  • Aciera
  • Aciera's Avatar
18 Sep 2026 08:49
Kinematic model for a 5axis mill with universal (nutating) head
Category: Show Your Stuff
I'm afraid I don't have a ready made kinematic for a machine with 2 work side rotaries and one spindle rotary.
Do you have a picture of the machine geometry? I'm having trouble picturing a spindle with a C rotation only. C would rotate around the Z axis and usually the spindle itself is aligned with the Z axis.
  • metalkesh
  • metalkesh
18 Sep 2026 08:38
Hi Aciera;
First of all, thanks for your great work.
with config "xyzbca-trsrn" it is very easy to make nutation-angle = 90 if machine doesn't have nutating head and it works properly with 90 degree nutation agle.
what about if A axis is on the plane like B axis, and only C axis is on spindle ? is there any easy way to do it with config  "xyzbca-trsrn" ?
i checked "xyzab-tdr" config too but this config doesnt have C axis on spindle. and also i checked "xybc-trt" .
what is the correct way for  configuration xyzbac- table rotay- table rotary  - spindle rotary ?
  • murdemon
  • murdemon
18 Sep 2026 06:53
Replied by murdemon on topic Xilinx Zynq 7010 fpga crypto windfall boards
Category: Driver Boards
6 SmartSerial interfaces with ZYNQ 7010 and SPI Ethernet , on first one ethernet port Ethercat is configured
  • RMJ fabrication
  • RMJ fabrication
18 Sep 2026 05:36
Replied by RMJ fabrication on topic Home switches stopping machine but not latching fully
Category: Plasmac
I ordered new switches and replaced them and now the homing sequence is working and latching fully. Now homing works all the time with no errors and I did not change any settings in the configuration.
The old switches are at least two years old so it could have been contact bounce. Big thank you to everyone for your resourceful feedback and kind help.
  • csec0128
  • csec0128
17 Sep 2026 15:51
Replied by csec0128 on topic Retrofit of Precix 5x10 CNC
So I have a Precix machine I picked up a while ago. This thread has been a HUGE help in finding some information that is kept secret. If you own a Precix machine, you may know what I am getting at.
Anyways, I wanted to join in on getting more information out there for it, mainly focusing on the encoder side and how I am managing it using some DC drivers. These drivers are a bit older, but using the Gecko G320 DC servo drive units along with the C46 Differential Single-Ended Converter. Taking the encoder that you have established for the wires coming from the machine, converting the singles to a DC signal for the Gecko Drivers to be able to understand. Again, this is a bit older stuff, but for anyone retrofitting the Precix machine, this will be a key factor, I promise you!
I did go a different route using a C11G breakout board instead of the Mesa Card using the LinuxCNC, but that's because I already had the board for another project and was just using what I had on hand. Check out the photo I included to help anyone else out there.
I will be doing a full wiring diagram on the machine once I sort out some of the other items suchs as spindle wiring, limit switches and such. I'd like to be able to use a RapidChangeATC (rapidchangeatc.com/) for this machine, but not sure the collet and nut would match up correctly.
As always thanks for everyone's input!
I updated my wiring diagram per PCW's recommendation for the drive interface. I also took a guess on the encoder interface with the details I got from Magtronic. Hopefully someone can tell me if it make sense or not.
I took off the CAP of the encoder and would have to start to take it apart further to find details PCW mentioned.
I am thinking with the manual I found and the drawing Magtronic sent I can be fairly confident in the wiring, what do you think?
Anyone want to see more pictures (why I don't know) can see them here:
photos.app.goo.gl/wBgjA9fuxgXsEZX96
  • Lcvette
  • Lcvette's Avatar
17 Sep 2026 15:48
(Solved) Probe Basic - HAL pins not being created
Category: QtPyVCP
don't rely solely on the machine setup files, also look over the docs config section that is more kept updated and relevant, the machine setup files are a very very basic setup and may actually be out of date, i need to look at that when i have a moment to sit down at dev next.
use the docs those have been recently updated and contain the more current necessary items you may be missing.
probe basic itself has requirements beyond axis so again only rely on axis as a starting point, simply changing display is not going to work without the remaining items being present.
the post gui hal file CANNOT be removed the base items in the supplied postgui are requirements not optional if you do not use the stock items in the probe_basic_postgui.hal file, it will 100% have issues.
