  • Sziggy_NC
  • Sziggy_NC
24 Feb 2025 16:16
Replied by Sziggy_NC on topic +-10v setup 7i97 & .ini
Cincinnati sabre 500. A simple 3 axis machine. The tool changer pivots on two hinges to swing the carousel under the spindle. It's resembles an arm bring a glass to a mouth.
  • Nathan40
  • Nathan40
24 Feb 2025 16:14
7i95t pin and firmware files with Stepgens and Inputs 5Axis BoB
Category: Driver Boards
Thanks for your file. Please confirm if it contains the input pins information for 5 Axis BOB.
If not, please add the same.
  • PCW
  • PCW's Avatar
24 Feb 2025 16:04
Which combination of mesa cards should I use?
If the resolvers connect to the drives (expected with AC servos) ,
a 7I49 is not needed (or useful)
  • PCW
  • PCW's Avatar
24 Feb 2025 16:00
Replied by PCW on topic Mesa 7I96S and Proximity Switches
Yes, assuming:
Black is out
Blue is ground = 24V common
Brown is +24V
  • PCW
  • PCW's Avatar
24 Feb 2025 15:53
7I95T firmware for 5ABOB but with added stepgen on pins 1,14
(so 12 total)
File Name: 7i95t_6ppst.zip
File Size:307 KB
24 Feb 2025 15:46
Replied by tommylight on topic Float precision for Ultra-Precision applications
Is there a way to change that to double precision floats (64bit) without having to rewrite the whole control?
This is his original question, that we did not answer, so he is right.
While waiting for someone that can answer that, you might want to have a look at the source code, it is on github:
github.com/LinuxCNC/linuxcnc
Also, these might or might not help:
forum.linuxcnc.org/38-general-linuxcnc-q...ming-milling-machine
forum.linuxcnc.org/38-general-linuxcnc-q...cision-home-switches
  • urvilsuthar
  • urvilsuthar
24 Feb 2025 15:29
Replied by urvilsuthar on topic Change acceleration on the fly?
Hello Rodw,
I tried offset concept with the current system, but at the end fallback to the same thing happening previously.
I have added the hal files and opratated the system, when start eoffset and changing the accelaration the accelaration changes only on Z axis level offset movement only, but this did not affect the possible speed variation on the other axis, can be increase or decreased.
also modified (attached) the eoffset hal file and xml file to set the acceleration dynamically but the reasult the small files get buffered in the queue by emctaskplan calls and the velocity/accel change commands never get executed, also shared the log file..
  • Dee436
  • Dee436
24 Feb 2025 15:01
QtPlasmac problems was created by Dee436
QtPlasmac problems
Category: Plasmac
I have been using a very old Plasmac version from 2019 and although I alway planned to upgrade it, it just worked so got put off. A month or so ago I turned on my plasma only to find the hard drive had failed. I fitted a new ssd and did a build of QtPlasmac with Debian 12 bookworm. Although I got the machine working as such, I have a couple of issues that I am stuck on;
Using the same PC I used previously without issue, I now regularly get errors like
“Mon24 13:59: Unexpected realtime delay on task 0 with period 1500000
This Message will only display once per session.
Run the Latency Test and resolve before continuing.
Mon24 13:59: hm2/hm2_7i76e.0: Watchdog has bit! (set the .has-bit pin to False to resume)
Mon24 13:59: hm2/hm2_7i76e.0: Smart Serial port 0: DoIt not cleared from previous servo thread. Servo thread rate probably too fast. This message will not be repeated, but the hm2_7i76e.0.sserial.0.fault-count pin will indicate if this is happening frequently.”
I have tried the period setting at 1000000, 1500000, 2000000 etc latency test is around 35000.
the other major issue is that I can’t cut anything that has an arc unless I use the QtPlasmac conversational. My sheetcam produced code just generates errors like
--- QtVCP Screen Started on: Mon, Feb 24 2025 13:12:29 ---
--- CNC_Plasma - QtPlasmaC v2.9-236.301, powered by QtVCP and LinuxCNC ---
Mon24 13:12: Tool 0: No Tool
Mon24 13:14: Loaded: /home/darren/linuxcnc/nc_files/examples/Darrens Gcode Files/Motor Moutn Blue Mill/10mm motor plate Arc Lead (SMM).ngc
Mon24 13:14: G-Code error in 10mm motor plate Arc Lead (SMM).ngc
Near line 42 of
/tmp/emcflt-m50pkakv.d/10mm motor plate Arc Lead (SMM).ngc
Radius to end of arc differs from radius to start: start=(X31.0695,Y19.2947) center=(X29.4735,Y20.3617) end=(X29.6980,Y20.4360) r1=1.9198 r2=0.2365 abs_err=1.683 rel_err=87.6824%
I have ensured G91.1 is active and all the holes entries are # out in the nc file.
Can anyone point me in the right direction? I can provide any extra info needed
  • Aciera
  • Aciera's Avatar
24 Feb 2025 14:59
Replied by Aciera on topic Change acceleration on the fly?
using the python interface for on the fly feedrate changes is a bad idea that is what the real time 'motion' pins are for:
linuxcnc.org/docs/html/man/man9/motion.9.html
  • PCW
  • PCW's Avatar
24 Feb 2025 14:56
Replied by PCW on topic 7I97T joint following error
Did you try with the drive disconnected?
That is measure TB3 pin 4 (AOUT0) relative to TB3 pin 3 (GND)
with the 4 pin connector unplugged.
  • Todd Zuercher
  • Todd Zuercher's Avatar
24 Feb 2025 14:47
Replied by Todd Zuercher on topic HAL trigger M code
HAL trigger M code
Category: HAL
I don't think you can change acceleration settings during operation. The problem is that changing acceleration messes with the calculations that the tool planner has to make.
I don't understand are you saying that changing the feed override does not slow the machine? Unless you are referring to the feed of rapid positioning moves (G0) which are not affected by the feed override settings.
  • Nathan40
  • Nathan40
24 Feb 2025 14:45
Please can anyone share 7i95t pin and firmware files with Stepgens on 1,2,3,4,5,6,7,8,9,14,16,17 and Inputs on pin 10, 11,12,13,15 pins on 5Axis BOB.
  • urvilsuthar
  • urvilsuthar
24 Feb 2025 14:25
I hope this message finds you well. the issue with my machine's feedrate and acceleration settings while using the Python module's feedrate function. Despite initially lowering the feedrate, I am still encountering problems where the machine achieve speed of 1500mm/min on short segments during 2D movements. This has led to some safety concerns, as the spindle has accidentally hit me on the head due to these high speeds.
To resolve this, I am trying to implement a feature where, upon pressing a push button, the machine would operate at just 10% of its maximum speed and adjust the acceleration to 10% of the set maximum acceleration, to tackle the 2D sort segment speed up very slow, with a hop i do not hit me again.
  • Hastrh2o
  • Hastrh2o
24 Feb 2025 14:12
Replied by Hastrh2o on topic Reading Barcode data
Category: AXIS
Forgot OpenCV, and use a barcode scanner.
I do this way to scan the worksheet and load the G-Code according to the type of part which I need to machine. The bar code scanner act as a keyboard, and I use a few python in the handler.py file to get what I need.
Displaying 18631 - 18645 out of 18777 results.
Time to create page: 0.428 seconds
