  • tivoi
  • tivoi's Avatar
28 Jun 2025 04:33
used spindle atc iso20 d80 4kw 40krpm, int shipping
Category: User Exchange
899usd for spindle + 6 tool holder
if you want vfd and accessories please contact me
This email address is being protected from spambots. You need JavaScript enabled to view it.
  • MrTejuino
  • MrTejuino
28 Jun 2025 02:37
Setting a Scara was created by MrTejuino
Setting a Scara
I am trying to set a scara robot with a remora card, conected by ethernet, i can made to can work with the 4 motors that i need but when i try to put the scarakins. the joints work quite well,but when i home it i cannot move the axis on x and z. and i dont have any idea why this is happening.
  • cakeslob
  • cakeslob
28 Jun 2025 01:51
Axis view options are not persistant between sessions. Any thoughts?
Category: AXIS
yeah that should be the only option he needs in the INI file, the one in [TRAJ] LINEAR UNITS
the ai shit up your ini file. you need to fix these sections. I dont know what angular inch U axis is or a linear spindle.
#*** AXIS_U *******************************
[AXIS_U]
UNITS = INCH
MAX_VELOCITY = 7
MAX_ACCELERATION = 20
MIN_LIMIT = -500
MAX_LIMIT = 500.0
[JOINT_3]
TYPE = ANGULAR
UNITS = INCH
HOME = 0.0
MIN_LIMIT = -500
MAX_LIMIT = 500.0
MAX_VELOCITY = 7
FERROR = 1000
MIN_FERROR = 1000
HOME_ABSOLUTE_ENCODER = 1
#*** SPINDLE *******************************
[AXIS_B]
MAX_VELOCITY = 25.0
MAX_ACCELERATION = 750.0
MIN_LIMIT = -200.0
MAX_LIMIT = 200.0
[JOINT_4]
TYPE = LINEAR
HOME = 0.0
MIN_LIMIT = -200.0
MAX_LIMIT = 200.0
MAX_VELOCITY = 25.0
FERROR = 1000
MIN_FERROR = 1000
  • COFHAL
  • COFHAL
28 Jun 2025 00:48
Does it include the speed controller or just the spindle?
  • tar_san
  • tar_san
27 Jun 2025 22:39
Replied by tar_san on topic Problems with Lichuan Ethercat servo drive
Category: EtherCAT
I succeeded LC10E driver homing with incremental encoder + origin, limit switch with my own homing codes.
  • irwinger
  • irwinger
27 Jun 2025 22:08
Replaced Hard drive - now my 'fast move' (SHIFT->arrow |PgUp/PgDn is not working
I added HOME_FINAL_VELOCITY to the AXIS_X / JOINT_0 section(s). I set it to match the value for the HOME_SEARCH_VEL and HOME_LATCH_VEL. I also increased the HOME_OFFSET to -.500000 to make sure there was some visible movement. Nothing changed - it locked up trying to move the axis.
Here is that section of the INI file - in case any of the other entries look odd.
#*** AXIS_X *******************************
[AXIS_X]
MAX_VELOCITY = 1.0
MAX_ACCELERATION = 30.0
MIN_LIMIT = -0.01
MAX_LIMIT = 8.0
[JOINT_0]
TYPE = LINEAR
HOME = 0.0
MIN_LIMIT = -0.01
MAX_LIMIT = 8.0
MAX_VELOCITY = 1.0
STEPGEN_MAXACCEL = 37.5
SCALE = 8000.0
FERROR = 0.05
MIN_FERROR = 0.01
HOME_OFFSET = -.500000
HOME_SEARCH_VEL = -0.050000
HOME_LATCH_VEL = -0.050000
HOME_FINAL_VELOCITY = -0.050000
HOME_IGNORE_LIMITS = YES
27 Jun 2025 21:44
Replied by tommylight on topic Blow back plasma torch start timing problem
Category: Plasma & Laser
Should be done in CAM, not in LinuxCNC.
Seems strange to do that on every cut, although i had a Hypertherm that would need a bit of a pause only on short cuts, but 3 sec. max. so i added that to Inkscape.
27 Jun 2025 21:40
Set the HOME_FINAL_VELOCITY to something smaller.
If they are not in the ini file, add them for each joint.
  • irwinger
  • irwinger
27 Jun 2025 21:32
I'm not sure if you were asking me to upload a video to YouTube showing what is happening - but that's what I did. The video link is here:
youtube.com/shorts/D5WTf5WWpfo
It's very hard to 'see' or hear - but as part of the homing function, the axis slowly approaches the limit switch, then moves away, then back and finally 'jumps' away from the switch.
I tried changing the MAX_ACCELERATION setting in the .INI - in both the AXIS_X and JOINT_0 sections. I halved them but it made no difference. I also attempted to move the sliders at the bottom of the LinuxCNC screen (below the jog section) way down one at a time - but that made now changes.
If I try to run even a simple shape (gcode for a small rectangle) it just 'locks up' like you see in the video when I attempt to press the 'SHIFT-(any arrow).
I'm just buffalo'd - I cannot figure it out.
Arden
  • pscott
  • pscott
27 Jun 2025 19:42
Hi All,
I am in the process of converting our workshop homebuilt plasma table from MACH3 to LinuxCNC.
So far all the basic things work except for the plasma torch timing. The particular torch & inverter we have
needs a minimum of 15 second delay from the end of one cut to the start of the next. In MACH3 we have a
M3 macro that takes care of that. Is there a feature in QtPlasmaC / plasmac that can do something similar.?
I can do it using the retry logic - but that usually wastes a lot of time between cuts.
Scott.
  • atrex77
  • atrex77's Avatar
27 Jun 2025 19:41
W5100S-EVB-PICO stepgenerator and encoder driver
Category: Driver Boards
The expansion board is "plan to sell it" but the prototypes is in making, so its need more time.
  • lex200
  • lex200
27 Jun 2025 17:44
Issue with Inverse Kinematics Failing During Homing – 3-Axis Robot with LinuxCNC
Category: HAL
Well, you were right. I had to use the modified parameters in the DH method.
  • cmorley
  • cmorley
27 Jun 2025 16:08
[qt_dragon_hd] auto tool probe and gcode display issue
Category: Qtvcp
What version of linuxcnc are you using?
Can you post your config files?
  • Aciera
  • Aciera's Avatar
27 Jun 2025 15:02 - 27 Jun 2025 18:04
Replied by Aciera on topic Referenzierungs Fehler
Category: Deutsch
Nein, bei der Y achse ist die HOME_SEARCH_VELOCITY negativ:
HOME_OFFSET = 0.000000
HOME_SEARCH_VEL = -5.000000
HOME_LATCH_VEL = -0.500000
HOME_FINAL_VEL = 2.000000
Das Problem mit den Limiten wird aber erst sichtbar werden, wenn die Achsen erfolgreich referenziert sind.
Für das eigenliche Referenzieren ist wichtig, dass 'joint.n.home-sw-in' False ist wenn der Referenzschalter nicht aktiviert ist.
Displaying 14521 - 14535 out of 15150 results.
Time to create page: 2.386 seconds
