  • aikiaviator
  • aikiaviator
  • aikiaviator
  • aikiaviator
24 Dec 2024 00:23
Replied by aikiaviator on topic To Probe Basic from Gmoccapy
Category: QtPyVCP
Redone from Old gmoccapy and all working correctly. So will try from there.
  • PCW
  • PCW's Avatar
24 Dec 2024 00:16
7i96s Flash for additional PWM and Wiring for laser
Category: Driver Boards
I would not permanently enable the pwmgen with setp  but rather enable it by
connecting it to spindle-on as shown.
Inverting the PWM output and using the STEP- pin is needed because it guarantees that the
PWM pin is low before LinuxCNC is running, during power up, and after a fault (watchdog bite)
  • PCW
  • PCW's Avatar
24 Dec 2024 00:10
Replied by PCW on topic After homing move off of limit switch
Category: Basic Configuration
This is controlled by the homing parameter settings in the ini file:
linuxcnc.org/docs/html/config/ini-homing.html
  • Dave2024
  • Dave2024's Avatar
23 Dec 2024 23:34
After homing move off of limit switch was created by Dave2024
How’s it going.  So, I'm trying to make my mill use only one limit switch for both the minimum and maximum travel of the table.  Every time the machine is homed the table moves to the minimum hits the switch it then does a second shorter slower home cycle but then parks with the switch engaged.  How do I make it so after the last short slow home cycle it then parks so the switch is not engaged?  I need to have it parked off the switch so I can configure it to also serve as my max travel limit switch.  If I’m configured for the same limit switch to also be the max I can never move the table after it has been homed.
Which setting or file do I need to modify to make this functionality so lates say immediately after homed move slowly till the switch is disengaged?
  • SneakyGamer
  • SneakyGamer
23 Dec 2024 23:29 - 23 Dec 2024 23:30
Replied by SneakyGamer on topic 7i96s Flash for additional PWM and Wiring for laser
ooh ok thanks
yeah oversight, should be channel 1 if im using step/dir4
# Enable PWM generator on channel 1
setp hm2_7i96s.0.pwmgen.01.enable true
or do i not need this command if im replacing it with the invert
# invert pwm output
setp hm2_7i96s.0.pwmgen.01.out0.invert_output true
  • rodw
  • rodw's Avatar
23 Dec 2024 23:27
Minimal setup for touch probe and tool setter ?
to get the most out of qtdragon's tool handling, you need repeatable tooling and premeasured tools.
With Tormach TTS tooling, they sell a small granite plate
tormach.com/small-granite-surface-plate-...tool-hole-31713.html
And you use a height gauge to measure the height of your probe and your tools
en.wikipedia.org/wiki/Height_gauge
TTS can be used in R8 and MT3 spindles found on small machines, many people use at home.
This does work a treat when you have it all set up.
23 Dec 2024 23:18
Replied by Cant do this anymore bye all on topic How to build linuxcnc on buildroot?
There's no information that I can recall for cross compiling Linuxcnc.
When compiling Linuxcnc for the RPi platform (4/400 or 5) I've either done it natively or via QEMU.
For those that are unaware Buildroot is a cross compiling system for building Linux file systems, generally aimed at embedded systems.
  • rodw
  • rodw's Avatar
23 Dec 2024 23:11
How to build a spaceship with Linuxcnc and a Mesa 7i76e
I bet you just sold allot of Mesa 7i76e's with this video!  Cool, thanks
Nah, but perhaps PCW did!
  • Dave2024
  • Dave2024's Avatar
23 Dec 2024 23:09
  • jjdege
  • jjdege's Avatar
23 Dec 2024 23:07 - 23 Dec 2024 23:15
Ethercat installation from repositories - how to step by step
Category: EtherCAT
there is an error in the command
sudo apt install -y linux-headers-$(uname -r) ethercat-master linuxcnc-ethercat
try this, it doesn't give me any errors
  • scda
  • scda's Avatar
23 Dec 2024 23:00 - 24 Dec 2024 13:24
Problems with Lichuan Ethercat servo drive
Category: EtherCAT
Hi everyone
So I am also trying to setup an Ethercat drive (Stepper) from Lichuan CL3-E86H. These are my first steps with Ethercat, so far I only worked with MESA cards.
From reading through the thread Lichuan (servo) drives seem to be working now. Is this correct? Is it relevant which firmware the drive uses? (I got mine delivered two weeks ago). I have not yet checked the version.
I still get the PREOP + E message when starting Linuxcnc. Also have an EK1100 running on the same loop, which works fine. XML is from page 6 or 7 of this thread (which is supposed to work). I can clear the error by manually putting the drive into PREOP mode again.
Plugging in the cable won't work because LinuxCNC gives an error when the drive is not connected on startup.
The address settings on top of the drive does not seem to affect the address in the ethercat slave listing.
Dave
EDIT: So I was able to fix the problem by changing vendor ID to : 00000766 and PID to: 00011000.
  • MaHa
  • MaHa
23 Dec 2024 22:36
Replied by MaHa on topic Inconsistent values from Versaprobe
Category: Qtvcp
In the ini, under Versaprobe there is Diameter. Maybe you can add below HEIGHT = nnn and use it as #<_ini[VERSA_TOOLSETTER]HEIGHT>
It could look like this:
#<tool_length> = ABS[ABS[#<_ini[VERSA_TOOLSETTER]Z_REF>] - #<zworkoffset> + #<_ini[VERSA_TOOLSETTER]HEIGHT>]
  • gardenweazel
  • gardenweazel's Avatar
23 Dec 2024 22:20
Replied by gardenweazel on topic Inconsistent values from Versaprobe
Category: Qtvcp
I will measure this from Z0 to table top but, what's the VAR that I add it to?
  • MaHa
  • MaHa
23 Dec 2024 22:14
Category: Qtvcp
I just realized, there is something missing. You need to know the distance from   #<_ini[VERSA_TOOLSETTER]Z_REF>  (-183.97) to table surface. This must be added to toollength. Then you can work with table as base.
I think the toollength probing result you get now, is wrong by exactly this value.
Displaying 21526 - 21540 out of 21695 results.
Time to create page: 0.551 seconds
