  • tcbmetalworks
  • tcbmetalworks
14 Apr 2025 18:00
Replied by tcbmetalworks on topic 10.5 x 25 cnc plasma table retrofit
Okay so here is what I'm thinking of buying.
www.aliexpress.us/item/3256808075045002....798396400003024786_1
For a set of 3 1000w motors it came out to being around $1000 usd shipped with gear reducers. I think 1000w might be a little large and I may go down to 750w. Do you think it's worth it to go absolute vs increment? They also asked about communication step dir vs "communication" I think they mean some sort of ethercat sort of deal. Waiting to here back from the salesman to clarify
I did alot of research last night and found the gear rack i have is 16 pitch with i belive a 20 dp I will still have the deal of a metric shaft to a imperial pinion size. But I'm not too concerned I can machine it out and proably hand file or even broach the keyway out.
  • spumco
  • spumco
14 Apr 2025 17:46
Need help making rotary axis behave like second spindle
Caxis.comp is not in the official LCNC distribution, so there isn't going to be any documentation beyond forum posts.
It was authored by Andy Pugh a few years ago while he was working with another forum member who was trying to get his DIY lathe sorted out.  The lathe was configured to use the same motor for spindle work as well as c-axis positioning for a live tool.
I wound up in the same boat when I started my lathe project and stumbled across Andy's post where he uploaded caxis.comp. I shamelessly grabbed it and spent quite a bit of time trying to use it and get things sorted out.  The forum is littered with my ramblings & whining over the past year or so.
If you don't mind re-starting LCNC for spindle-mode, then creating two configurations should be pretty easy.
Do you need two spindles at the same time?  Like a router bit spinning in main spindle, and 4th axis-spindle turning as well?
Is the config you attached in the original post working well for you now and you just want some help creating a 2nd config for spindle work?
  • PCW
  • PCW's Avatar
14 Apr 2025 17:36
Replied by PCW on topic Problem with THC
Problem with THC
Category: Plasmac
The THCAD2 is scaled the same as a THCAD-10 when jumpered
for 10V full scale and scaled the same as a THCAD-5 when jumpered
for 5V full scale.
  • claytoncramer
  • claytoncramer
14 Apr 2025 17:27
Replied by claytoncramer on topic Engraving Fonts
Engraving Fonts
Category: Milling Machines
I am unable to figure out how to use the engraver-1 python program. If I try python engraver-1.py I get:
File "engraver-1.py", line 1
SyntaxError: invalid syntax
I am running it as downloaded:
python engrave-1,py
  • notJamesLee
  • notJamesLee
14 Apr 2025 16:37
Replied by notJamesLee on topic Determining Angular Scale - Help w/ Microsteps
Category: Configuration Tools
before i do this, should i modify the 'steps per revolution' in the arduino code?
For the capacitor, are we just trying to smooth the input?
  • mariusl
  • mariusl's Avatar
14 Apr 2025 16:35
Replied by mariusl on topic Problem with THC
Problem with THC
Category: Plasmac
That makes sense. Thanks. I always use the "Autovolts" option and has always been good enough but in this case there are complications that I have to catch so the manual calibration is required.
  • notJamesLee
  • notJamesLee
14 Apr 2025 16:08
I currently have it on my test bench with a DC power supply set at 24v. Depending on what is doing it typically is drawing around 0.25A. if i turn the current knobs on the power supply it doesnt increase at all.
I have the switch on the driver set to D which according to the data sheet is 2.8 peak or 2 RMS which is alot more than its pulling. Should i switch this to 0-4 according to the datasheet thats about where my current draw is.
I just tried plugging 625 into the arduino code (its not on the machine yet) and its about 1.125 spins.
  • grijalvap
  • grijalvap's Avatar
14 Apr 2025 16:03
Replied by grijalvap on topic Problem with THC
Problem with THC
Category: Plasmac
this is the process I followed to set up a hyperterm 85 SYNC
1 Make sure the Z axis is properly calibrated including trabvel switch if any.
2 Make sure table is properly laveled, so the plate to cut is always perpendicular to the torch
2 From hyperterm Cut tables select a metal plate in the midle range of the plasma power supply and set up the parameters in the proper tool.
3 Disable any THC feature including THC itself.
5 Cut a line of a length that allow you to record the voltage on the screen (May be 8 or 10 inches long), using the previusly ste tool.
6 Adjust the voltage scale to reflect the voltage in the cut table for that cut heigh.
You can repeat with a thicknes on the high range and then one in the low range and then make an average.
this method has worked to me don't need to many maths but for sure should be anothers that work.
  • Lampje
  • Lampje
  • notJamesLee
  • notJamesLee
14 Apr 2025 15:26 - 14 Apr 2025 15:27
Hi Friends,
- yes its a hybrid stepper, sorry for the misnomer, i've attached the data sheet of the motor and the drive.
