  • abdulasis12
  • abdulasis12
26 Dec 2024 15:18
Skew correction/perpendicularity correction (millkins or millkins_xyz)
Category: Basic Configuration
Hi Aciera
I use this
$ git clone github.com/LinuxCNC/linuxcnc.git linuxcnc-source-dir
$ cd linuxcnc-source-dir/src
and I replace file trtfuncs.c  (inside skew func) on this step (correct right ?)
Then, cmd :
$ ./autogen.sh
$ ./configure --with-realtime=uspace
it's look good  and I use  cmd : $ make
it's loading and show in picture attach file  , this not complete compile right ?
Error :
/bin/bash: line 1: a2x: command not found
make: * [../docs/src/Submakefile:1001: ../docs/man/man1/5axisgui.1] Error 127
How to solve this problem ?
I think it's near succes with your help ^^"
Thank you,
Asis
  • tu_koper
  • tu_koper
26 Dec 2024 15:03
Hello everyone.I am very interested in control via Ethernet, and I became familiar with this method some time ago. However, I am encountering a problem. I am currently testing everything on just one stepper motor. My system is LinuxCNC version 2.9.3, which I use to control the EC500 controller (running on the RT-1052) via Ethernet.The EC500 already has firmware installed:
remora-rt1052-3.1.3.bin
and a JSON file:
ec500-rt1052-DMA.txt
. When I launch LinuxCNC, select the "remora-ec500" configuration, and then run the standard G-code file provided with LinuxCNC, the process starts, but the stepper motor does not turn.My EC500 controller is connected to the control output via an HBS86H driver, which controls the stepper motor. This setup is a closed-loop servo mechanism that operates autonomously (without the involvement of Remora or LinuxCNC). However, this configuration does not work when I load the
JSON file onto the EC500 and run LinuxCNC with the corresponding HAL file for DMA-based control.Interestingly, after changing the JSON file to
.../remora-rt1052-basic/ec500-rt1052.txt
and launching LinuxCNC with the appropriate HAL file for the BASIC version, the G-code program starts working, and the motor begins to rotate using the same unchanged hardware setup.I used the HALSHOW environment to monitor and compare changing pins and signals for both the DMA and BASIC configurations, but I couldn't identify anything significant for myself. It’s possible that I am missing something, which is why I am getting these results.Scott (or anyone else on this forum), could you spare some time and provide me with any insights or information that might help me move forward? Perhaps it's some small detail, like an enable signal or something similar, that might be causing the issue (even though I did see in HALSHOW that this signal appears to be the same for both configurations).Thank you in advance!
  • aikiaviator
  • aikiaviator
26 Dec 2024 14:55
Replied by aikiaviator on topic To Probe Basic from Gmoccapy
Category: QtPyVCP
Well not completely, I'm still just a baby on this stuff trying to get it functional. Will be on the learning curve for a long time I feel. I have not been able to get the Hole or Facing Conversationals going, which to me would be the next step. Once these are working I feel that it will be working well enough for me to understand some of the basics. I did complete some manual GCode instruction processing. So I know that aspect works. Just wanted to get the conversationals working as I can see these being invaluable when starting out.
On the ATC, I don't have one as yet, but am working towards creating one. The Mill being converted is a PM728VT. So Spindle control is available. I need to get to this once the machine is together. I am only bench testing atm. Still need to fit the ball screws etc.. yet.. The plan is to have the ATC will be managed via a pneumatic drawbar. Still trying to figure out best way on the tool change. Thought a set on the side of the table for pickup and drop off wud work best. A rotating one, although good is a little way off for me.
  • Lcvette
  • Lcvette's Avatar
26 Dec 2024 14:44
Mcode out of range, greater than 199 error
Category: G&M Codes
Is anyone else getting out of range mcode errors?  Getting these from time to time while tinkering in 5 axis switchkins builds on calls for the higher m codes.
  • Lcvette
  • Lcvette's Avatar
26 Dec 2024 14:40
Replied by Lcvette on topic To Probe Basic from Gmoccapy
Category: QtPyVCP
Great, glad you got it sorted!
The linuxcnc docs are a good place to start, they cover setting up the machine home and soft limits and cover G and M codes etc... All of the questions for the most part should be able to be answered there in the docs regarding configuration for basic machines.
What type spindle do you have on the machine? Does it have an ATC?
