic Configuration
The velocity units for linear axis are in inches per second, not revolutions per second
If the linear velocity is not correct, its likely the the step scale does not match the hardware
(hardware meaning the ball screw pitch, step drive microstep ratio, any intermediate gear/belt reductions etc.)
The velocity units for rotary axis are in degrees per second.
Note that latency will have no real affect on scaling unless its
so bad that you get stalling (which would be obvious)
  • richcolvin
  • richcolvin's Avatar
25 Sep 2025 19:04
Stepper Motor Speed does not match MaxVel was created by richcolvin
I am finding that
  1. the stepper motors for the two spindles work as expected, however
  2. the stepper motors for the axes (B, U, V, X, &, & Z) run at a VERY slow speed.
The latency test on my Raspberry Pi 5 gave:
  • Servo Thread
    • Max Interval = 1,013,089nS
    • Max Jitter = 13,089nS
  • Base Thread
    • Max Interval = 46,407nS
    • Max Jitter = 24,074nS
I ran the Step Timing Calculator to set the BASE_PERIOD based on using StepperOnline DM542T drivers.
  • Step Length = 2.5µS
  • Step Space = 2.5µS
  • Direction Setup = 5µS
  • Direction Hold = 5µS
The recommended BASE_PERIOD = 26.57µS.
When I run LinuxCNC based on this configuration, the value for the parameter, hm2_yi92.0.stepgen.02.maxvel = 1.
Regardless, the stepper motor does NOT run at 1 rev / sec.
Attached are the HAL, INI, and include files for
  • Spindle0 (Spindle1 is the same)
  • Axis X (axes Y, Z, B, U, & V are the same)
The X Axis is set as Joint 0, Channel 02.
Help would be GREATLY appreciated!
Thank you and kind regards,
Rich
  • PCW
  • PCW's Avatar
25 Sep 2025 18:44
What does my script do?
(sudo is a bit funny with some command lines)
  • bentiggin
  • bentiggin
25 Sep 2025 18:42
Replied by bentiggin on topic Hypertherm hsd130 interface
Category: Plasma & Laser
I realize my questions probably don't make much sense so attached are some pics of how I think I should wire it, bypassing the old "phc interface."
I don't want to use the "phc interface" because I would have to make some assumptions about how it was wired.
For example, can I assume the 12v on the on the "phc interface" break out is actually 24v since the hypertherm hsd130 doesn't have 12v?
Do the wire colors correlate to the wire colors in the manual?
If I take the time to verify this, why not just bypass the "phc interface" and go directly to the 37 pin connector that I have documentation for.
  • endian
  • endian's Avatar
25 Sep 2025 18:28 - 25 Sep 2025 18:32
Beckhoff AX5YZZ internal probing was created by endian
Category: EtherCAT
Hello folks...
have anybody working configuration with custom data telegrams of SM pdos which include internal SoE probing objects? I think internal probing in generally over the SoE parameters and S-0-0169, S-0-0170 IDNs ...
@chimeno, @db1981 has some working stuff but I can not see any custom modification of the SMs ifself...
Thanks and regards
  • peterpan
  • peterpan
25 Sep 2025 18:23
Replied by peterpan on topic Trouble with Cia402 drive configuration
Category: EtherCAT
After adding the rest of the pdo entries on pg 9 and 10 the drive still stays in PREOP
<masters>
  <master idx="0" appTimePeriod="1000000" refClockSyncCycles="5">
    <slave idx="0" type="EK1100" />
    <slave idx="1" type="EL1008" />
    <slave idx="2" type="EL2008" />
    <slave idx="3" type="generic" vid="0x00000c96" pid="0x00000001" configPdos="true">
      <dcConf assignActivate="300" sync0Cycle="*1" sync0Shift="700000" />
      <syncManager idx="2" dir="out">
            <pdo idx="1600">
               <pdoEntry idx="6040" subIdx="00" bitLen="16" halPin="cia-controlword" halType="u32" />
               <pdoEntry idx="6060" subIdx="00" bitLen="8" halPin="opmode" halType="s32" />
               <pdoEntry idx="6071" subIdx="00" bitLen="16" halPin="target-torque" halType="s32" />
               <pdoEntry idx="607A" subIdx="00" bitLen="32" halPin="target-position" halType="s32" />
               <pdoEntry idx="60FE" subIdx="00" bitLen="32" halPin="digital-outputs" halType="u32" />
               <pdoEntry idx="60FF" subIdx="00" bitLen="32" halPin="target-velocity" halType="s32" />
            </pdo>
         </syncManager>
         <syncManager idx="3" dir="in">
            <pdo idx="1a00">
  <pdoEntry idx="603F" subIdx="00" bitLen="16" halPin="error-code" halType="u32" />
               <pdoEntry idx="6041" subIdx="00" bitLen="16" halPin="cia-statusword" halType="u32" />
               <pdoEntry idx="6061" subIdx="00" bitLen="8" halPin="opmode-display" halType="s32" />
               <pdoEntry idx="6064" subIdx="00" bitLen="32" halPin="actual-position" halType="s32" />
               <pdoEntry idx="606C" subIdx="00" bitLen="32" halPin="actual-velocity" halType="s32" />
               <pdoEntry idx="6077" subIdx="00" bitLen="32" halPin="actual-torque" halType="s32" />
               <pdoEntry idx="60F4" subIdx="00" bitLen="32" halPin="follow-error" halType="s32" />
               <pdoEntry idx="60FD" subIdx="00" bitLen="32" halPin="digital-inputs" halType="u32" />
            </pdo>
         </syncManager>
      </slave>
  </master>
</masters>
The dmesg:
[100592.236726] EtherCAT DEBUG 0-3: 9936 ns difference after 400 ms.
