  • 3404gerber
  • 3404gerber
11 Jan 2026 18:12
7cm should be ok. I started to have issue with TMC driver @4MHz after more or less 50cm.
Can you confirm that you always get the same SPI payload? (say, press the reset button 10 times and compare the results)
Could you share you hal file and the link to the firmware/lcnc component you use?
  • Lili
  • Lili
11 Jan 2026 17:56 - 11 Jan 2026 18:08
Single LC10E-600W Driver Not Responding
Category: EtherCAT
Hello,
Can you take a look at my program?
In TwinCAT, I read the available PDOs/SDOs, and after a while I was able to launch the LinuxCNC GUI, but it’s not really connecting with a single Lichuan LC10E-600W driver. It stays in pre-operational mode, and switching the cable on/off has no effect, and the servo does not load or update its position. The program is attached
File Name: newproject.zip
File Size:47 KB
, and this is the
[code][code]        Halshow
Realtime Threads:
     Period  FP     Name               (     Time, Max-Time )
    1000000  YES          servo-thread (    54416,   409602 )
                  1 lcec.read-all
                  2 cia402.0.read-all
                  3 motion-command-handler
                  4 motion-controller
                  5 cia402.0.write-all
                  6 lcec.write-all
 Loaded HAL Components:
ID      Type  Name                                            PID   State
    55  User  halcmd2491                                       2491 ready
    51  User  axisui                                           2405 ready
    49  User  inihal                                           2401 ready
    40  RT    cia402                                                ready
    37  RT    lcec                                                  ready
    34  User  lcec_conf                                        2392 ready
    30  RT    __servo-thread                                        ready
    29  RT    motmod                                                ready
    26  RT    trivkins                                              ready
    21  RT    homemod                                               ready
    16  RT    tpmod                                                 ready
    10  User  halui                                            2377 ready
     4  User  iocontrol                                        2375 ready
Exported Functions:
Owner   CodeAddr  Arg       FP   Users  Name
 00040  7f0a273d4c2b  7f0a277f61d0  YES      1   cia402.0.read-all
 00040  7f0a273d41d9  7f0a277f61d0  YES      1   cia402.0.write-all
 00037  7f0a273f93ec  55c5e290a060  NO       0   lcec.0.read
 00037  7f0a273f7d4f  55c5e290a060  NO       0   lcec.0.write
 00037  7f0a273f9548  00000000  NO       1   lcec.read-all
 00037  7f0a273f7ed3  00000000  NO       1   lcec.write-all
 00029  7f0a275473c1  00000000  YES      1   motion-command-handler
 00029  7f0a275479b4  00000000  YES      1   motion-controller
Signals:
Type          Value  Name     (linked to)
bit            TRUE  emc-enable
                         ==> iocontrol.0.emc-enable-in
bit           FALSE  x-amp-fault
                         <== cia402.0.drv-fault
                         ==> joint.0.amp-fault-in
u32      0x00000004  x-controlword
                         <== cia402.0.controlword
                         ==> lcec.0.0.controlword
s32               0  x-drv-act-pos
                         ==> cia402.0.drv-actual-position
                         <== lcec.0.0.actualposition
bit           FALSE  x-enable
                         ==> cia402.0.enable
                         <== joint.0.amp-enable-out
s32               0  x-opmode
                         <== cia402.0.opmode
                         ==> lcec.0.0.modesofoperation
float             0  x-pos-cmd
                         ==> cia402.0.pos-cmd
                         <== joint.0.motor-pos-cmd
float             0  x-pos-fb
                         <== cia402.0.pos-fb
                         ==> joint.0.motor-pos-fb
u32      0x00000000  x-statusword
                         ==> cia402.0.statusword
                         <== lcec.0.0.statusword
s32               0  x-target-position
                         <== cia402.0.drv-target-position
                         ==> lcec.0.0.targetposition
 Parameters:
Owner   Type  Dir         Value  Name
    40  bit   RW           TRUE  cia402.0.auto-fault-reset
    40  bit   RW           TRUE  cia402.0.csp-mode
    40  float RW        1677722  cia402.0.pos-scale
    40  s32   RW           6004  cia402.0.read-all.tmax
    40  bit   RO          FALSE  cia402.0.read-all.tmax-increased
    40  float RW              1  cia402.0.velo-scale
    40  s32   RW           3724  cia402.0.write-all.tmax
    40  bit   RO          FALSE  cia402.0.write-all.tmax-increased
