18 Mar 2026 20:40
Replied by tommylight on topic Motor timing help
Motor timing help
At 75 and 185mVPP, those look like noise, not a signal of any kind, although the first one is weirdly clean sinusoidal.
  • miniwini
  • miniwini's Avatar
18 Mar 2026 20:01
Replied by miniwini on topic LinuxCNC 2.98 - Ethercat - ProbeBasic
Category: EtherCAT
thank you for this very helpfull hint!! it´s back online!!
the grandixximo repo did it!
cheers
miniwini
  • PCW
  • PCW's Avatar
18 Mar 2026 19:46
Installing Linuxcnc on new pc Using Debian 12.13 and Linuxcnc 2.9.8 mesa 7i76eu
Category: Installing LinuxCNC
OK if you have +24V on TB1 pin 5 relative to TB1 pin 8
and no red LED above TB1 when LinuxCNC is not running,
The 7I76EUs field I/O section has failed or been damaged.
  • kello711
  • kello711's Avatar
18 Mar 2026 19:39
Replied by kello711 on topic Probe Basic Errors after successfully probing
Category: QtPyVCP
Maybe send as screen shot of your roster settings and probe page settings as well as your z travel.
Attached. I think this is what you were asking for.
Also have you edited your var file and added all of the parameter numbers shown in the probe basic docs so the settings are persistent?
Yes, my ini includes a ref to the var file. Settings are persistent across executions of LinuxCNC. Or at least I think so.
github.com/kello711/linuxcnc/blob/main/c...ntnc/probe_basic.var
  • kello711
  • kello711's Avatar
18 Mar 2026 19:28
Category: QtPyVCP
Where is your zero home in z
Zero is at the top of travel with -6.3 at the bottom.
  • Aciera
  • Aciera's Avatar
18 Mar 2026 19:18 - 18 Mar 2026 19:43
Replied by Aciera on topic Updating Old GladeVCP Files?
Category: GladeVCP
The first thing I'd try is to load your glade file in the Glade (Version 3) editor and save it.
Also check for error output when starting your config from a terminal.
  • 0x2102
  • 0x2102's Avatar
18 Mar 2026 18:44
Umstieg von LinuxCNC + Mesa auf EtherCAT (Leadshine EL8 / Beckhoff) – Erfahrunge
Category: Deutsch
Der groesste Vorteil fuer mich bei einem EtherCAT System ist die Nutzung von Servos mit Absolut-Encoder. Maschine starten, LinuxCNC liesst die aktuelle absolute Position, "Home All" druecken, fertig (nichts verfaehrt da absolut). Selbst diesen Schritt koennte man sich mit ein paar Verbindungen in der HAL sparen und gleich bei "Machine On" bereit sein.
Falls das gewerblich genutzt werden soll dann nur Servos mit STO.
  • andrax
  • andrax's Avatar
18 Mar 2026 18:39
Category: Deutsch
Also Empfehlung meinerseits.
Wenn A6 dann richtig!
Bestellt zu den Servos die Encodercabel mit Batteriebox, erspart euch jede menge Ärger.
Die Servos dann auf Absolutwert Multiturn umstellen und noch ein einziges mal das Homing durchführen.
Derzeit sieht es leider so aus, dass der Ethercat hall Treiber, sowie die CIA402 Homing Komponenten noch eine große Baustelle sind.
Es gibt zwar hierzu Entwicklungen, aber keiner weiß, wann die in den Hauptzeig einfließen. Näheres zu den Problemen sind im englischen Teil zu finden.
Zum EMV:
EMV ist ein richtiges Problem, ich hatte hier zu kämpfen bevor die Ausgabe von dmesg fehlerfrei war, dennoch reagieren die Servos empfindlich auf Störungen.
Die empfohlenen Netzfilter für jeden Servo findet ihr Hier:
Stepperonline-A6
Netzwerkkabel Cat 6 sind Pflicht, besser Industriestandart und diese mit Feritkernen entstören, keine Schlaufen legen.
Netzwerkkarte mit Intelchip benutzen. Hier einfach mal bei Beckhoff vorbeischauen, die haben eine Liste mit Zertifizierten Chips.
Andere Karten gehen auch, aber können Probleme machen.
  • 0x2102
  • 0x2102's Avatar
18 Mar 2026 18:23
Replied by 0x2102 on topic LinuxCNC 2.98 - Ethercat - ProbeBasic
Category: EtherCAT
I had a similar issue. Was running an older linuxcnc-ethercat version - which worked well but when I went to the latest version to address the "random jitter" issue it crashed with signal 11.
forum.linuxcnc.org/ethercat/58103-etherc...-fix?start=60#344310
Try grandixximo's linuxcnc-ethercat repo - which has the "jitter fix" and the "zero-initialized" fix.
Make your custom mods and compile:
github.com/grandixximo/linuxcnc-ethercat
  • Todd Zuercher
  • Todd Zuercher's Avatar
18 Mar 2026 18:13
Replied by Todd Zuercher on topic Updating Old GladeVCP Files?
Category: GladeVCP
I'm still not getting anywhere with this. This GadeVCP worked fine with Linuxcnc 2.7 on Debian 7, but on the upgraded control PC running Linuxcnc 2.9 on Debian 13, The Python handler file doesn't seem to work. The problem is that it isn't creating any of the hal pins that it used to.  I've tried this with several different GladeVCPs that I had created a number of years ago for these machines. and all of them are giving similar issues.
  • PCW
  • PCW's Avatar
18 Mar 2026 18:02
If you measure from
TB1 pin 8 (-) to TB1 PIN 5 (+)
 What do voltage do you get?
  • 858PSJ
  • 858PSJ
18 Mar 2026 17:53
Replied by 858PSJ on topic pocketing program
pocketing program
here's a screenshot and a pocketingprogram
File Name: polygonpoc...3-18.zip
File Size:7 KB
  • georgio
  • georgio
18 Mar 2026 17:32
W1 is in the default position left and the fileld power is correctly conneced
George
  • PCW
  • PCW's Avatar
18 Mar 2026 17:29
OK that means you have no VIN so the field I/O section is unpowered
Normally VIN comes from VFIELD (W1 LEFT)
So either you have:
1.  No VFIELD
2. W1 is in the right hand position (it should be in the default left position)
3. Some hardware issue with the field I/O section.
Displaying 4726 - 4740 out of 13553 results.
Time to create page: 0.875 seconds
