  • jblanscett
  • jblanscett
26 Feb 2026 15:45
Trying to set up position control mode was created by jblanscett
Category: HAL
Hi all,
We are working on a retrofit of an older Fryer lathe. We are using a Mesa 7i95 board and are trying to connect our SGDH-10AE Yaskawa drivers to the board in position control mode. We have managed to make the axes move in what seems like position control, but when changing the jog speed in AXIS, it also changes where the motion stops. I believe that I have made a mistake, or many, in trying to set up our HAL code. We generated the HAL code from Pnfconf and then made adjustments to try to change the Stepgen to position control mode. I was hoping that we could get some help in looking at our Hal and Ini files to see where we may have gone wrong. Or if someone has successfully implemented it, we could look at their files to see if we can figure it out.
Thanks!
Jblanscett
  • Jensner
  • Jensner
26 Feb 2026 15:26 - 26 Feb 2026 15:40
After Month of machining without any problems -Positionerror and no more moving
I tried to copy the whole starting-log out of the Terminal, but i can`t becouse i got the error-message "there are too many links in this post...."
So i attached an file.
File Name: Error-Log.txt
File Size:6 KB
Also here the readhmid from the MESA 7i96s
File Name: MESA7i96s_...hmid.txt
File Size:7 KB
  • Jensner
  • Jensner
26 Feb 2026 15:19 - 26 Feb 2026 15:31
Hi andy,
there is no movement at all.
At the wizard i testet every axle (X, Y, Z) and not just one moved.
At the HAL-Scope i could see the feedrates on every axle, but no movement.
Every tim I try to do the reference, i get this error
Motor 2 Positionssfehler
In the Terminal is the following:
[qtpyvcp.actions.machine_actions][INFO]  Homing all axes (machine_actions.py:640)
emc/task/taskintf.cc 976: Error on joint 2, command number 96
[qtpyvcp.plugins.notifications][ERROR]  Motor 2 Positionssfehler (notifications.py:139)
  • hmearns
  • hmearns
26 Feb 2026 15:17
Replied by hmearns on topic Mesa StepGen ouputs with Yaskawa servos
Category: Driver Boards
Johnbl,
I am working on a lathe with SGDH-10AE drives and a Mesa 7i95 using step and direction with position control on the drive. Would you be willing to supply your hal, ini files from Linuxcnc and your parameter files from your drive?
We have some control over the drives and have the step and direction wired up as suggested here. Our linuxcnc is not working as we would like and the drive isn't producing consistent results. I think the pulses are coming out of the 7i95 too quickly. we do have some level of speed control through jog limit, but not what we would like and for some reason we don't get consistent distances depending on speed. We are having to tune the drive for position control which I thought would not be required initially. We aren't using feedback to the mesa, only internal to the drive.
Thanks,
Howard
  • Marcos DC
  • Marcos DC's Avatar
26 Feb 2026 13:59
Ver 2.9.4 iso clean install Trouble when disabling EOE
Category: EtherCAT
I think that for Yaskawa, the safest approach is to use Yaskawa’s own tool (SigmaWin+), since it knows the hardware and the drive’s constraints, and it’s also the approach their support can reproduce and help with if something goes wrong.
  • Plasmanfm
  • Plasmanfm
26 Feb 2026 13:47 - 26 Feb 2026 13:58
Umstieg von LinuxCNC + Mesa auf EtherCAT (Leadshine EL8 / Beckhoff) – Erfahrunge
Category: Deutsch
Ja EMV ist ein großes Thema und man sucht im dunkeln was da stört kann man messen aber nur die Industrie hat die Möglichkeit Datenkabel können in frage kommen hatte ich schon mit ein Monitor-Kabel.Da du ein Metalsteg eingebaut hast ist in dem Bereich was nicht ganz sauber.
Ich tippe auf die Grünen Datenkabel oder ist T3 ein Netgerät ? Vielleicht das.
Auch können die China Komponenten schuld sein hatte ich schon mit
ein Handylagerät das hat total das Fungerät gestört.
Was mir auch aufgefallen ist dein Netzfilter der ist ja ok aber es könnte
mit RCD Probleme geben muss nicht . Das ist heute auch ein großes Thema weil jede LED-Schaltung Ableitstöme produziert und irgend wann sind 30mA erreicht und dann macht es klick.