    37  u32   RW     0x000F4240  lcec.0.pll-max-err
    37  u32   RW     0x000003E8  lcec.0.pll-step
    37  s32   RW              0  lcec.0.read.tmax
    37  bit   RO          FALSE  lcec.0.read.tmax-increased
    37  s32   RW              0  lcec.0.write.tmax
    37  bit   RO          FALSE  lcec.0.write.tmax-increased
    37  s32   RW         161690  lcec.read-all.tmax
    37  bit   RO          FALSE  lcec.read-all.tmax-increased
    37  s32   RW         177650  lcec.write-all.tmax
    37  bit   RO          FALSE  lcec.write-all.tmax-increased
    29  s32   RW           8132  motion-command-handler.tmax
    29  bit   RO          FALSE  motion-command-handler.tmax-increased
    29  s32   RW          70300  motion-controller.tmax
    29  bit   RO          FALSE  motion-controller.tmax-increased
    29  bit   RO          FALSE  motion.debug-bit-0
    29  bit   RO          FALSE  motion.debug-bit-1
    29  float RO              0  motion.debug-float-0
    29  float RO              0  motion.debug-float-1
    29  float RO              0  motion.debug-float-2
    29  float RO              1  motion.debug-float-3
    29  s32   RO              0  motion.debug-s32-0
    29  s32   RO              0  motion.debug-s32-1
    30  s32   RW         409602  servo-thread.tmax
    29  float RO              0  tc.0.acc
    29  float RO              0  tc.0.pos
    29  float RO              0  tc.0.vel
    29  float RO              0  tc.1.acc
    29  float RO              0  tc.1.pos
    29  float RO              0  tc.1.vel
    29  float RO              0  tc.2.acc
    29  float RO              0  tc.2.pos
    29  float RO              0  tc.2.vel
    29  float RO              0  tc.3.acc
    29  float RO              0  tc.3.pos
    29  float RO              0  tc.3.vel
    29  u32   RO     0x00000000  traj.active_tc
    29  float RO              0  traj.pos_out
    29  float RO              0  traj.vel_out
Component Pins:
    29  float OUT             0  axis.a.eoffset
    29  bit   IN          FALSE  axis.a.eoffset-clear
    29  s32   IN              0  axis.a.eoffset-counts
    29  bit   IN          FALSE  axis.a.eoffset-enable
    29  float OUT             0  axis.a.eoffset-request
    29  float IN              0  axis.a.eoffset-scale
    29  float IN              1  axis.a.jog-accel-fraction
    29  s32   IN              0  axis.a.jog-counts
    29  bit   IN          FALSE  axis.a.jog-enable
    29  float IN              0  axis.a.jog-scale
    29  bit   IN          FALSE  axis.a.jog-vel-mode
    29  bit   OUT         FALSE  axis.a.kb-jog-active
    29  float OUT             0  axis.a.pos-cmd
    29  float OUT             0  axis.a.teleop-pos-cmd
    29  bit   OUT         FALSE  axis.a.teleop-tp-enable
    29  float OUT             0  axis.a.teleop-vel-cmd
    29  float OUT             0  axis.a.teleop-vel-lim
    29  bit   OUT         FALSE  axis.a.wheel-jog-active
    29  float OUT             0  axis.b.eoffset
    29  bit   IN          FALSE  axis.b.eoffset-clear
    29  s32   IN              0  axis.b.eoffset-counts
    29  bit   IN          FALSE  axis.b.eoffset-enable
    29  float OUT             0  axis.b.eoffset-request
    29  float IN              0  axis.b.eoffset-scale
    29  float IN              1  axis.b.jog-accel-fraction
    29  s32   IN              0  axis.b.jog-counts
    29  bit   IN          FALSE  axis.b.jog-enable
    29  float IN              0  axis.b.jog-scale
    29  bit   IN          FALSE  axis.b.jog-vel-mode
    29  bit   OUT         FALSE  axis.b.kb-jog-active
    29  float OUT             0  axis.b.pos-cmd
    29  float OUT             0  axis.b.teleop-pos-cmd
    29  bit   OUT         FALSE  axis.b.teleop-tp-enable
    29  float OUT             0  axis.b.teleop-vel-cmd
    29  float OUT             0  axis.b.teleop-vel-lim
    29  bit   OUT         FALSE  axis.b.wheel-jog-active
    29  float OUT             0  axis.c.eoffset
    29  bit   IN          FALSE  axis.c.eoffset-clear
    29  s32   IN              0  axis.c.eoffset-counts
    29  bit   IN          FALSE  axis.c.eoffset-enable
    29  float OUT             0  axis.c.eoffset-request
    29  float IN              0  axis.c.eoffset-scale
    29  float IN              1  axis.c.jog-accel-fraction
    29  s32   IN              0  axis.c.jog-counts
    29  bit   IN          FALSE  axis.c.jog-enable
    29  float IN              0  axis.c.jog-scale
    29  bit   IN          FALSE  axis.c.jog-vel-mode
    29  bit   OUT         FALSE  axis.c.kb-jog-active
    29  float OUT             0  axis.c.pos-cmd
    29  float OUT             0  axis.c.teleop-pos-cmd
    29  bit   OUT         FALSE  axis.c.teleop-tp-enable
    29  float OUT             0  axis.c.teleop-vel-cmd