[100592.236728] EtherCAT DEBUG 0-3:    ref_time=812139542737448000
[100592.236729] EtherCAT DEBUG 0-3:    app_time=812139546509016167
[100592.236730] EtherCAT DEBUG 0-3:  start_time=812139546609016167
[100592.236731] EtherCAT DEBUG 0-3:       cycle=1000000
[100592.236732] EtherCAT DEBUG 0-3:  shift_time=700000
[100592.236733] EtherCAT DEBUG 0-3:   remainder=568167
[100592.236734] EtherCAT DEBUG 0-3:        start=812139546610148000
[100592.236735] EtherCAT DEBUG 0-3: Setting DC cyclic operation start time to 812139546610148000.
[100592.238726] EtherCAT DEBUG 0-3: Setting DC AssignActivate to 0x0300.
[100592.241726] EtherCAT ERROR 0-3: Failed to set SAFEOP state, slave refused state change (PREOP + ERROR).
[100592.242726] EtherCAT ERROR 0-3: AL status message 0x001E: "Invalid input configuration".
[100592.244725] EtherCAT 0-3: Acknowledged state PREOP.
[100592.465795] EtherCAT WARNING 0: 1 datagram UNMATCHED!
[100592.489802] EtherCAT WARNING: Datagram 0000000070b69bf8 (master-fsm) was SKIPPED 1 time.
  • kb58
  • kb58
25 Sep 2025 18:22 - 25 Sep 2025 19:27
First post, so be gentle - also, if this is in the wrong sub-forum, feel free to move it.
Back story: I'm building a wire EDM machine based upon Mike Bax's BX18 arc generator. He supplies modified LinuxCNC code, including initialization code for the stepper drivers. It's nearly done but I've run up against a problem with the drivers.
The problem: Mike wrote code for the ECT60 (closed loop driver) version, configuring it to run open-loop steppers. Silly me thought that since they're open loop steppers, there was no reason to spend the extra money on the ECT model, so I bought the ECR (open loop) model. Unfortunately, they're apparently different enough that the ECR gets stuck in the "Pre-Operation" phase during initialization, and neither Mike nor I can figure out why.
We both looked through the XML .ini code and we can't find anything that would cause it to fail. What's a bit concerning however, is that the online manuals are missing at least two sections regarding registers 0x60FE, and 0x6077. It makes me wonder if perhaps more information is missing that could explain why this isn't working.
Obviously the "easy button" is to replace the ECR units with ECT units. I would gladly do so if I had a use for the ECRs, but I do not. Throwing another $200 at this project is a bitter pill - plus I'm stubborn - and I would like to figure this out instead.
Anyone have any ideas?
Note: This is my first interaction with both LinuxCNC (or any form of Linux) and XML, making it much more challenging.
Thanks!
  • jcbryant
  • jcbryant
25 Sep 2025 17:27
For what I want to do, the script boils down to
echo 2 > /proc/irq/29/smp-affinity
I've tried this and it doesn't work. I get "permission denied" (whether or not I use sudo), presumably because folder irq don't exist. And even if I were to create folder irq, and create a folder 29 within it, I can't see how just creating a file is going to change anything. Something has to use the file, and in this case I think that that something is irqbalance, which as I've mentioned doesn't exist and can't be made to exist.
  • PCW
  • PCW's Avatar
25 Sep 2025 17:07
You might try this script to pin the Ethernet interrupt to the last CPU
File Name: pinirq_202...25-2.txt
File Size:1 KB
chmod +x pinirq.txt
sudo ./pinirq.txt enp1s0
(might also be enp1)
Displaying 13216 - 13230 out of 13393 results.
Time to create page: 6.086 seconds