Gruß
Juergen
  • andypugh
  • andypugh's Avatar
26 Feb 2026 13:05
Replied by andypugh on topic Cannot JOG Plus/Minus move in TeleOp mode
Category: Basic Configuration
Do you mean 2.4.8 or 2.8.4 ?
(2.4.8 was released around 15 years ago)
  • andypugh
  • andypugh's Avatar
26 Feb 2026 12:58
Replied by andypugh on topic New Laser Build - raster engraving
Category: Plasma & Laser
Pasting this into the message body has destroyed the indentation. As it contains embedded Python this means that it won't work at all.
Can you attach the script as a file instead?
(I tried correcting the file, but it became too difficult in the Python code without doing real code analysis)
  • andypugh
  • andypugh's Avatar
26 Feb 2026 12:46
Need to install newest Linux Debian Bookworm with the newest Linuxcnc preempt-rt
Category: Installing LinuxCNC
You should be able to install a previous Bookworm ISO, then update the LinuxCNC version (this should actually be automatic).
The 2.9.4 ISO will definitely be Bookworm as it precedes the Trixie release.
www.linuxcnc.org/iso/
Then use the Synapric package manager to update LinuxCNC.
  • andypugh
  • andypugh's Avatar
26 Feb 2026 12:40
Can you give the _exact_ error message?
It feels like, for whatever reason, the motor drivers are inhibited. Do you see any movement at all?
  • Finngineering
  • Finngineering
26 Feb 2026 10:13
Replied by Finngineering on topic XHC WHB04B development?
Do you mean that the pendant did not recover in the above situation after you had commented out the assert line?
You could enable all logging by adding the "-a" option when loading the xhc-whb04b-6 component. It will write a lot of things to the terminal... which makes it easier to figure out if it gets stuck in some specific part of the code.
  • DerKlotz
  • DerKlotz
26 Feb 2026 10:03
Replied by DerKlotz on topic Add Buttons in Probe Basic
Category: QtPyVCP
i made a new install on my system today but fail again
- I downloaded and installed Bookworm 12.13 from the Probe Basic site  kcjengr.github.io/probe_basic/probe_basi..._stable_install.html
- i did sudo apt update
- i did sudo apt upgrade
- i downloaded the AMD64 Deb for PC
- i did cd~
- i did cd Download
- i did sudo dpkg -i linuxcnc-uspace_2.9.8_amd64.deb
the result after the last step
Selecting previously unselected package linuxcnc-uspace.
(Reading database ... 123705 files and directories currently installed.)
Preparing to unpack linuxcnc-uspace_2.9.8_amd64.deb ...
Unpacking linuxcnc-uspace (1:2.9.8) ...
dpkg: dependency problems prevent configuration of linuxcnc-uspace:
 linuxcnc-uspace depends on libboost-python1.74.0 (>= 1.74.0+ds1); however:
  Package libboost-python1.74.0 is not installed.
 linuxcnc-uspace depends on libboost-python1.74.0-py311; however:
  Package libboost-python1.74.0-py311 is not installed.
 linuxcnc-uspace depends on libgpiod2 (>= 1.5.1); however:
  Package libgpiod2 is not installed.
 linuxcnc-uspace depends on libmodbus5 (>= 3.1.4); however:
  Package libmodbus5 is not installed.
 linuxcnc-uspace depends on libtk8.6 (>= 8.6.0); however:
  Package libtk8.6 is not installed.
 linuxcnc-uspace depends on libudev-dev; however:
  Package libudev-dev is not installed.
 linuxcnc-uspace depends on iptables; however:
  Package iptables is not installed.
 linuxcnc-uspace depends on blt; however:
  Package blt is not installed.
 linuxcnc-uspace depends on mesa-utils; however:
  Package mesa-utils is not installed.
 linuxcnc-uspace depends on python3-tk; however:
  Package python3-tk is not installed.
 linuxcnc-uspace depends on python3-numpy; however:
  Package python3-numpy is not installed.
 linuxcnc-uspace depends on python3-opengl; however:
  Package python3-opengl is not installed.
 linuxcnc-uspace depends on python3-configobj; however:
  Package python3-configobj is not installed.
 linuxcnc-uspace depends on python3-xlib; however:
  Package python3-xlib is not installed.
 linuxcnc-uspace depends on libgtksourceview-4-dev; however:
  Package libgtksourceview-4-dev is not installed.