    29  float OUT             0  axis.c.teleop-vel-lim
    29  bit   OUT         FALSE  axis.c.wheel-jog-active
    29  float OUT             0  axis.u.eoffset
    29  bit   IN          FALSE  axis.u.eoffset-clear
    29  s32   IN              0  axis.u.eoffset-counts
    29  bit   IN          FALSE  axis.u.eoffset-enable
    29  float OUT             0  axis.u.eoffset-request
    29  float IN              0  axis.u.eoffset-scale
    29  float IN              1  axis.u.jog-accel-fraction
    29  s32   IN              0  axis.u.jog-counts
    29  bit   IN          FALSE  axis.u.jog-enable
    29  float IN              0  axis.u.jog-scale
    29  bit   IN          FALSE  axis.u.jog-vel-mode
    29  bit   OUT         FALSE  axis.u.kb-jog-active
    29  float OUT             0  axis.u.pos-cmd
    29  float OUT             0  axis.u.teleop-pos-cmd
    29  bit   OUT         FALSE  axis.u.teleop-tp-enable
    29  float OUT             0  axis.u.teleop-vel-cmd
    29  float OUT             0  axis.u.teleop-vel-lim
    29  bit   OUT         FALSE  axis.u.wheel-jog-active
    29  float OUT             0  axis.v.eoffset
    29  bit   IN          FALSE  axis.v.eoffset-clear
    29  s32   IN              0  axis.v.eoffset-counts
    29  bit   IN          FALSE  axis.v.eoffset-enable
    29  float OUT             0  axis.v.eoffset-request
    29  float IN              0  axis.v.eoffset-scale
    29  float IN              1  axis.v.jog-accel-fraction
    29  s32   IN              0  axis.v.jog-counts
    29  bit   IN          FALSE  axis.v.jog-enable
    29  float IN              0  axis.v.jog-scale
    29  bit   IN          FALSE  axis.v.jog-vel-mode
    29  bit   OUT         FALSE  axis.v.kb-jog-active
    29  float OUT             0  axis.v.pos-cmd
    29  float OUT             0  axis.v.teleop-pos-cmd
    29  bit   OUT         FALSE  axis.v.teleop-tp-enable
    29  float OUT             0  axis.v.teleop-vel-cmd
    29  float OUT             0  axis.v.teleop-vel-lim
    29  bit   OUT         FALSE  axis.v.wheel-jog-active
    29  float OUT             0  axis.w.eoffset
    29  bit   IN          FALSE  axis.w.eoffset-clear
    29  s32   IN              0  axis.w.eoffset-counts
    29  bit   IN          FALSE  axis.w.eoffset-enable
    29  float OUT             0  axis.w.eoffset-request
    29  float IN              0  axis.w.eoffset-scale
    29  float IN              1  axis.w.jog-accel-fraction
    29  s32   IN              0  axis.w.jog-counts
    29  bit   IN          FALSE  axis.w.jog-enable
    29  float IN              0  axis.w.jog-scale
    29  bit   IN          FALSE  axis.w.jog-vel-mode
    29  bit   OUT         FALSE  axis.w.kb-jog-active
    29  float OUT             0  axis.w.pos-cmd
    29  float OUT             0  axis.w.teleop-pos-cmd
    29  bit   OUT         FALSE  axis.w.teleop-tp-enable
    29  float OUT             0  axis.w.teleop-vel-cmd
    29  float OUT             0  axis.w.teleop-vel-lim
    29  bit   OUT         FALSE  axis.w.wheel-jog-active
    29  float OUT             0  axis.x.eoffset
    29  bit   IN          FALSE  axis.x.eoffset-clear
    29  s32   IN              0  axis.x.eoffset-counts
    29  bit   IN          FALSE  axis.x.eoffset-enable
    29  float OUT             0  axis.x.eoffset-request
    29  float IN              0  axis.x.eoffset-scale
    29  float IN              1  axis.x.jog-accel-fraction
    29  s32   IN              0  axis.x.jog-counts
    29  bit   IN          FALSE  axis.x.jog-enable
    29  float IN              0  axis.x.jog-scale
    29  bit   IN          FALSE  axis.x.jog-vel-mode
    29  bit   OUT         FALSE  axis.x.kb-jog-active
    29  float OUT             0  axis.x.pos-cmd
    29  float OUT             0  axis.x.teleop-pos-cmd
    29  bit   OUT         FALSE  axis.x.teleop-tp-enable
    29  float OUT             0  axis.x.teleop-vel-cmd
    29  float OUT             0  axis.x.teleop-vel-lim
    29  bit   OUT         FALSE  axis.x.wheel-jog-active
    29  float OUT             0  axis.y.eoffset
    29  bit   IN          FALSE  axis.y.eoffset-clear
    29  s32   IN              0  axis.y.eoffset-counts
    29  bit   IN          FALSE  axis.y.eoffset-enable
    29  float OUT             0  axis.y.eoffset-request
    29  float IN              0  axis.y.eoffset-scale
    29  float IN              1  axis.y.jog-accel-fraction
    29  s32   IN              0  axis.y.jog-counts
    29  bit   IN          FALSE  axis.y.jog-enable
    29  float IN              0  axis.y.jog-scale
    29  bit   IN          FALSE  axis.y.jog-vel-mode
    29  bit   OUT         FALSE  axis.y.kb-jog-active
    29  float OUT             0  axis.y.pos-cmd
    29  float OUT             0  axis.y.teleop-pos-cmd
    29  bit   OUT         FALSE  axis.y.teleop-tp-enable
