  • jochen91
  • jochen91
11 Apr 2025 15:03
Planning to Retrofit a Mazak Integrex200Y Mill-Turn Machine
Excuse my crude model of the Integrex, but could someone tell me if my axis naming is correct for a lathe configuration?
And how is the axis called with the "?". Of Course for a Mill configuration it would change. Would be happy for input :)
  • matti.juntunen
  • matti.juntunen
11 Apr 2025 15:00
Z level compensation was created by matti.juntunen
Hi all!
I have been trying to get a Z compensation thingy working for a while.
github.com/scottalford75/LinuxCNC-3D-Pri.../master/compensation
I have gotten the script working, in the way that it is incorporated in LinuxCNC, and it reads my probe data, sorta. I have two problems with it.
First problem: It doesnt read negative coordinates in X and Y. It only understands lower left corner being zero in the gcode. Which is a problem, since my machine zero is in center of worktable, and i make all my gcode with zero in center. I have worked like that for ages, and i dont feel like changing my workflow.
Second problem: The outputed coordinates only work from machine zero. It doesnt follow if i have a work offset active.
Has anyone had the same problems? This is over my skill level, and i cant get it to work.
I am attaching a number of files. Compensation.py is the script i am using now. probe-results.txt has only positive coordinates and works. probe-results2.txt has both negative and positive, and does not work. Or, it works for a while if i only move in positive area, but after a while the whole compensation just dies and i have to restart LinuxCNC. Z_level_compensation.py is a file i found in another thread here, that i believe morley(?) has modified. It is based on the script i am currently using, but it looks like work offset has been fixed. I have not gotten this script to work on my system, but maybe someone can tell me how to fix my problems based on that.
  • andypugh
  • andypugh's Avatar
11 Apr 2025 14:56
Replied by andypugh on topic rotary axis queston
rotary axis queston
Usually omitting or deleting lines with HOME_...._velocity in the ini file and editing the homing and limit lines in hal is all it takes,
It's usual to retain the lines, but set the two velocities to zero. Omitting probably works too (they will default to zero) but actively setting to zero looks less like a mistake.
  • andypugh
  • andypugh's Avatar
11 Apr 2025 14:53
Replied by andypugh on topic Strange behaviour of custom component
I have not using any kind of global variables
I think you are, look at line 159:
enum MODE_SELECTION{WRITEMODE, WAITVELOMODE, INITIAL, WORKING, WAITINGFORENABLE, HOMING};
static enum MODE_SELECTION mode_selection;
mode_selection is a static global in the code.
I don't know for sure if that is enough to cause the problem?
it looks like mode_selection should be a local variable (actually, make it a parameter so that you can debug using it)
Also maybe consider using a "switch" command on mode_selection rather than repeated "if (mode_selection == ##) "
  • andypugh
  • andypugh's Avatar
11 Apr 2025 14:25 - 11 Apr 2025 14:26
Replied by andypugh on topic How to build a CNC Router?
Category: Milling Machines
 because I might have damaged a drive or two without beeing aware of the importance of the wiring.
A cage-clamp terminal done up nice and tight with the cable not actually inside the clamp is a popular way to blow up a drive. Give the wires a good tug after tightening the clamps.
  • andypugh
  • andypugh's Avatar
11 Apr 2025 14:23
Replied by andypugh on topic Rf45 clone glow up.
Rf45 clone glow up.
How's the rigidity of the harmonic drive?
It seems OK. The HD website quotes values for torsional stiffness, but to be honest I don't know what value would be appropriate for a milling machine, so the numbers aren't useful to me.
But I frequently use it just as a handy way to mount round stock and have noticed no issues.
  • PCW
  • PCW's Avatar
11 Apr 2025 14:19 - 11 Apr 2025 14:19
Replied by PCW on topic VHD Header Help
VHD Header Help
Category: Driver Boards
Here's an example:
File Name: 7i76e_7i76...9x1d.zip
File Size:160 KB
It's a bit tricky because you do need to use muxed encoders for all
encoders (because the 7I89 uses physically muxed encoders)
  • andypugh
  • andypugh's Avatar
11 Apr 2025 14:18
  • endian
  • endian's Avatar
11 Apr 2025 14:16
Replied by endian on topic Strange behaviour of custom component
Probably .hal and .comp which is overflowing
Excuse me for mess in the component but it is in the working session ...
I am sorry
I will enumerate all hard code and
Is has behaviour as I described higher ... I am confused and I have feeling like something in the working session is mixing together but no way to find it out...
Please let me know what I am doing wrong
thanks
regards E..
  • andypugh
  • andypugh's Avatar
11 Apr 2025 14:09
Replied by andypugh on topic 3D Scanners Who Has Used Them?
Category: Additive Manufacturing
My experience is limited, but typicaly getting from a scan to a usable model is the hard part. I would ask for a demo with a sample component and be sure it goes all the way to the point that you expet to use the scan.
  • jochen91
  • jochen91
11 Apr 2025 13:34 - 11 Apr 2025 13:34
Thank you that's a good idea, by coincidence i already started making myself familiar with vismach, cause i really don't wanna crash the machine. I try to start as soon as possible an make a crude 3D model of the machine to import it into vismach. But i still need to figure out how to do the virtual Y axis compound move. I think i need to paint a picture of the axis configuration of the machine to post it here. Cause i have a few questions in regards of the axis/joint names.
