  • kor
  • kor
20 Nov 2025 03:37 - 20 Nov 2025 03:37
  • TimP
  • TimP
20 Nov 2025 03:35
Need your opinion on Axes placement.
Category: CNC Machines
Is there in existence CNC machines with such axes placement. If yes how this types of machines called?
Red -> X, Green -> Y, Blue -> Z
Pros:
Clean working area, no way covers (only on vertical wall)
Easy way covers construction (plain sheet of metal)
Possibility to put long vertical work material (if to remove table or use other type of attachment)
4 and 5 axis could be added for rotating (smaller table or chuck)
Cons:
Please share your opinion
  • DemonClaW
  • DemonClaW
20 Nov 2025 03:34 - 20 Nov 2025 03:37
Beckhoff Problem with Communication (TwinCAT, LinuxCNC)
Category: EtherCAT
I didnt see that either, its what i got with my last and frustraded way by using AI.
Before I did the "Thing" above I had this as .xml but that didnt work, too
I have started by doing it exactly like this :
  • Hakan
  • Hakan
20 Nov 2025 03:07
Sudden motor jump after machine enable. Delta ASDA e3 drives and EtherCAT
Category: EtherCAT
It could be interesting to use halscope and record pos-cmd and pos-fb around the Machine on event.
I think your analysis is right. I have a similar problem. I zero the encoder's values before starting linuxcnc.
My issue is related to stepper motors when energized, so not necessarily same for you.
  • SPH
  • SPH's Avatar
20 Nov 2025 02:47
Category: EtherCAT
Ok, changing the Home_Absolute_encoder=2 to =0, no change. #'d it out altogether, still no change.
What seems to be happening or at least what I can see is that when lcnc starts up it's loading the stored g54 values from linuxcnc.var as the current machine possition but then it's zeroing out the dro a few seconds later. If the machine is enabled it's actually trying to make that move to 0 rather than just the dro zeroing out.
I've no idea at this point. Maybe an actual homing routine will sort it out. At least for now I know that if I wait a few seconds before enabling the machine I won't snap any motor shafts.
  • Hakan
  • Hakan
20 Nov 2025 02:24
Category: EtherCAT
What's that? Never seen that before.
Anyway that won't work with lcec_conf, it requires a file in xml format.
Easiest way, I think, is to take the output of the command "lcec_configgen" and put that
in the ethercat-conf.xml file and use that as input to lcec-conf.
Example here to show the structure and syntax of things
github.com/dbraun1981/hal-cia402/tree/main/example
Reference to lcec and lcec_conf
github.com/linuxcnc-ethercat/linuxcnc-ethercat
  • Hakan
  • Hakan
20 Nov 2025 02:17
EtherCAT + CiA402 Servo: OP state reached, but axis won’t move (only Following E
Okay, so one drive is for a spindle?
I made an adaptation to the cia402 component for the driver to work in PV (Profile velocity) mode
which is better suited to run as spindle.
Check out here github.com/MetalMusings/cia402pv
This person made it work after a while forum.linuxcnc.org/38-general-linuxcnc-q...tor-as-spindle-motor
  • T_D
  • T_D
20 Nov 2025 01:55
Maho 500 W4 Retrofit was created by T_D
Hallo zusammen , ich bin seid ca. 4 Wochen der stolze Besitzer einer Maho 500 W4 , es ist die selbe wie in dem User DoWerna jedoch haben sich bei dem Eintrag nicht alle meine fragen geklärt , zum einen wie ist das mit den Mesa karten gibt es unterschiede zwischen PCIe oder über Lan Kabel bzw. was ist besser oder besser erweiterbar oder eventuell günstiger und wie ist das mit dem Bedienpult welches ich selber bauen möchte ? ich habe mir die benötigten Taster zusammengeschrieben und möchte das auch in der Art machen mit Gmoccapy und dachte an die selbe Bedienart wie bei den Kunzmann 3/4 Maschinen dass dort also noch ein Handrad mit Achsauswahl hinzugefügt werden soll (Haidenhain Steuerung). ich bin kein Elektroniker sondern Industriemechaniker und muss mich dort in das Thema selber hineinarbeiten deswegen wäre die ein oder andere Hilfe gerade was die Mesa karten angeht nicht so schlecht  ich mache gerade einen Maschinenbautechniker und kenne mich dadurch schon ein wenig mit SPS aus aber manche Sachen kann man dort übertragen aber gerade das mit diesen Signalen bzw. von Haidenhain Glasmessstäben zu denen die die Mesa versteht ist für mich Neuland . gruß Tom
  • SPH
  • SPH's Avatar
20 Nov 2025 01:16
Category: EtherCAT
Looks like it's going to be the Home_absolute_encoder=2
I should have said that my motors don't have absolute encoders.
  • SPH
  • SPH's Avatar
20 Nov 2025 00:38
Category: EtherCAT
Ok so I've found what's happening but not why. Video below shows it in detail.
A few seconds after Lcnc loads the, I guess, current possition of the machine, the possition it starts up in lets say, is changing. I can see it jump from one position to the new one. Sometimes it's just the Z that jumps, sometimes it's the z and the y.
I hadn't noticed it before as I was so busy watching the motors. If I enable the machine before the current position in lcnc updates it tries to move to that new position. Again, easier to show it than describe it. It's pretty clear in the video, linked here
Could this be something to do with absolute encoders? The original machine that I'm using the files from had absolute encoders. Is there something saving the machine position on shutdown or something like that?
Displaying 11236 - 11245 out of 11245 results.
Time to create page: 0.214 seconds