    29  float OUT             0  axis.y.teleop-vel-cmd
    29  float OUT             0  axis.y.teleop-vel-lim
    29  bit   OUT         FALSE  axis.y.wheel-jog-active
    29  float OUT             0  axis.z.eoffset
    29  bit   IN          FALSE  axis.z.eoffset-clear
    29  s32   IN              0  axis.z.eoffset-counts
    29  bit   IN          FALSE  axis.z.eoffset-enable
    29  float OUT             0  axis.z.eoffset-request
    29  float IN              0  axis.z.eoffset-scale
    29  float IN              1  axis.z.jog-accel-fraction
    29  s32   IN              0  axis.z.jog-counts
    29  bit   IN          FALSE  axis.z.jog-enable
    29  float IN              0  axis.z.jog-scale
    29  bit   IN          FALSE  axis.z.jog-vel-mode
    29  bit   OUT         FALSE  axis.z.kb-jog-active
    29  float OUT             0  axis.z.pos-cmd
    29  float OUT             0  axis.z.teleop-pos-cmd
    29  bit   OUT         FALSE  axis.z.teleop-tp-enable
    29  float OUT             0  axis.z.teleop-vel-cmd
    29  float OUT             0  axis.z.teleop-vel-lim
    29  bit   OUT         FALSE  axis.z.wheel-jog-active
    51  bit   OUT         FALSE  axisui.abort
    51  bit   OUT         FALSE  axisui.error
    51  bit   OUT         FALSE  axisui.jog.a
    51  bit   OUT         FALSE  axisui.jog.b
    51  bit   OUT         FALSE  axisui.jog.c
    51  float OUT             0  axisui.jog.increment
    51  bit   OUT         FALSE  axisui.jog.u
    51  bit   OUT         FALSE  axisui.jog.v
    51  bit   OUT         FALSE  axisui.jog.w
    51  bit   OUT         FALSE  axisui.jog.x
    51  bit   OUT         FALSE  axisui.jog.y
    51  bit   OUT         FALSE  axisui.jog.z
    51  bit   IN          FALSE  axisui.notifications-clear
    51  bit   IN          FALSE  axisui.notifications-clear-error
    51  bit   IN          FALSE  axisui.notifications-clear-info
    51  bit   IN          FALSE  axisui.resume-inhibit
    40  u32   OUT    0x00000004  cia402.0.controlword ==> x-controlword
    40  s32   IN              0  cia402.0.drv-actual-position <== x-drv-act-pos
    40  s32   IN              0  cia402.0.drv-actual-velocity
    40  bit   OUT         FALSE  cia402.0.drv-fault ==> x-amp-fault
    40  s32   OUT             0  cia402.0.drv-target-position ==> x-target-position
    40  s32   OUT             0  cia402.0.drv-target-velocity
    40  bit   IN          FALSE  cia402.0.enable <== x-enable
    40  bit   IN          FALSE  cia402.0.fault-reset
    40  bit   I/O         FALSE  cia402.0.home
    40  s32   OUT             0  cia402.0.opmode ==> x-opmode
    40  bit   OUT         FALSE  cia402.0.opmode-cyclic-position
    40  bit   OUT         FALSE  cia402.0.opmode-cyclic-velocity
    40  s32   IN              0  cia402.0.opmode-display
    40  bit   OUT         FALSE  cia402.0.opmode-homing
    40  bit   OUT          TRUE  cia402.0.opmode-no-mode
    40  float IN              0  cia402.0.pos-cmd <== x-pos-cmd
    40  float OUT             0  cia402.0.pos-fb ==> x-pos-fb
    40  s32   OUT            76  cia402.0.read-all.time
    40  bit   OUT         FALSE  cia402.0.stat-fault
    40  bit   OUT         FALSE  cia402.0.stat-homed
    40  bit   OUT         FALSE  cia402.0.stat-homing
    40  bit   OUT         FALSE  cia402.0.stat-op-enabled
    40  bit   OUT         FALSE  cia402.0.stat-quick-stop
    40  bit   OUT         FALSE  cia402.0.stat-remote
    40  bit   OUT         FALSE  cia402.0.stat-switched-on
    40  bit   OUT         FALSE  cia402.0.stat-switchon-disabled
    40  bit   OUT         FALSE  cia402.0.stat-switchon-ready
    40  bit   OUT         FALSE  cia402.0.stat-target-reached
    40  bit   OUT         FALSE  cia402.0.stat-voltage-enabled
    40  bit   OUT         FALSE  cia402.0.stat-warning
    40  u32   IN     0x00000000  cia402.0.statusword <== x-statusword
    40  float IN              0  cia402.0.velocity-cmd
    40  float OUT             0  cia402.0.velocity-fb
    40  s32   OUT           114  cia402.0.write-all.time
    10  bit   IN          FALSE  halui.abort
    10  float IN              0  halui.axis.a.analog
    10  float IN              0  halui.axis.a.increment
    10  bit   IN          FALSE  halui.axis.a.increment-minus
    10  bit   IN          FALSE  halui.axis.a.increment-plus
    10  bit   IN          FALSE  halui.axis.a.minus
    10  bit   IN          FALSE  halui.axis.a.plus
    10  bit   IN          FALSE  halui.axis.a.select
    10  float IN              0  halui.axis.b.analog
    10  float IN              0  halui.axis.b.increment
    10  bit   IN          FALSE  halui.axis.b.increment-minus
    10  bit   IN          FALSE  halui.axis.b.increment-plus
    10  bit   IN          FALSE  halui.axis.b.minus
    10  bit   IN          FALSE  halui.axis.b.plus
