  • gardenweazel
  • gardenweazel's Avatar
27 Aug 2024 15:06
Replied by gardenweazel on topic QTDragon spindle raise issues
Category: Qtvcp
What about the other question that I had? Not sure if you noticed that?
"Do I need both lines 41 and 46?"
  • PCW
  • PCW's Avatar
27 Aug 2024 14:48
Replied by PCW on topic Error while Running Linuxcnc
Category: Driver Boards
The original error is a watchdog bite.
This means you have a latency issue
(or the watchdog timeout is set way too fast)
I would do a ping test:
ping -c 4 [card_ip_address]
sudo ping -c 30000 -i .001 -q [card_ip_address]
Where [card_ip_address] is the IP address of the 7I92 card
(probably 10.10.10.10 or 192.168.1.121)
The last command will take 30 seconds to complete
  • AndyDM01
  • AndyDM01
27 Aug 2024 14:32
Replied by AndyDM01 on topic Amplifier Fault ECT60 Closed Loop
Category: EtherCAT
how did you get the ECR moving in the first place? did you add the lcec_rtec.c to the lcec_main.c ? I'm a bit stuck and out of ideas
  • Aciera
  • Aciera's Avatar
27 Aug 2024 14:24 - 27 Aug 2024 14:26
Replied by Aciera on topic Compiling extra Kinematics
Category: Installing LinuxCNC
1. I can't really tell you as I generally use the newer .comp method for kinematics:
linuxcnc.org/docs/devel/html/motion/kine...erkins_comp_template
2. If I need to use the classic C file method I modify one of the built in kinematic files.
3. If I really wanted to figure it all out then I would look for an installed kinematic file (eg 'scarakins.c') and look where that pops up in the source code and copy the lines in the relevant files and replace 'scarakins.c' with my .c file (likely '/src/emc/kinematic/meson.build' and '/src/Makefile'):
  • jjdege
  • jjdege's Avatar
27 Aug 2024 14:18 - 27 Aug 2024 14:21
Replied by jjdege on topic what am I missing ? no movement!
Category: EtherCAT
I think in .hal there should be:
setp cia402.0.csp-mode 1
setp cia402.0.pos-scale 800
setp cia402.1.csp-mode 1
setp cia402.1.pos-scale 800
  • yathish
  • yathish
27 Aug 2024 14:15
Multiple external step generators like ESP32 (Individual ESP32 for every axis)
Hello community, I have tried github.com/jzolee/HAL2UDP, an external step generator: ESP32 for 3-axis in a single ESP32. But, I want to use individual ESP32 for individual motors to have extra I/O pins that can be used for other purposes.
See the image attached below for your understanding.
Please let me know if anyone has any idea.
Thankyou
  • scottlaird
  • scottlaird's Avatar
27 Aug 2024 14:11
Replied by scottlaird on topic problem with running ethercat
Category: EtherCAT
The problem with `ethercat slaves` is presumably because your kernel is running a different version of the EtherCAT code than the one that the `ethercat` command-line tool expects. If you'd recently installed an update without rebooting, then I'd expect to see the kernel version lower than the command-line version, but that's not what I see here. So that's kind of odd. The best fix would be to update and reboot. But...
IIRC they recently changed the keys for the OpenSUSE build server. I *think* the instructions in forum.linuxcnc.org/ethercat/45336-etherc...ep-by-step?start=290 should fix this. Try that, and if it runs successfully then reboot and see if everything works?
  • Aciera
  • Aciera's Avatar
27 Aug 2024 14:11
scarakins axis follow problem in -x and -y zone
2.9.3 is a branch inside the git tree that you cloned to your local machine. Default branch is 'master' ie currently 2.10.xx.
To compile 2.9.3 you need to switch to the '2.9' branch
git checkout 2.9
and then recompile
  • Masiwood123
  • Masiwood123's Avatar
27 Aug 2024 13:56
Replied by Masiwood123 on topic 7i96s + dcs100A
7i96s + dcs100A
I had to ask because I don't understand the core of electronics at all, my level is that I know how to connect the wires, set the pid and so on.. I thought that maybe by chance there is some limitation related to the 7i96s in terms of the digital signals it would give to this driver.
  • besriworld
  • besriworld
27 Aug 2024 13:49
Replied by besriworld on topic 7i96s + dcs100A
7i96s + dcs100A
Why do you think it won't be compatible? I don't see anything to worry about. You can just buy an extra board for the encoders and you will be able to close the loop in LinuxCNC
  • nartburg
  • nartburg
27 Aug 2024 13:46
Replied by nartburg on topic Compiling extra Kinematics
sry my question was ambigous.
I have already built linuxcnc to RIP
the question was how to put this extra kinematic into the build process so that it is recompiled linked and put in the right place with make
  • DPFlex
  • DPFlex
27 Aug 2024 13:42
Hi Aciera,
I could not do with halcompile, so I tried build from sources.
Building from source is faster than my expect. But it is LCNC version 2.10.xxx
I checked all branches on github, could not find stable version 2.9.3
Please advise. Thank you.
  • Todd Zuercher
  • Todd Zuercher's Avatar
27 Aug 2024 13:38
What's the Oddest Machine You Have Powered with LinuxCNC
Yes it is used/owned by a business (my employer). (Yes I get to "play" with Linuxcnc as part of my day-job.) We also have 3 other cnc routers here that I converted to running Linuxcnc. I would consider the machine's we have running Linuxcnc to be "light duty" and they are mainly used for carving and engraving, and they can do that much faster than our large heavy duty routers that we use for milling out parts. The big heavy machines, are mostly all Fanuc controlled.
The CAD/CAM software I use is called Enroute. It's a package geared more toward the woodworking/sign making industries. I also use FreeCAD a little to do some things that Enroute can't.
  • Masiwood123
27 Aug 2024 13:33
7i96s + dcs100A
yes, they work great on mach3, but linukcnc is safer for me because it won't ``continue working'' if something bad happens, even though these drivers have a certain encoder error tracking protection. maybe it's easiest for me to try, because I already have the 7i96s and the configuration on that earlier lathe, so let me try. I would be able to connect, what worried me the most was that maybe the frequency step/dir signals or whatever with the 7i96s are not compatible with this driver.
27 Aug 2024 13:21
Replied by tommylight on topic 7i96s + dcs100A
7i96s + dcs100A
I think in that case it will cost me the same as the combination of 7i96s+7i77.
See:
7i97T
7i92TM+7i77
7i92TM+7i85+7i83
Displaying 20266 - 20280 out of 26031 results.
Time to create page: 0.500 seconds
