  • PCW
  • PCW's Avatar
22 Jun 2026 17:46
Replied by PCW on topic 7i92tm + 2xbob
7i92tm + 2xbob
Category: Driver Boards
Unless you can get a MPG with open collector outputs ( that match the SainsSmart BOB inputs ),
you are probably better off connecting the MPG  directly to the 7I92.
  • Masiwood123
  • Masiwood123's Avatar
22 Jun 2026 17:43 - 22 Jun 2026 17:44
Replied by Masiwood123 on topic 7i92tm + 2xbob
7i92tm + 2xbob
better solution is always 7i96s, The price of the card is not expensive at all, but the problem is that with customs and transportation, even from Portugal, the price is almost double here in Serbia.
  • Masiwood123
22 Jun 2026 17:31
7i92tm + 2xbob
This classic bob is available in our market, so in that case, would it be possible to somehow make mpg wheels work with 100ppr/5v?
  • PCW
  • PCW's Avatar
22 Jun 2026 17:20
7i92tm + 2xbob
Yes, you can use the 5ABOBx2 firmware for the common Sainsmart BOB
and choosing the discover option in pnccconf will allow you to make a
working configuration for that firmware.
On issue with the SainSmart type BOBS is that they have no TTL encoder inputs
Those BOBs have 10v ? sourcing inputs (ground to actuate) which may work with
low resolution encoders with open collector outputs. ( low resolution because those inputs
are fed through slow opto isolators )
  • Masiwood123
22 Jun 2026 17:03
7i92tm + 2xbob
thanks, in that case I like the option to flash the card for 2xbob, both bob via a fmale to fmale 26pin cable?...in that case I need for my lathe machine one spindle analog output, one spindle encoder input and xzA config for servos and two independent simulative mpg wheels for x and z. In that case, will the pnccfg and gecko initial configuration give me the ability to meet the above needs, possibly by modifying hal for mpg and spindle encoder?
  • PCW
  • PCW's Avatar
22 Jun 2026 16:20
7i92tm + 2xbob
Yes, the G540X2 configuration supports step/dir on both connectors (8 stepgens total)
The 5ABOB x2 configuration is anothe possibility
You _can_ use the output directly with some limitations.
1. They are 3.3V outputs but can drive 5 V  loada when using in sinking mode
( say drive STEP+ to +5V, drive STEP- to  7I92 STEP)
2. The 7I92 pins can be damaged easily by overvoltages (input output range is -0.3V to +7V)
Its very easy to damage with negative voltages unless there is some current limiting
How do you get a negative voltage with high current? Just connect a GPIO pin to frame ground
that has 1VAC of of HF electrical noise relative to 7I92 ground from axis drives/VFDs
If you use the 7I92 GPIO directly, its best to have a small series resistor to protect against
this issue
  • Masiwood123
22 Jun 2026 16:07
7i92tm + 2xbob was created by Masiwood123
7i92tm + 2xbob
need help with card configuration through pnccfg or mesact...namely specific question can 7i92tm be used without bob  cards directly and if so what is the initial configuration that should be selected in pnccfg? there is an option for gecko in the menu, is it adequate in case of using two bob cards or some other option. so that both P1 and P2 connectors are functional. thanks?
  • lgrfbs
  • lgrfbs's Avatar
22 Jun 2026 15:59
Replied by lgrfbs on topic largest NC file
largest NC file
Wow, those are some pretty hefty files you're working with.
Thanks for sharing more with us.
  • cob.charles
  • cob.charles
22 Jun 2026 15:46 - 22 Jun 2026 17:48
Replied by cob.charles on topic Configure 7I92 Zhulong card on AliExpress.
I have another question. I select the option to turn on the spindle. Output 27 is the option available, but it doesn't output 24V to turn on the relay and start the engine. The other available outputs (numbers 12, 13, 14, 29, 30, 31) always output 5V. Therefore, I wouldn't be able to connect a relay for the refrigeration pump and other control outputs. I've already changed the input and output functions, but the voltage remains the same.
  • MikkelRS
  • MikkelRS's Avatar
22 Jun 2026 15:44
Replied by MikkelRS on topic largest NC file
largest NC file
At work I use a 5axis large format machine, ive had over 100mb files before cutting for ~25 hours.
It has a tool changer but rarely used since it gets full of crud- crappy gantry design with very little dust extraction.
Much fun!
  • axemas
  • axemas's Avatar
22 Jun 2026 15:33
NativeCAM 2.0b — Python 3 & GTK3 port for LinuxCNC 2.9 / Debian 13 Trixie
Category: NativeCAM
Hi everyone,I owe you an apology for the month of silence. The reason is that I've been completely focused on a hardware project called Proton – a CNC motion controller I'm developing alongside NativeCAM. I've put up a page at
cncproton.com
with some info, but honestly, that project has been consuming all my focus and time, and I let this thread slip.Now that the hardware side is stable, I'm back and catching up on everything. I've read all three pages of this thread, and I've just replied to each of you individually (Surmetall, COFHAL, Doug Crews, and others).Over the next week, I'll push fixes to the GitHub repo (especially the blank GladeVCP tab and the OWord path documentation) and prepare the lathe test package.Thank you for your patience – NativeCAM is still very much alive.— Axemas
  • axemas
  • axemas's Avatar
22 Jun 2026 15:27
Category: NativeCAM
@Doug Crews – thanks for the report. The blank tab is a known issue with the -4 package on Trixie. GTK deprecation warnings break the embedded GladeVCP renderer.
Workaround: run nativecam standalone once, close it, then launch LinuxCNC – the tab should appear.
Also check your INI: NCAM_DIR should point to /usr/share/linuxcnc/aux_gladevcp/NativeCAM if the default doesn't work.
I'm fixing this properly in the next release (-5 or -6) within a few days.
— Axemas
22 Jun 2026 15:25
Replied by tommylight on topic Installing LinuxCNC RTAI
Category: Installing LinuxCNC
Run one of the included configs for parallel port, if those run you are OK.
  • axemas
  • axemas's Avatar
22 Jun 2026 15:17
Category: NativeCAM
@COFHAL – you asked about the ~/nativecam directory and OWord macros. Here's what's going on:
NativeCAM creates and uses ~/nativecam as its working directory for temporary files, tool tables, and post-processor configs.
The SUBROUTINE_PATH in your LinuxCNC INI file must include the path to the OWord subroutines that NativeCAM generates. Without that, LinuxCNC won't find the macros.
If Axis shows no errors but QTDragon fails with "can't find macros or OWord," it's almost certainly a path issue.
Quick fix: add something like this to your INI file:
text
[RS274NGC]
SUBROUTINE_PATH = ~/nativecam:/usr/share/linuxcnc/ncfiles
Restart LinuxCNC and try again. If it still doesn't work, paste your full INI file here and I'll debug it with you.
— Axemas
  • axemas
  • axemas's Avatar
22 Jun 2026 15:15
Category: NativeCAM
@Surmetall – thank you for the kind words and for the continued excitement about the lathe features, especially the polyline workflow alongside G71/G72/G73. That preview video took a lot of work, and it means a lot that it sparked anticipation.
Since my last update, I've been testing the polyline path generation on real G-code scenarios. No major blockers – mostly fine-tuning the toolpath logic and cleaning up the UI response for lathe operations. I'm planning to push a test package soon.
And yes, I'd absolutely love for you to test it on a real machine. Your offer to provide feedback, screenshots, and G-code examples is gold. I'll reach out to you directly when I have something ready for real-world testing.
— Axemas
Displaying 2821 - 2835 out of 12801 results.
Time to create page: 1.416 seconds