    10  bit   IN          FALSE  halui.axis.b.select
    10  float IN              0  halui.axis.c.analog
    10  float IN              0  halui.axis.c.increment
    10  bit   IN          FALSE  halui.axis.c.increment-minus
    10  bit   IN          FALSE  halui.axis.c.increment-plus
    10  bit   IN          FALSE  halui.axis.c.minus
    10  bit   IN          FALSE  halui.axis.c.plus
    10  bit   IN          FALSE  halui.axis.c.select
    10  float IN            0.2  halui.axis.jog-deadband
    10  float IN              0  halui.axis.jog-speed
    10  u32   OUT    0x00000000  halui.axis.selected
    10  float IN              0  halui.axis.selected.increment
    10  bit   IN          FALSE  halui.axis.selected.increment-minus
    10  bit   IN          FALSE  halui.axis.selected.increment-plus
    10  bit   IN          FALSE  halui.axis.selected.minus
    10  bit   IN          FALSE  halui.axis.selected.plus
    10  float IN              0  halui.axis.u.analog
    10  float IN              0  halui.axis.u.increment
    10  bit   IN          FALSE  halui.axis.u.increment-minus
    10  bit   IN          FALSE  halui.axis.u.increment-plus
    10  bit   IN          FALSE  halui.axis.u.minus
    10  bit   IN          FALSE  halui.axis.u.plus
    10  bit   IN          FALSE  halui.axis.u.select
    10  float IN              0  halui.axis.v.analog
    10  float IN              0  halui.axis.v.increment
    10  bit   IN          FALSE  halui.axis.v.increment-minus
    10  bit   IN          FALSE  halui.axis.v.increment-plus
    10  bit   IN          FALSE  halui.axis.v.minus
    10  bit   IN          FALSE  halui.axis.v.plus
    10  bit   IN          FALSE  halui.axis.v.select
    10  float IN              0  halui.axis.w.analog
    10  float IN              0  halui.axis.w.increment
    10  bit   IN          FALSE  halui.axis.w.increment-minus
    10  bit   IN          FALSE  halui.axis.w.increment-plus
    10  bit   IN          FALSE  halui.axis.w.minus
    10  bit   IN          FALSE  halui.axis.w.plus
    10  bit   IN          FALSE  halui.axis.w.select
    10  float IN              0  halui.axis.x.analog
    10  float IN              0  halui.axis.x.increment
    10  bit   IN          FALSE  halui.axis.x.increment-minus
    10  bit   IN          FALSE  halui.axis.x.increment-plus
    10  bit   OUT          TRUE  halui.axis.x.is-selected
    10  bit   IN          FALSE  halui.axis.x.minus
    10  bit   IN          FALSE  halui.axis.x.plus
    10  float OUT             0  halui.axis.x.pos-commanded
    10  float OUT             0  halui.axis.x.pos-feedback
    10  float OUT             7  halui.axis.x.pos-relative
    10  bit   IN          FALSE  halui.axis.x.select
    10  float IN              0  halui.axis.y.analog
    10  float IN              0  halui.axis.y.increment
    10  bit   IN          FALSE  halui.axis.y.increment-minus
    10  bit   IN          FALSE  halui.axis.y.increment-plus
    10  bit   IN          FALSE  halui.axis.y.minus
    10  bit   IN          FALSE  halui.axis.y.plus
    10  bit   IN          FALSE  halui.axis.y.select
    10  float IN              0  halui.axis.z.analog
    10  float IN              0  halui.axis.z.increment
    10  bit   IN          FALSE  halui.axis.z.increment-minus
    10  bit   IN          FALSE  halui.axis.z.increment-plus
    10  bit   IN          FALSE  halui.axis.z.minus
    10  bit   IN          FALSE  halui.axis.z.plus
    10  bit   IN          FALSE  halui.axis.z.select
    10  bit   IN          FALSE  halui.estop.activate
    10  bit   OUT         FALSE  halui.estop.is-activated
    10  bit   IN          FALSE  halui.estop.reset
    10  bit   IN           TRUE  halui.feed-override.count-enable
    10  s32   IN              0  halui.feed-override.counts
    10  bit   IN          FALSE  halui.feed-override.decrease
    10  bit   IN          FALSE  halui.feed-override.direct-value
    10  bit   IN          FALSE  halui.feed-override.increase
    10  bit   IN          FALSE  halui.feed-override.reset
    10  float IN            0.1  halui.feed-override.scale
    10  float OUT             1  halui.feed-override.value
    10  bit   OUT         FALSE  halui.flood.is-on
    10  bit   IN          FALSE  halui.flood.off
    10  bit   IN          FALSE  halui.flood.on
    10  bit   IN          FALSE  halui.home-all
    10  float IN              0  halui.joint.0.analog
    10  bit   OUT         FALSE  halui.joint.0.has-fault
    10  bit   IN          FALSE  halui.joint.0.home
    10  float IN              0  halui.joint.0.increment
    10  bit   IN          FALSE  halui.joint.0.increment-minus
    10  bit   IN          FALSE  halui.joint.0.increment-plus
    10  bit   OUT         FALSE  halui.joint.0.is-homed