  • andypugh
  • andypugh's Avatar
11 Apr 2025 13:18
Marco Reps clone - not enabling drives was created by andypugh
Category: EtherCAT
I spent a few hours yesterday evening in the workshop of a user who has duplicated the Marco Reps controller configuration, with an Rpi5 and Leadshine EL8 (as detailed here: github.com/marcoreps/linuxcnc_leadshine_EL8
The cia402 component is seeing an enable signal, and the cia-controlword into lcec is setting to 6. But nothing seems to be happening in the drives, and there is no position feedback when turning a motor shaft.
cia402.opmode is showing zero, and that leads me to think that stat_voltage_enabled is zero
  if (stat_voltage_enabled && !home ) {
    opmode = OPMODE_CYCLIC_POSITION;
So possibly no data is being seen from the drives?
 stat_voltage_enabled   = (statusword >> 4) & 1;
command-line ethercat commands list 7 devices (all in pre-op) and the lcec component also lists 7 devices, so _some_ comms is happpening.
It feels like some sort of drive-enable isn't happening?
Any thoughts? I felt a bit foolish turning up as an "expert" and then being completely baffled. (first contact with EtherCAT)
  • JT
  • JT's Avatar
11 Apr 2025 13:15
Replied by JT on topic Flexible GUI
Flexible GUI
Category: Flex GUI
  • Fianna
  • Fianna's Avatar
11 Apr 2025 13:14 - 11 Apr 2025 15:58
VHD Header Help was created by Fianna
VHD Header Help
Hi All
My intent is to merge some vhd files to get a 7i76e + 7i78 + 7i89
I saw a post here (from PCW I believe) sayign the count in the 4th column was the number of those modules, so for the stepgens I want (6x or more) I've been putting x06, and same for the encoders (1x spindle + 6x on the DB25 headers), just increasing the built in Qcount. I believe I don't need muxed ones (I have single ended A/B/Z glass scales), finally I then make sure the total number of entries in the whole array was the same as the standard hostmot2 7i76e examples. No ide if this logic is sound or not...
(HM2DPLLTag,x"00",ClockLowTag, x"01",HM2DPLLBaseRateAddr&PadT,HM2DPLLNumRegs,x"00",HM2DPLLMPBitMask), (WatchDogTag,x"00",ClockLowTag, x"01",WatchDogTimeAddr&PadT, WatchDogNumRegs,x"00",WatchDogMPBitMask),
(IOPortTag,x"00",ClockLowTag, x"03",PortAddr&PadT,IOPortNumRegs,x"00",IOPortMPBitMask),
(QcountTa    x"02",   ClockLowTag,x"06",QcounterAddr&PadT,QCounterNumRegs,x"00",QCounterMPBitMask),
(StepGenTag,x"02",ClockLowTag, x"06", StepGenRateAddr&PadT,StepGenNumRegs,x"00",StepGenMPBitMask)
(MuxedQcountTag, MQCRev,ClockLowTag, x"01",MuxedQcounterAddr&PadT,MuxedQCounterNumRegs,x"00", MuxedQCounterMPBitMask),
(MuxedQCountSelTag, x"00",ClockLowTag, x"01", NullAddr&PadT,x"00",x"00",x"00000000"),
(SSerialTag,x"00",ClockLowTag,x"01",SSerialCommandAddr&PadT,SSerialNumRegs,x"10",SSerialMPBitMask),
(LEDTag,x"00",ClockLowTag,x"01",LEDAddr&PadT,LEDNumRegs,x"00",LEDMPBitMask),
(NullTag,x"00",NullTag,x"00",NullAddr&PadT,x"00",x"00",x"00000000"),
(NullTag, x"00", NullTag,x"00",NullAddr&PadT,x"00",
more null
more null
until I get to the same line number as the examples so same number of modules.
I think I've made a dud bit file and written it to my 7i76e at some stage, the first time I tried to write it, mesaflash did the erasing, got halfway through the writing "WWWW..." thing and the terminal just hung. Ctrl + C'd the terminal, and I think the 7i76e stopped responding.
I power cycled the card itself, and now mesaflash can see it and write known good bit files to it, but after I write new bit files and --reload, the --readhmid just returned "None" for all of the channels.
I've since power cycled a few times and it seems to be writing standard bitfiles again by some miracle.
Can someone explain the header logic or point me to an explanation?
Can I just keep changing the module count freely and the Xilinx tool will flag if it runs out of space?
If the Xilinx tool compiles it okay can I be confident it won't brick the board?
How do I know if it's in fallback or normal boot?
What do the other columns in the header do, do I need to set memory addresses where the modules start or block sizes or anything? I'm wondering if I could be increasing module count and then overflowing the following module or something.
Does the total number of modules in that array need to be correct / a specific number / does it matter?
I've skimmed the hostmot2 dataflow vhd file but fallen at the first hurdle:
-- decodes -- --    IDROM related signals
-- Extract the number of modules of each type from the ModuleID
constant StepGens: integer := NumberOfModules(TheModuleID,StepGenTag);
This line obviously reads that count but I can't see where NumberOfModules (function? attribute of the an object called "work"?) is defined so I'm lost. As you can tell I don't have a clue how this code works so I'm just a smidge lost :)
I've had PCW post a few bitfiles here for me, for which I'm eternally grateful, but I feel bad so I'd prefer to acutally understand what's going on and be able to do it myself (and pass the favour on if it's not potentially harmful to someone elses setup!)
Thanks,
Kealan
  • JT
  • JT's Avatar
11 Apr 2025 13:12
Flexible GUI
Category: Flex GUI
I even added LED's to the reload and save button if you want them you just have to add a Dynamic Property. Big thanks to Chris for helping me understand the LED's
Just edited the nc code file.
Just saved the file so it shows a reload is needed.
So much fun...
JT
Displaying 16876 - 16890 out of 17637 results.
Time to create page: 0.426 seconds
