  • TripleM
  • TripleM
15 Jul 2026 07:41
Recommended way to implement spindle enable conditions?
Category: HAL
Thanks for all the suggestions and ideas!
I will give it a try and see how it works out on my machine.
  • aaron
  • aaron
15 Jul 2026 07:31
Replied by aaron on topic Trixy Install problems
Thanks for all your replies.  However, I found the only way I could do the install was by downloading Debian, doing apt update, apt upgrade, and then installing LinuxCNC via Synaptic.  Worked a treat.
  • BigDogCNC
  • BigDogCNC
15 Jul 2026 07:16
Replied by BigDogCNC on topic Mitsubishi SSCNET
Mitsubishi SSCNET
Category: Installing LinuxCNC
Would you be willing to share any details of the protocol? Specifically for MDS-B? I'm trying to do the opposite of you, implement a device that emulates a MDS-B drive to a Meldas 600M control, and drive my custom built 4th axis from it.
  • vermilion
  • vermilion's Avatar
15 Jul 2026 02:53
Is possible to use RS485 to read a CMOS laser sensor?
Category: Driver Boards
Hola. I want to use a CMOS laser sensor with an RS485 interface and find out if it is possible to use the RS485 terminal on the 7i96s board to read the sensor values. My goal is to use the laser to measure height and move the Z-axis to a specific initial height on a plasma cutting machine. I consulted Gemini AI, and it indicated that I needed to flash new firmware to enable this function; consequently, I visited the Mesa website and downloaded the hostmot2 file for the 7i96s. Could someone confirm if that hostmot2 file allows me to use the 7i96s's RS485 port in the way I intend? Thank you very much .
  • PCW
  • PCW's Avatar
15 Jul 2026 00:20
Replied by PCW on topic I hate the 7i97T
I hate the 7i97T
Category: Configuration Tools
Input 8  (TB5 pin 1)  is
hm2_7i97.0.inmux.00.input-08
  • Onkelmat
  • Onkelmat's Avatar
14 Jul 2026 22:19
Replied by Onkelmat on topic I hate the 7i97T
I hate the 7i97T
You need to configure the network on the host for the Mesa card.
Also 192.168.1.121 is not suggested for LinuxCNC use as it's  in
a commonly used NAT range.
Suggested setup is to use the 10.10.10.10 address on the Mesa card
(via the IP address setup jumpers) and set  a static host address of
say 10.10.10.100/24.
At this point you should be able to ping the Mesa card:
ping 10.10.10.10
I found the problem I had the whole time but Linux didn´t point it out enough for me. Since the 7i97t is connected via ethernet i ran into more and more problems when I approached wiring up the machine and testing in and outputs. Today i started wiring the Lathe to the Mesacard and i didn´t get any MPG Handwheel feedback at all, a few seconds into starting Linuxcnc I´d run into queueing errors.
Little research pointed me to major network problems, causing the 7i97t to indicate a fault with CR7 red whenever i try to connect and hold connection.
I turned the checkbox "show notifications" in the network tab top right on and viola i got an error "disconnected". So i went with your suggestion and set the Jumpe on the card to eeprom default ip=10.10.10.10
still the same problem. For sure i changed my own IP to 10.10.10.100. Still the same. I changed the cable. Still the same. I tried a lot of thernet configurations.
In the end, the fix was: The subnet mask was set to "24" and not to "255.255.255.0". After fixing that the card connected right away and the network symbol stopped spinning. Since I´m not familiar with Linux, that spinning symbol gave me bad feelings but there is no Tooltip showing up, telling me what that icon actually means.
Now got already both MPG wheels hooked up. Somehow I cna´t find the TB5 IN8 pin in Halshow...
  • Odiug
  • Odiug
14 Jul 2026 19:49
qtDragon: Auto Return to Manual Mode After an MDI Command so MPG works
Category: Qtvcp
Hi Chris,
thanks for looking into it.
I am currently just running the normal 2.9.10 LinuxCNC. I guess it came with a version of QtDragon? I have to figure out first what's the best way to run the Master branch.
Can I check it out and use it parallel to the 2.9.10 version and be able to switch back and forth?
Guido
  • tuxcnc
  • tuxcnc
14 Jul 2026 18:37
Replied by tuxcnc on topic arcs in 4 axis mode
arcs in 4 axis mode
I have build foam cutter a few years ago and not remember details, but I think it was as follows:
There are two possibily configurations:
1. XY with master-slave axes - no cones, but you can use G2/G3.
2. XYUV independent axes - can cut cones, but can't use G2/G3.
When you use XYUV you must convert circles to strings of short lines in your CAD/CAM.