    10  bit   OUT          TRUE  halui.joint.0.is-selected
    10  bit   IN          FALSE  halui.joint.0.minus
    10  bit   OUT         FALSE  halui.joint.0.on-hard-max-limit
    10  bit   OUT         FALSE  halui.joint.0.on-hard-min-limit
    10  bit   OUT         FALSE  halui.joint.0.on-soft-max-limit
    10  bit   OUT         FALSE  halui.joint.0.on-soft-min-limit
    10  bit   OUT         FALSE  halui.joint.0.override-limits
    10  bit   IN          FALSE  halui.joint.0.plus
    10  bit   IN          FALSE  halui.joint.0.select
    10  bit   IN          FALSE  halui.joint.0.unhome
    10  float IN            0.2  halui.joint.jog-deadband
    10  float IN              0  halui.joint.jog-speed
    10  u32   OUT    0x00000000  halui.joint.selected
    10  bit   OUT         FALSE  halui.joint.selected.has-fault
    10  bit   IN          FALSE  halui.joint.selected.home
    10  float IN              0  halui.joint.selected.increment
    10  bit   IN          FALSE  halui.joint.selected.increment-minus
    10  bit   IN          FALSE  halui.joint.selected.increment-plus
    10  bit   OUT         FALSE  halui.joint.selected.is-homed
    10  bit   IN          FALSE  halui.joint.selected.minus
    10  bit   OUT         FALSE  halui.joint.selected.on-hard-max-limit
    10  bit   OUT         FALSE  halui.joint.selected.on-hard-min-limit
    10  bit   OUT         FALSE  halui.joint.selected.on-soft-max-limit
    10  bit   OUT         FALSE  halui.joint.selected.on-soft-min-limit
    10  bit   OUT         FALSE  halui.joint.selected.override-limits
    10  bit   IN          FALSE  halui.joint.selected.plus
    10  bit   IN          FALSE  halui.joint.selected.unhome
    10  bit   OUT         FALSE  halui.lube.is-on
    10  bit   IN          FALSE  halui.lube.off
    10  bit   IN          FALSE  halui.lube.on
    10  bit   OUT         FALSE  halui.machine.is-on
    10  bit   IN          FALSE  halui.machine.off
    10  bit   IN          FALSE  halui.machine.on
    10  float OUT             1  halui.machine.units-per-mm
    10  bit   IN           TRUE  halui.max-velocity.count-enable
    10  s32   IN              0  halui.max-velocity.counts
    10  bit   IN          FALSE  halui.max-velocity.decrease
    10  bit   IN          FALSE  halui.max-velocity.direct-value
    10  bit   IN          FALSE  halui.max-velocity.increase
    10  float IN              0  halui.max-velocity.scale
    10  float OUT           100  halui.max-velocity.value
    10  bit   OUT         FALSE  halui.mist.is-on
    10  bit   IN          FALSE  halui.mist.off
    10  bit   IN          FALSE  halui.mist.on
    10  bit   IN          FALSE  halui.mode.auto
    10  bit   OUT         FALSE  halui.mode.is-auto
    10  bit   OUT          TRUE  halui.mode.is-joint
    10  bit   OUT          TRUE  halui.mode.is-manual
    10  bit   OUT         FALSE  halui.mode.is-mdi
    10  bit   OUT         FALSE  halui.mode.is-teleop
    10  bit   IN          FALSE  halui.mode.joint
    10  bit   IN          FALSE  halui.mode.manual
    10  bit   IN          FALSE  halui.mode.mdi
    10  bit   IN          FALSE  halui.mode.teleop
    10  bit   OUT          TRUE  halui.program.block-delete.is-on
    10  bit   IN          FALSE  halui.program.block-delete.off
    10  bit   IN          FALSE  halui.program.block-delete.on
    10  bit   OUT          TRUE  halui.program.is-idle
    10  bit   OUT         FALSE  halui.program.is-paused
    10  bit   OUT         FALSE  halui.program.is-running
    10  bit   OUT          TRUE  halui.program.optional-stop.is-on
    10  bit   IN          FALSE  halui.program.optional-stop.off
    10  bit   IN          FALSE  halui.program.optional-stop.on
    10  bit   IN          FALSE  halui.program.pause
    10  bit   IN          FALSE  halui.program.resume
    10  bit   IN          FALSE  halui.program.run
    10  bit   IN          FALSE  halui.program.step
    10  bit   IN          FALSE  halui.program.stop
    10  bit   IN           TRUE  halui.rapid-override.count-enable
    10  s32   IN              0  halui.rapid-override.counts
    10  bit   IN          FALSE  halui.rapid-override.decrease
    10  bit   IN          FALSE  halui.rapid-override.direct-value
    10  bit   IN          FALSE  halui.rapid-override.increase
    10  bit   IN          FALSE  halui.rapid-override.reset
    10  float IN            0.1  halui.rapid-override.scale
    10  float OUT             1  halui.rapid-override.value
    10  bit   OUT          TRUE  halui.spindle.0.brake-is-on
    10  bit   IN          FALSE  halui.spindle.0.brake-off
    10  bit   IN          FALSE  halui.spindle.0.brake-on
    10  bit   IN          FALSE  halui.spindle.0.decrease
    10  bit   IN          FALSE  halui.spindle.0.forward