 linuxcnc-uspace depends on tcl8.6; however:
  Package tcl8.6 is not installed.
 linuxcnc-uspace depends on tk8.6; however:
  Package tk8.6 is not installed.
 linuxcnc-uspace depends on bwidget (>= 1.7); however:
  Package bwidget is not installed.
 linuxcnc-uspace depends on tclreadline; however:
  Package tclreadline is not installed.
 linuxcnc-uspace depends on tclx; however:
  Package tclx is not installed.
 linuxcnc-uspace depends on python3-pyqt5; however:
  Package python3-pyqt5 is not installed.
 linuxcnc-uspace depends on python3-pyqt5.qsci; however:
  Package python3-pyqt5.qsci is not installed.
 linuxcnc-uspace depends on python3-pyqt5.qtsvg; however:
  Package python3-pyqt5.qtsvg is not installed.
 linuxcnc-uspace depends on python3-pyqt5.qtopengl; however:
  Package python3-pyqt5.qtopengl is not installed.
 linuxcnc-uspace depends on python3-opencv; however:
  Package python3-opencv is not installed.
 linuxcnc-uspace depends on python3-espeak; however:
  Package python3-espeak is not installed.
 linuxcnc-uspace depends on python3-dbus.mainloop.pyqt5; however:
  Package python3-dbus.mainloop.pyqt5 is not installed.
 linuxcnc-uspace depends on python3-pyqt5.qtwebengine | python3-pyqt5.qtwebkit; however:
  Package python3-pyqt5.qtwebengine is not installed.
  Package python3-pyqt5.qtwebkit is not installed.
 linuxcnc-uspace depends on espeak-ng; however:
  Package espeak-ng is not installed.
 linuxcnc-uspace depends on pyqt5-dev-tools; however:
  Package pyqt5-dev-tools is not installed.
 linuxcnc-uspace depends on gstreamer1.0-tools; however:
  Package gstreamer1.0-tools is not installed.
 linuxcnc-uspace depends on espeak; however:
  Package espeak is not installed.
 linuxcnc-uspace depends on python3-poppler-qt5; however:
  Package python3-poppler-qt5 is not installed.
 linuxcnc-uspace depends on psmisc; however:
  Package psmisc is not installed.
dpkg: error processing package linuxcnc-uspace (--install):
 dependency problems - leaving unconfigured
Processing triggers for libc-bin (2.36-9+deb12u13) ...
Processing triggers for desktop-file-utils (0.26-1) ...
Processing triggers for mailcap (3.70+nmu1) ...
Processing triggers for hicolor-icon-theme (0.17-2) ...
Processing triggers for man-db (2.11.2-2) ...
Processing triggers for shared-mime-info (2.2-1) ...
Errors were encountered while processing:
 linuxcnc-uspace
  • Hakan
  • Hakan
26 Feb 2026 08:44
Replied by Hakan on topic XHC WHB04B development?
I have added a bit more logging to the component..
The component is attempting to connect, it says, but I wonder if it actually tries and why that doesn't work.
  • Hakan
  • Hakan
26 Feb 2026 08:36 - 26 Feb 2026 08:41
Category: EtherCAT
That's right. Linuxcnc doesn't use an ESI file.
The ethercat master reads out the info it needs from the slave directly.
The safest way to update the SII eeprom contents of the drive is to use TwinCAT.
There are a number of steps needed, but in principle not difficult.
Download and install TwinCAT from Beckhoff it you don't already have it,
Place the ESI file you got from support in C:\TwinCAT\3.1\Config\Io\EtherCAT
or where your twincat installation is.
In this video I update the firmware on a device, the principle is the same for your drive.
Go to 5:20 for the relevant part.
  • Finngineering
  • Finngineering
26 Feb 2026 08:29
Okay. I did not really think that libusb_fill_interrupt_transfer() would solve the issue. But that IS the correct function to use in any case.
If the disconnect happens only at mode switches, I'm pretty sure it can be solved simply by modifying the xhc-whb04b-6 component. Maybe we need to add some more (temporary) logging to the component to pinpoint the issue.
It appears our dongle firmware is different by one version increment. But of course the hardware side is the important one for compatibility. I would think that there is a good chance that the hardware is compatible or the same.
Displaying 5716 - 5730 out of 13545 results.
Time to create page: 1.546 seconds
