  • cmorley
  • cmorley
21 Dec 2024 17:23
Replied by cmorley on topic G Code Syntax Check (Python + Qt Designer)
Category: Qtvcp
If you use a graphic display , the file is checked each time it is loaded.
Look here how that is actually done:
github.com/LinuxCNC/linuxcnc/blob/master...qt5_graphics.py#L350
  • PCW
  • PCW's Avatar
21 Dec 2024 17:23
Replied by PCW on topic Threading Index Varies With Speed
It's certainly supposed to be speed independent,
that is, the Z motion is supposed to be "geared" to the
spindle rotation.
(there's a video I can't find at the moment that shows
LinuxCNC threading while hand turning the spindle)
Possibly an encoder/index/Z axis issue?
  • jmelson
  • jmelson
21 Dec 2024 16:47
Replied by jmelson on topic Yaskawa encoder hack
Category: Driver Boards
It looks from the PC board that there are 12 outputs from the encoder.  A B quadrature, plus index (Z) and U V W commutation, and the differential complement of all of these.  That should be enough to run any industry standard servo drive.  AMC, Servo Dynamics, etc. have brushless drives that can take encoders like that.  Some don't need the UVW complements.
Fanuc had a different scheme for commutation on the older red cap version, the later ones are serial, so there is no ABZ signal at all.
Jon
  • CopperHead
  • CopperHead
21 Dec 2024 16:31
Replied by CopperHead on topic Slag on tight corners
Category: Plasmac
My Current max acceleration is set to 25. I'm not sure where i got that number from unless it was a carry over from my motor and driver settings in the old Mach 4. any suggestions as to what they should be . running NEMA 23 425oz motors and the Stepper Online DM542T Drivers. Don't remember my settings for the driver but I'm pretty sure i went conservative on them as I couldn't find the correct Drivers settings in Linuxcnc
21 Dec 2024 16:20
Replied by tommylight on topic Slag on tight corners
Category: Plasmac
Slow cut speed = plenty of hot slag = hard to clean
Happens due to limited acceleration of the machine as it has to slow down a lot on corners.
Try upping the acceleration for X and Y axis, it should help a lot if you can get the corner speed near the normal cut speed.
  • MrDe
  • MrDe
21 Dec 2024 16:00
Hey Scott,
Sorry to bug you again, but just wanted to let you know I finally managed to flash the firmware and ping 10.10.10.10! Next up is diving into the LinuxCNC side of things.
I’m planning to document everything I did to get it all working and might make a YouTube video showing the steps once my exams are out of the way next week. Also, I was thinking it’d be cool to contribute to the project documentation if there’s any way I can help out.
Thanks again for all your help – really appreciate it!
  • CopperHead
  • CopperHead
21 Dec 2024 15:36
Slag on tight corners was created by CopperHead
Category: Plasmac
Id like to reduce the amount of slag I'm getting on tight corners, I've searched the forum for settings on the THCAD2 and the 7i96s and really haven't found anything related to it. longer cuts and or curves come out perfect its just tight cutbacks it leaves a pile of slag. I'm cutting 12ga Steel and reduced my speed from 120 to 100 for the 12ga settings. So I'm not sure if I'm getting the height control locking at at the right time or its something else. my air quality is consistent and I run a refrigerated drier so I know my air is clean. I did change the Post processor to one of the Updated ones here called Plasmac local materials for setting the material from plasmac instead of sheetcam. it improved quite a few items during cuts. Maybe my motors and drivers aren't tuned correctly? open to anything to reduce the amount of cleanup I have to do after the cuts lol. and i might have left out some speciffics needed so ask away.
  • JR1050
  • JR1050's Avatar
21 Dec 2024 15:35
Yaskawa encoder hack was created by JR1050
  Hello there. I have a couple of mills with Yaskawa servo systems, mid 1990 BE series analog drives. They are junk, constantly blow up, very little info available, only support from Yaskawa, send us your life savings, in my case about $5 , so not enuff anyway.Using another brand of drive should be doable, the wrinkle here is Yaskawa’s unknown initial magnet sensing. The motors are sinisudialy communtated, sorry for the misspelling. The oldest ac yaz motors used what I suspect is a coded type hall sensing for initial trapezoidal communtation. The output signals were v,-v,u,-u,w,-w. , output from the encoder to the drive.The new motors have the markings on the encoder for the added signals, they are unused. I suspect the circuitry is there. Both encoders have on the glass disk , an inner ring of what I guess could be grey code. See pictures.Does anyone recognize this and have a hypothesis about how these signals would work? My guess is they are similar to the red cap Fanuc bldc signals. I have not put a scope on them
  • 10K
  • 10K's Avatar
21 Dec 2024 14:40
 I'm having an odd problem. I'm running a threading routine using G76. I thought that, while threading, I could change the spindle speed without affecting the operation. Everything seemed to be working fine until I starting threading something a little larger for me - a 1"-8. I started to see bad gouging off and on during the threading. that at times nearly stopped the (7HP) lathe. I was only taking off about 0.002" per pass for most of the operation. I thought something must be moving, and checked all the obvious things. Everything looked OK.