    10  bit   IN          FALSE  halui.spindle.0.increase
    10  bit   OUT         FALSE  halui.spindle.0.is-on
    10  bit   IN           TRUE  halui.spindle.0.override.count-enable
    10  s32   IN              0  halui.spindle.0.override.counts
    10  bit   IN          FALSE  halui.spindle.0.override.decrease
    10  bit   IN          FALSE  halui.spindle.0.override.direct-value
    10  bit   IN          FALSE  halui.spindle.0.override.increase
    10  bit   IN          FALSE  halui.spindle.0.override.reset
    10  float IN            0.1  halui.spindle.0.override.scale
    10  float OUT             1  halui.spindle.0.override.value
    10  bit   IN          FALSE  halui.spindle.0.reverse
    10  bit   OUT         FALSE  halui.spindle.0.runs-backward
    10  bit   OUT         FALSE  halui.spindle.0.runs-forward
    10  bit   IN          FALSE  halui.spindle.0.start
    10  bit   IN          FALSE  halui.spindle.0.stop
    10  float OUT             0  halui.tool.diameter
    10  float OUT             0  halui.tool.length_offset.a
    10  float OUT             0  halui.tool.length_offset.b
    10  float OUT             0  halui.tool.length_offset.c
    10  float OUT             0  halui.tool.length_offset.u
    10  float OUT             0  halui.tool.length_offset.v
    10  float OUT             0  halui.tool.length_offset.w
    10  float OUT             0  halui.tool.length_offset.x
    10  float OUT             0  halui.tool.length_offset.y
    10  float OUT             0  halui.tool.length_offset.z
    10  u32   OUT    0x00000000  halui.tool.number
    49  float IN              0  ini.0.backlash
    49  float IN             50  ini.0.ferror
    49  float IN              0  ini.0.home
    49  float IN              0  ini.0.home_offset
    49  s32   IN              0  ini.0.home_sequence
    49  float IN            500  ini.0.max_acceleration
    49  float IN            500  ini.0.max_limit
    49  float IN             50  ini.0.max_velocity
    49  float IN              5  ini.0.min_ferror
    49  float IN              0  ini.0.min_limit
    49  float IN              0  ini.a.max_acceleration
    49  float IN              0  ini.a.max_limit
    49  float IN              0  ini.a.max_velocity
    49  float IN              0  ini.a.min_limit
    49  float IN              0  ini.b.max_acceleration
    49  float IN              0  ini.b.max_limit
    49  float IN              0  ini.b.max_velocity
    49  float IN              0  ini.b.min_limit
    49  float IN              0  ini.c.max_acceleration
    49  float IN              0  ini.c.max_limit
    49  float IN              0  ini.c.max_velocity
    49  float IN              0  ini.c.min_limit
    49  bit   IN           TRUE  ini.traj_arc_blend_enable
    49  bit   IN          FALSE  ini.traj_arc_blend_fallback_enable
    49  float IN              4  ini.traj_arc_blend_gap_cycles
    49  s32   IN             50  ini.traj_arc_blend_optimization_depth
    49  float IN            100  ini.traj_arc_blend_ramp_freq
    49  float IN            0.1  ini.traj_arc_blend_tangent_kink_ratio
    49  float IN          1e+99  ini.traj_default_acceleration
    49  float IN             50  ini.traj_default_velocity
    49  float IN          1e+99  ini.traj_max_acceleration
    49  float IN            100  ini.traj_max_velocity
    49  float IN              0  ini.u.max_acceleration
    49  float IN              0  ini.u.max_limit
    49  float IN              0  ini.u.max_velocity
    49  float IN              0  ini.u.min_limit
    49  float IN              0  ini.v.max_acceleration
    49  float IN              0  ini.v.max_limit
    49  float IN              0  ini.v.max_velocity
    49  float IN              0  ini.v.min_limit
    49  float IN              0  ini.w.max_acceleration
    49  float IN              0  ini.w.max_limit
    49  float IN              0  ini.w.max_velocity
    49  float IN              0  ini.w.min_limit
    49  float IN            500  ini.x.max_acceleration
    49  float IN            500  ini.x.max_limit
    49  float IN             50  ini.x.max_velocity
    49  float IN              0  ini.x.min_limit
    49  float IN              0  ini.y.max_acceleration
    49  float IN              0  ini.y.max_limit
    49  float IN              0  ini.y.max_velocity
    49  float IN              0  ini.y.min_limit
    49  float IN              0  ini.z.max_acceleration
    49  float IN              0  ini.z.max_limit
    49  float IN              0  ini.z.max_velocity
    49  float IN              0  ini.z.min_limit
     4  bit   OUT         FALSE  iocontrol.0.coolant-flood
     4  bit   OUT         FALSE  iocontrol.0.coolant-mist
     4  bit   OUT          TRUE  iocontrol.0.emc-abort
     4  bit   IN          FALSE  iocontrol.0.emc-abort-ack
