  • Aciera
  • Aciera's Avatar
21 Jan 2026 16:52
Replied by Aciera on topic LinuxCNC S-Curve Accelerations
@grandixximo
Note the issues related to scurve code:
github.com/LinuxCNC/linuxcnc/issues/3719
github.com/LinuxCNC/linuxcnc/issues/3720
I'm not sure if pinging you on github works.
  • sataran
  • sataran
21 Jan 2026 16:45
Bitfile or help – Mesa 6i25 + 7i74 (BiSS-C) + 8i20 + 7i70/7i87
Category: Driver Boards
Update, i just received the (almost) final plan for this project.
mesa part:
  6i25 => 7i76  -> spindle   = 1 motor
                        - >field output 1 = motor on/off
                        - >field output 2 = motor on/off
                          ? -> encodeur biss-c ?
          => 7i74   ? 0 => encodeur biss-c (RAIK060 by vishay) ?
                         1 => 7i87 -> 6 temperatures captors
                                          ->  1 pressure captor
                         2 => 8i20 -> main motor
Encodeur:
- i use an encoder raik060 from vishay (doc bellow) it seem to need a clock from the master card and maybe a signal? start?? in order to operate.
Project non mesa part.
This project is not a cnc but a system to test pieces it is composed  of 2 part:
- The first part is 1 motor cyclic powered by 8i20 in team with the biss-c encoder and a pressure captor in team with the motor controlled by 7i76 spindle
- The second part is the cooling system that will work in continue.
this is 2 motor that will run full time en 4 temp captors for security
QUESTIONS:
-Concerning the signal biss i am flexible on what part to use, ether the 7i76 or the 7i74 depending on what may be possible or the easiest and i saws where was an encoder part on the 7i76U  was curious if it was possible to use that?.
-If we keep the signal biss-c on the 7i74 it is important to note that i need to have most of the 7i74 port to work normally and only the port 0 has a biss-c socket. If it is not possible i can use a second 6i25 and 7i74 dedicated to handling the signal biss.
- i still dont have any signal from or to my encoder, is their something to do in order to generate the clock signal or to make it react? I cant seem to find details about this part in the forum (i still have a lot to read so i am not loosing hope) and chatgpt or other ai keep telling me that it is impossible or to use non existing  driver like hm2_biss.
I added the doc of the encoder i am using, it is the Multi turn version, information about the signal are page 15 and 16.
Lastly is there any doc about how to configure a framework? Even if i cant do one myself, knowing what is happening would help me to know what information i need to give in order to get a bitfile adapted to my configuration.
  • Jocman
  • Jocman
21 Jan 2026 16:39
MAC address not retrieved (after 2 years stop)
I'm really poor in network matter....
Why my results are so dismal?
I red "60000 packets transmitted, 60000 packets received, 0% packet loss" and I was almost happy.....
BTW, the Mesa in wired to the onboard ethernet card, while the router (LAN, WEB) is wired to a PCI board (a commercial, very cheap one, this PC is intended only for CNC machining)
At the moment I don't remember the MB specification, but as soon as I can, I'll check e post it.
  • jjdege
  • jjdege's Avatar
21 Jan 2026 16:31
Replied by jjdege on topic asd-a2-e ... lcec driver?
Category: EtherCAT
HI
the .xml file should look like this, I think
File Name: ethercat-c...1-21.xml
File Size:0 KB
  • freemoore
  • freemoore
21 Jan 2026 16:20
7i80HD+7i48+7i42TA+7i84 Mesa firmware request (morbidelli author 503 retrofit)
OK. Have done this and grounding each of these inputs produces no response from any of the pins a, b or index in halshow, on any of encoder channels 00, 01, or 02.
  • PCW
  • PCW's Avatar
21 Jan 2026 16:03
Those are fairly dismal ping results, What is the Ethernet hardware?
If Intel, make sure you disable IRQ coalescing (see hm2_eth manual page)
  • SehagEvez
  • SehagEvez
21 Jan 2026 16:03 - 22 Jan 2026 14:14
CNC Rotary Table with Standalone Controller for Gear Hobbing
Category: Basic Configuration
That’s a solid approach, especially starting from Clough42’s ELS project. Mounting an encoder and motor on the dividing head is a clean way to get a lot of capability without going full CNC. The DR-DRO setup makes sense too, it’s way more flexible for tropical-casino.com/ oddball indexing and manual machine tricks. Doing something similar on an MH800E with LinuxCNC sounds like a natural next step, especially since you can blend manual control with some pretty advanced automation when you need it.