I am using a GT2 timing belt and timing pulleys i got off amazon. The pulley ratio expressed as a fraction is 37.49/11.99. I just realized i should probably use the number of teeth instead which brings that fraction to 60/20 or 3, but this still doesnt get me to the 540 number any easier. How would one measure the pulley ratio with the actual belt?
I was hoping that the belt system i designed wouldn't slip THAT much. I only have it rotating one way, as belts are good pullers not so good when it comes to pushing. I mean i even have a custom tensioner in there. I can upload cad photos if necessary.
So because i took the head off to redesign it i haven't put it back up on the machine and reset up the drive, all the numbers i am sharing are coming from the little Arduino script i wrote to test this.
  • RotarySMP
  • RotarySMP's Avatar
14 Apr 2025 15:15
Replied by RotarySMP on topic Plausiblty check on feedrates
Thanks, Andy also made that suggestion. You are right, I am kind of used to thinking in G94. Need to reprogram my brain.
  • Lampje
  • Lampje
14 Apr 2025 15:14 - 14 Apr 2025 15:22
Mill setup troubles and questions (Speed display, at speed signal, coolant pump)
So i finally have the tool probe and workpoint figured out (i think*).
Running the code i got from Inventor CAM, with the default LinuxCNC post I run into issues.
I attached the Z-probe and workpiece subroutines as well as the Inventor cam generated code.
It stops on the T1 M6 line (N25). But i can't seem to get it to go beyond that. Pressing the start/pause on the HB04 doesn't do a thing.
Commenting out this line moves the program up to line N60 and throws up error messages about the Z-axis running out (it wants to go to high).
To me it looks like the code has a different idea of where the tool tip is (in Z) than what it gets set at with the Z-probe routine.
Work order:
{The z-probe / toolsetter is fixed to the bed}
Mount the probe. (that's the XYZ probe)
Run the Z-probe to set it's tip.
manually move the spindle/probe to within the bounds of the workpiece probe routine. (The vice for now)
Run the workpiece probe routine (finally got it to set it's coords correctly and it moves perfectly above the corner.)
Then i manually move the spinde to a comfortable place to change out the probe for the tool (round paper lollypop stick for now).
I placed a piece of plastic on the tool probe to create extra Z offset for initial safety so the lollypop stick doesn't plunge into the workpiece (the vice).
Then i load the 19.091 cgode file and "press play".
It moves from the probe XY to a place that is NOT the coords of line N55
Then it runs line N60 and error's out on a Z-axis out of bounds. 13mm above the workpiece is well withing that actual range of my machine with the tool probed as is with the extra spacer. I checked this with the spacer on the vice and the tool touching it (simulating the tool touching Z0 on the workpiece /G54. And then move up 13mm and then i still have plenty of headroom before I run into the Z home/limit switch.
So the 2 issues:
Getting past the M6 on line N25
Correctly using the tool length (?).
* probing the workpiece often fails when i comment out the message and M0 commands, claiming the probe is in contact during rapid movement. Adding the M0 'pause' solves that. But that is not how things should be.
Also, i would like to be able to position the probe during the routine
lines:
(MSG, Plaats probe boven werkstuk\n Hou de probe ong. 5mm binnen de hoek\n en druk daarna op start)
M0                        ; Wacht op bevestiging
The M0 hold doesn't allow moving the spindle about.
  • fsabbatini
  • fsabbatini
14 Apr 2025 15:04
run Linuxcnc on xenomai with EVL(the realtime core)
Linuxcnc works for xenomai 3 only as it is posix based (basically same code but linked to xenomai libraries instead of standard libc libraries)
Xenomai EVL, on the other hand, is not posix based and a wrapper for threads, mutex, etc should be coded
Regards
  • theslawek
  • theslawek
14 Apr 2025 14:41
Hi Spumco,
I can't find any official documentation about caxis.comp, just many forum posts about it from you. Is this something new not in the documentation yet?
My goal is to make my CNC router use the rotary axis and simulate a lathe. I've actually already done this before moving to my Mesa 7i76e but using an external device with a dial ( amazon link ) to control the speed. I'd like to have that programatic control over the speed for obvious reasons. I actually have a YouTube video on what I did then.
I don't need dynamic change between velocity and position controls. I'm more than happy to restart LinuxCNC with new config when changing operations.
  • Beovoxo
  • Beovoxo
14 Apr 2025 14:36
Replied by Beovoxo on topic Deckel FP4A Retrofit
Used keyboard matrix controller for bottoms on the controller cabinet.
I disassemble a old keyboard and salvage the controller. the connection points has to be cleaned before soldering wires on it. "the black stuff" on the contact points are graphite with normal traces under.
Displaying 16666 - 16680 out of 17624 results.
Time to create page: 0.656 seconds