  • Lcvette
  • Lcvette's Avatar
26 Dec 2024 14:32
Replied by Lcvette on topic Rack Tool Changer
Rack Tool Changer
Category: QtPyVCP
I believe Conner has done this and it looks quite nice and function great, I will see if I can find his repo
  • Lcvette
  • Lcvette's Avatar
26 Dec 2024 14:27
Replied by Lcvette on topic probe_basic_lathe vtk_backplot.py error
Category: QtPyVCP
No worries, the lathe interface does need some TLC. I'm going to be running a clean install/update on my machine to see if I can reproduce, on my test pc I could not replicate the errors you reported so makes it difficult to track down where the issue was coming from. Will report back.
What is ELS?
  • JT
  • JT's Avatar
26 Dec 2024 14:08 - 26 Dec 2024 14:40
Replied by JT on topic Flex GUI Stylesheet Builder
Category: Flex GUI
The stylesheet builder now has QPushButton, QCheckBox, QRadioButton and QLabel.
JT
  • lkavan
  • lkavan
26 Dec 2024 12:49
Replied by lkavan on topic halviewer, go or no go?
Hallo friend,
nice project! I need to make something similar in C++, but I don't know how to get full tree of all HAL components, pins, etc. I have tried to analyse halshow.tcl script, but I am not able to understand it and transfer it to Qt C++
Can you help me how to do this?
Thanx a lot!
  • Blume
  • Blume
26 Dec 2024 10:37
Rack Tool Changer was created by Blume
Rack Tool Changer
Category: QtPyVCP
have anyone a Rack Tool Changer in Probe Basic included the UI ?
best regards
  • slowpoke
  • slowpoke
26 Dec 2024 10:01 - 26 Dec 2024 10:10
7i96S MPG input was created by slowpoke
7i96S MPG input
I'm anticipating reception of my 7196S card shortly. (The Canada Post strike is finally on hold)
This is for a lathe; I have a stepper (for now) mated to the Z-axis leadscrew, and a servo mated to the cross-slide
The Spindle encoder (A,B,Z signals) will interface to the fast encoder inputs on TB2:7,10,13
I plan to configure this so that the lathe can operate either in old fashioned manual mode, or in LinuxCNC mode. When in manual mode a separate ELS controller drives the Z-axis leadscrew, and because I have eliminated the hand crank for the cross-slide (it's now mated to a servo), I want to add a MPG to emulate the old cross-slide hand crank when I want to manipulate the cross-slide manually.
My question is about interfacing the 600 pulse/Rev rotary encoder intended for use as the cross-slide MPG. I have spare isolated inputs on TB3 that I would prefer to use because of the isolation. Manual states 5kHz max for these isolated inputs which seems fast enough, I can't imagine being able to rotate that knob 8 times in a second. So assuming the rate is okay, can I simply add a few lines to my HAL file to get a couple of those spare inputs to decode the A/B signals to get counts and direction from the encoder? or do I need to re-FLASH the FPGA on the 7196S?
  • iMaks-RS
  • iMaks-RS
26 Dec 2024 09:44
Replied by iMaks-RS on topic probe_basic_lathe vtk_backplot.py error
Category: QtPyVCP
rollback/downgrade to 2.8.4: install NativeCAM with Gmoccapy.
I hope that in the future I will be able to use the turning version. I would like to hope that it will also have built-in NativeCAM functionality (there is a problem now, because it does not work with python and glade version 3).
Yes, I ran the simulation and it had such errors. I am also not satisfied with ngcgui scripts and similar wizards. In my opinion, the most convenient for a "home craftsman" is either ELS + CNC. Or a CNC system that will allow you to replace ELS.
Thank you for your work and the time you devoted to the project. This is a really cool project. Unfortunately, all the projects I know are more focused on milling and the turning configuration is done on a residual principle. Perhaps I have a false picture of the world .. but this is exactly what I encountered.
(translated by Google translator)
  • Edi_48
  • Edi_48
26 Dec 2024 09:35
Fehler update was created by Edi_48
Fehler update
Category: Installing LinuxCNC
Hallo
Ich versuche nach einer Neuinstallation mit sudo apt update zu machen bekomme ich folgende Fehlermeldung
Das Depot »cdrom://[Debian GNU/Linux 12.8.0 _Bookworm_ - Official amd64 DVD Binary-1 with firmware 20241109-11:05] bookworm Release« enthält keine Release-Datei.
Ich habe von USB stick installiert
mfg
Hilton
  • ihavenofish
  • ihavenofish
26 Dec 2024 08:36
Replied by ihavenofish on topic Mini wannabe datron build
Category: CNC Machines
Yeah I need to find it and hope it was not ruined in the flood.
26 Dec 2024 07:56
Replied by tommylight on topic Mini wannabe datron build
7i84 would be the best solution.
A cheap BOB is also an option if the 26 pin header is free.
Displaying 21376 - 21390 out of 21693 results.
Time to create page: 0.381 seconds