  • DemonClaW
  • DemonClaW
21 Jan 2026 15:53
Replied by DemonClaW on topic Generating a own Popup
Category: Qtvcp
First thing is that my data path isnt /usr/share anymore, instead some documentations told me to get the file seperated copyed into the machine folder, for me i got the base ui and handler there : /home/.../linuxcnc/configs/.../qtvcp/screens/qtdragon_hd/. The second thing is your talking about taking your file name it "qtdragon_hd_handler.py", if i go like that i would override the current base handler, that doesnt make sence to me. What i exactly did know is
-Rename ur .py data to vacuum_popup.py (using it as a second handler)
-Implement your 3 lines to .ini like that:
EMBED_TAB_NAME=vacuum_popup
EMBED_TAB_COMMAND=qtvcp vacuum_popup
EMBED_TAB_LOCATION=DIALOG
-/home/.../linuxcnc/configs/.../qtvcp/panels/vacuum_popup/ is the path where the ui would be
If i start then it seems like it load but it cant cant work with the class: Like you will see in the error code i attached as .txt
I feel kind of sorry but i really want to learn the things, even if the start is currently kind of hard. But your help is getting me confident i can make it.
Thanks for your help
  • cnbbom
  • cnbbom
21 Jan 2026 15:32
Replied by cnbbom on topic New and Working RTAI debs for 2.9
Category: Installing LinuxCNC
I took some time to modify some BIOS settings, performed several restarts, and ran tests. This is the result I was able to achieve.
  • Jocman
  • Jocman
21 Jan 2026 13:18
sorry for being late in my answer, but job and family demand their time too.....This is what i get : joccnc@JocCnc:~$ sudo chrt 99 ping -i.001 -c 60000 -q 10.10.10.10
[sudo] password for joccnc:
PING 10.10.10.10 (10.10.10.10): 56 data bytes
--- 10.10.10.10 ping statistics ---
round-trip min/avg/max/stddev = 0.246/0.395/0.733/0.032 ms
  • TAKUYA
  • TAKUYA
21 Jan 2026 13:12
Replied by TAKUYA on topic StepperOnline A6 Servo
Category: EtherCAT
In the meantime, I was testing around with the HOME_ABSOLUTE_ENCODER = 2 setting in axis SIM. It turns out that there might be a positional accuracy issue when homing. Ive created a github Issue for it already. It seems like its reading the joint position and not the encoder position when setting the new home so on re-home, it shifts the axis location in software by your home-offset value while hardware remains the same.
21 Jan 2026 12:33
Mesa 7i96S step ausgangsignal =5V , Schrittmotortriber eingang 12V was nun?
Category: Deutsch
Der Titel dieses Threads suggeriert aber, dass du eine 7i96 nutzt. Wenn dem gar nicht so ist, bin ich bei euch.
Was soll der titel sein?
  • juliankoenig87
  • juliankoenig87
21 Jan 2026 11:11
Category: Deutsch
Selber Bauen macht meisten mehr Spaß ;-)
21 Jan 2026 10:53
Replied by tommylight on topic How to set current machine position manually?
a) How do they probably do it on my "store bought" milling machine? No need to home it. The beast knows where it is after it is powered on.
Absolute encoders.
b) Can the home position be defined in the center of the machine travel? That would make the request easy. The axis can be homed at the position that was reached and the G54 can be "touched off".
Yes, even with normal encoder or without them, must have home switches.
It will home normally at axis ends, and move to wherever you would like it to be home.
c) Can the machine be homed normally, then after disabling the motors moving it around and keep track of the position? Provided some feedback is available e.g. rotary encoder on the hand wheel, or linear encoders?
(that would allow to use the Linux similar to a normal DRO, when the motors are disabled.)
This kind of tracking without motors might be also interesting to teach a machine.
Yes, all that can be done.
Teaching should also be possible without encoders, jogging the machine to required positions and saving coordinates.
Displaying 7546 - 7560 out of 13514 results.
Time to create page: 0.514 seconds