  • rodw
  • rodw's Avatar
17 Sep 2026 07:01
Replied by rodw on topic Crash
Crash
Category: Plasmac
If you are using qtplasmac, I would upgrade to Linuxcnc 2.9.10 using the ISO. Seeing Python 2.7 errors raises alarm bells for me
Also, you may find with qtplasmac you will get better results with master branch so it would be good to learn how to build LinuxCNC from source. Its pretty simple these days. QTplasmac is still being pretty actively developed.
  • rodw
  • rodw's Avatar
17 Sep 2026 06:52
Category: Plasmac
Please  try using a HOME_OFFSET of 0.1 inch. You want the axis to be off the home switch after homing. Not sure whether this should be positive or negative. If it fails, change the sign and try again...
  • rodw
  • rodw's Avatar
17 Sep 2026 06:47
loading debian 10 on a very old compaq Presario dual boot
Category: Installing LinuxCNC
2.9.10 is the current release so that is all good. Iwould expect you are therefore running Debian 13 if you used the LinuxCNC ISO
  • rodw
  • rodw's Avatar
17 Sep 2026 06:41
J1900 L2 sibling: pin Qt HMI to CPUs 0-1, keep the 1 ms EtherCAT thread on CPU3
Category: EtherCAT
Well you got further than me years ago, you were able to boot the Baytrail PC (but mine was a J1850).
Isolating the sibling core is recommended. If you are using a NIC with an RT app that uses networking, its recommended to pin the NIC IRQ to the same core as the RT thread. Latency may be worse  but the network latency becomes the bottleneck. I could not see what you were pinning.
  • Artur_1617
  • Artur_1617's Avatar
17 Sep 2026 04:03 - 17 Sep 2026 04:19
New Atc Tool Magazine was created by Artur_1617
Category: User Exchange
For sale new atc changers Deta International.
Location Poland
Model R3DE4  Cat 40
Price 3500E
www.deta.com.tw/For-VMC/30-disc-typeFeatures of Tool Magazine
  1. High-Precision, Low-Noise Drive System
    Features a dual-roller Geneva mechanism combined with a worm gear reducer for precise indexing and positioning. Ensures stable operation, reduces motor load, and achieves high energy efficiency.
  2. Highly Durable Tool Tilting Mechanism
    Employs a slim pneumatic cylinder on the rail to withstand side forces during tool tilting and provide a cushioning function.
    Equipped with a locking pin mechanism to prevent the tool pot from shifting in the event of air source interruption.
  3. High-Strength, Lightweight Structure
    Key components are made of high-strength aluminum alloy, optimizing both rigidity and light weight.
  4. Modular Tool Arm Design
    Modular design separates the main body and the gripper for quick and simple specification changes.
    Utilizes German spring steel wire with galvanization for superior anti-rust performance.
    Integrated drainage function prevents coolant accumulation, ensuring reliable operation
  5. Components for conversion to smaller tool holders—such as BT30 or SK30—can be purchased from the manufacturer.
  • tuxcnc
  • tuxcnc
17 Sep 2026 03:45 - 17 Sep 2026 03:47
Replied by tuxcnc on topic Crash
Crash
Category: Plasmac
@tuxcnc, (...) I don't understand why the message is useless.
tuxcnc post=349633 userid=3011
but it doesn't tell you where that empty string came from.
  • NWE
  • NWE's Avatar
17 Sep 2026 02:40 - 17 Sep 2026 02:43
Replied by NWE on topic Crash
Crash
Category: Plasmac
@tuxcnc, I agree python 2.7 is ancient. I don't understand why the message is useless.
It says file ./plasmac/plasmac_gcode.py line 39
Popen() apparently returned an empty string to int() which needs some character.
  • ncf250sd
  • ncf250sd
16 Sep 2026 21:32
Replied by ncf250sd on topic Probe basic error
Probe basic error
Category: QtPyVCP
My small contribution compared to all the help I’ve received.
  • spumco
  • spumco
16 Sep 2026 21:27
Category: QtPyVCP
does the log show anything?
Yes, but since the hang doesn't happen at exactly the same point each time it's a bit murky.
After the first few tries the startup attempts have been with the postgui.hal commented out of INI completely.  I tried starting with every non-mandatory feature/setting commented out - no dice.
And the Axis good start-up is the same config.  Just switch [DISPLAY]DISPLAY = probe_basic to [DISPLAY]DISPLAY = axis.  No hal-related issues for the same exact LCNC connections.
As for the other probe basic INI stuff, I copy-pasted from the machine_setup_files INI.  You're welcome to have a look at my INI to see if I fat-fingered something.
Displaying 706 - 720 out of 12270 results.
Time to create page: 0.384 seconds