  • Todd Zuercher
  • Todd Zuercher's Avatar
14 Jul 2026 16:26 - 14 Jul 2026 16:26
Replied by Todd Zuercher on topic arcs in 4 axis mode
arcs in 4 axis mode
I've never worked with a wire foam cutter, but I have made some Linuxcnc configurations that can use some custom M-code commands that will temporarily slave two axis together such that one will move with the commands of the other. The machines I was using this on were routers with two spindles each mounted on their own axis and configured XYZW. I had ran these for years just using XYZW g-code, but when the multi-line look ahead planer was first introduced in Linuxcnc, it only supported XYZ moves, any moves with a W command reverted to the old single line tool planner, and significantly slowed the wood carving we did with these. So I built my config with an M-code that slaved the W axis to the Z at their current positions when the command was issued. The W would then follow the Z until I issued the M-code command that released the W. (This had to be done when Z and W were commanded to be at the same positions relative to the position they were slaved at, or the W would give a following error.) Maybe this technique could be useful for you? Here is a copy of one of my configurations.
File Name: TwinCNC.zip
File Size:93 KB
  • cmorley
  • cmorley
14 Jul 2026 15:38
  • tuxcnc
  • tuxcnc
14 Jul 2026 14:57
Replied by tuxcnc on topic Linux_Mint_22.1_LinuxCNC_2.10.iso
The first problem is Python.
Python is powerfull, but permanently developed, so python scripts are version sensitive.
LinuxCNC depends on Python...
Debian is conservative, Ubuntu is progressive, so there must be version mismatches.
Sometimes old programs not works with new OS, but worst is when works, but not properly, become unstable or some functionality gone....
Believe me, experiments like LinuxCNC+Ubuntu are not worth wasted time.
  • GeckoWorks
  • GeckoWorks
14 Jul 2026 14:42 - 14 Jul 2026 15:42
Replied by GeckoWorks on topic Control panel
Control panel
Category: Show Your Stuff
Mass - thanks so, so much!:)
This is sweet. I will dive deeper into it in the days to come and the project you linked to. But I am almost sure I will buy a (used) SK4/6 panel. I wouldn't be surprised if they all come with the PS/2 + matrix combo. (Some will possibly be USB+matrix but that would just be a win). I know, no guarentees - also in terms of pinout and such, but the main foundation is certainly there as you have shown. And most important, nothing locked behind a proprietary serial protocol either, it seems.
But any chance you could share the code, too?
Having looked at the github for the Arduino-LCNC project a bit, I now realize that the matrix never gets turned into USB-HID or gamepad protocol, at all. Interesting. Maybe a better more direct approach.
Not that I really know what I will be looking at but with the help of Gemini, I managed to make a nice custom version of the NanoELS FW (an open source electronic leadscrew project) for my little lathe. Had to get DRO scales implemented and add some other features - and I actually managed to do so on code level. So, hopefully the robots can help me on this project, too.
Various Panels
As for SK4/6 I actually think they share the same layout 100%. I think I have even seen some SK6s with SK4 printed on the PCBs - but I could be wrong as I have looked at sooo many pics lately.
But there's also an SK5 which does have a slightly different layout. (Attaching pics of SK4/5/6).
Most often SK4 has membrane buttons whereas the SK6 often has tactile ones. I am leaning towards the latter.
But looking at SK PCBs get confusing very fast as there are so many different itirations of the SK4/5 plus a bunch of clones.
Encoder Overrides?
BTW, it looks like you swapped out the clicky rotary switches for pots or encoders? So, no hardstops at each end but possibly better "sync" between screen and knob, is that it?
I think I will try to stay with the rotaries and see how they feel.
14 Jul 2026 13:53
Replied by tommylight on topic linking U axis to X
linking U axis to X
We (this forum) do not close or retire topics as some forums do, i have no clue why they do that as the only thing that does is cause chaos and makes the forum unusable with many instances of the same Q&A that mostly never conclude or solve anything.
14 Jul 2026 13:50
Replied by tommylight on topic Linux_Mint_22.1_LinuxCNC_2.10.iso
See what Tuxedo OS uses for touch, i am sure it worked on Mint also as i tested on a Lenovo X1 Yoga a while back, but do not recall what the package name was.
Displaying 1726 - 1740 out of 13507 results.
Time to create page: 0.332 seconds