One of the things I tried was making a scratch pass at three different speeds, 100, 150 and 200 RPM. I ran the same program each time without changing the setup. You can see that the cut indexed to a different point for each speed. Conversely, if I ran it three times at the same speed, it would index to the same cut.
This is not good! It means if I cut a thread and then need to recut it, I need to make sure that the spindle speed is exactly the same or I'll get a different thread position. Needing to cut the thread again can be because the piece rotated in the chuck during the cut or I didn't set the tool X position deep enough. I'm also thinking that as the lathe slows down slightly, it might change the Y position of the tool incorrectly and cause the gouging.
Any ideas?
Two indexing signals to LinuxCNC: one pulse per revolution for indexing, and ten pulses per revolution for position
Spindle speed set manually, and not by LinuxCNC
LinuxCNC v2.9.3
  • vibram
  • vibram
21 Dec 2024 13:29
Replied by vibram on topic Another joint 0 on limit switch error
Category: Basic Configuration
Hello PCW,
I debounced when using the 7i73 but without success.
I tried with isolated input on the 7i96s and it's working fine.
Do you have some documentation regarding the slow option? I find the input in Hal show but it's always low.
I'm very happy that it's working but I still don't get something. If it's due to the EMI, why I don't see the dot blinking in Hal show? It's strange...
  • agima2
  • agima2
21 Dec 2024 12:23
Replied by agima2 on topic Linux CNC auf Virtualbox Simulation
Category: Deutsch
OK,
Wenn also eine Refernzfahrt nur nach Maschinenstart zu machen ist, so muss ich wohl mit dieser  Notlösung leben. Ich dachte ich kann mein Programm laden und dann eine simulierte Referenzfahrt machen.
MfG.
  • JT
  • JT's Avatar
21 Dec 2024 12:20
Replied by JT on topic Should I update
Should I update
My Hardinge CHNC lathe runs Ubuntu 10.04 and LinuxCNC 2.7. if it's not broke don't fix it.
JT
  • Sandro
  • Sandro
21 Dec 2024 12:12
Replied by Sandro on topic Probe Basic do not start
Category: QtPyVCP
Found the issue:
CONFIG_FILE = custom_config.yml
was missing from the INI-File.
Sorry!
  • Hossein74Majidi
  • Hossein74Majidi
21 Dec 2024 12:01 - 21 Dec 2024 12:05
G Code Syntax Check (Python + Qt Designer) was created by Hossein74Majidi
Category: Qtvcp
Hi
I'm going to use Qt Designer for my Display.
In my python handler I have a method as following:
def load_selected_gcode(self):
if self.modenumber_str != "Auto":
self.show_message("Invalid Mode", "Switch to Auto Mode.",0)
return
index = self.w.listGCodeFiles.currentIndex()
file_name = self.model.data(index, QtCore.Qt.DisplayRole)
file_path = os.path.join(self.gcode_directory, file_name)
self.loaded_gcod = file_path
with open(file_path, 'r') as file:
gcode_content = file.read()
self.w.showGCode.setText(gcode_content)
self.command.reset_interpreter()
self.command.program_open(file_path)
self.show_message("Success", "G Code is loaded successfully", 1)
this method loads the g code file content into a QTextEdit Widget named " showGCode" now before self.command.reset_interpreter() command and self.command.program_open(file_path) which load the G Code into linuxcnc, I want to check the gcode file syntax. How can I do it? How do I know if my G Code file is ok.
  • Sandro
  • Sandro
21 Dec 2024 11:52
Category: QtPyVCP
Hello everyone
I am having a different error when trying to start Probe Basic. I am coming from a currently working Gmoccapy machine. The error message is as follows:
  File "/usr/lib/python3/dist-packages/qtpyvcp/actions/__init__.py", line 62, in bindWidget
    method = getattr(method, item)
AttributeError: module 'qtpyvcp.actions' has no attribute 'settings'
During handling of the above exception, another exception occurred:
  File "/usr/lib/python3/dist-packages/qtpyvcp/widgets/form_widgets/main_window.py", line 198, in getMenuAction
    actions.bindWidget(menu_action, action_name)
  File "/usr/lib/python3/dist-packages/qtpyvcp/actions/__init__.py", line 67, in bindWidget
    raise InvalidAction("Could not get action method: %s" % item)
qtpyvcp.actions.InvalidAction: Could not get action method: settings
2024-12-21 12:36:01,809 - qtpyvcp.widgets.form_widgets.main_window - ERROR - Error binding menu action settings.backplot.show-program-ticks
2024-12-21 12:36:01,998 - qtpyvcp.app.launcher - INFO - Loading POSTGUI_HALFILE: /home/cnc/linuxcnc/configs/ethercat_milling_machine_csv_probe_basic/probe_basic_postgui.hal
Greetings
Sandro
Displaying 21676 - 21690 out of 21702 results.
Time to create page: 0.430 seconds