     4  bit   IN           TRUE  iocontrol.0.emc-enable-in <== emc-enable
     4  s32   OUT             6  iocontrol.0.emc-reason
     4  bit   OUT         FALSE  iocontrol.0.lube
     4  bit   IN          FALSE  iocontrol.0.lube_level
     4  bit   OUT         FALSE  iocontrol.0.start-change
     4  bit   IN          FALSE  iocontrol.0.start-change-ack
     4  s32   OUT             4  iocontrol.0.state
     4  bit   OUT         FALSE  iocontrol.0.tool-change
     4  bit   IN          FALSE  iocontrol.0.tool-changed
     4  s32   OUT             0  iocontrol.0.tool-number
     4  s32   OUT             0  iocontrol.0.tool-prep-index
     4  s32   OUT             0  iocontrol.0.tool-prep-number
     4  s32   OUT             0  iocontrol.0.tool-prep-pocket
     4  bit   OUT         FALSE  iocontrol.0.tool-prepare
     4  bit   IN          FALSE  iocontrol.0.tool-prepared
     4  bit   IN          FALSE  iocontrol.0.toolchanger-clear-fault
     4  bit   IN          FALSE  iocontrol.0.toolchanger-fault
     4  bit   OUT         FALSE  iocontrol.0.toolchanger-fault-ack
     4  bit   OUT         FALSE  iocontrol.0.toolchanger-faulted
     4  s32   IN              0  iocontrol.0.toolchanger-reason
     4  bit   OUT         FALSE  iocontrol.0.user-enable-out
     4  bit   OUT         FALSE  iocontrol.0.user-request-enable
    29  float OUT             0  joint.0.acc-cmd
    29  bit   OUT          TRUE  joint.0.active
    29  bit   OUT         FALSE  joint.0.amp-enable-out ==> x-enable
    29  bit   IN          FALSE  joint.0.amp-fault-in <== x-amp-fault
    29  float OUT             0  joint.0.backlash-corr
    29  float OUT             0  joint.0.backlash-filt
    29  float OUT             0  joint.0.backlash-vel
    29  float OUT             0  joint.0.coarse-pos-cmd
    29  bit   OUT         FALSE  joint.0.error
    29  float OUT             0  joint.0.f-error
    29  float OUT             5  joint.0.f-error-lim
    29  bit   OUT         FALSE  joint.0.f-errored
    29  bit   OUT         FALSE  joint.0.faulted
    29  float OUT             0  joint.0.free-pos-cmd
    29  bit   OUT         FALSE  joint.0.free-tp-enable
    29  float OUT             0  joint.0.free-vel-lim
    29  s32   OUT             0  joint.0.home-state
    29  bit   IN          FALSE  joint.0.home-sw-in
    29  bit   OUT         FALSE  joint.0.homed
    29  bit   OUT         FALSE  joint.0.homing
    29  bit   OUT          TRUE  joint.0.in-position
    29  bit   I/O         FALSE  joint.0.index-enable
    29  float IN              1  joint.0.jog-accel-fraction
    29  s32   IN              0  joint.0.jog-counts
    29  bit   IN          FALSE  joint.0.jog-enable
    29  float IN              0  joint.0.jog-scale
    29  bit   IN          FALSE  joint.0.jog-vel-mode
    29  bit   OUT         FALSE  joint.0.kb-jog-active
    29  float OUT            -0  joint.0.motor-offset
    29  float OUT             0  joint.0.motor-pos-cmd ==> x-pos-cmd
    29  float IN              0  joint.0.motor-pos-fb <== x-pos-fb
    29  bit   OUT         FALSE  joint.0.neg-hard-limit
    29  bit   IN          FALSE  joint.0.neg-lim-sw-in
    29  float OUT             0  joint.0.pos-cmd
    29  float OUT             0  joint.0.pos-fb
    29  bit   OUT         FALSE  joint.0.pos-hard-limit
    29  bit   IN          FALSE  joint.0.pos-lim-sw-in
    29  float OUT             0  joint.0.vel-cmd
    29  bit   OUT         FALSE  joint.0.wheel-jog-active
    37  s32   OUT             0  lcec.0.0.actualposition ==> x-drv-act-pos
    37  s32   OUT             0  lcec.0.0.actualvelocity
    37  u32   IN     0x00000004  lcec.0.0.controlword <== x-controlword
    37  s32   IN              0  lcec.0.0.modesofoperation <== x-opmode
    37  s32   OUT             0  lcec.0.0.opmodedisplay
    37  bit   OUT         FALSE  lcec.0.0.slave-online
    37  bit   OUT         FALSE  lcec.0.0.slave-oper
    37  bit   OUT         FALSE  lcec.0.0.slave-state-init
    37  bit   OUT         FALSE  lcec.0.0.slave-state-op
    37  bit   OUT         FALSE  lcec.0.0.slave-state-preop
    37  bit   OUT         FALSE  lcec.0.0.slave-state-safeop
    37  u32   OUT    0x00000000  lcec.0.0.statusword ==> x-statusword
    37  s32   IN              0  lcec.0.0.targetposition <== x-target-position
    37  s32   IN              0  lcec.0.0.targetvelocity
    37  bit   OUT         FALSE  lcec.0.all-op
    37  bit   OUT          TRUE  lcec.0.link-up
    37  s32   OUT             0  lcec.0.pll-err
    37  s32   OUT             0  lcec.0.pll-out
    37  u32   OUT    0x00000000  lcec.0.pll-reset-count
    37  s32   OUT             0  lcec.0.read.time
    37  u32   OUT    0x00000002  lcec.0.slaves-responding
    37  bit   OUT         FALSE  lcec.0.state-init
    37  bit   OUT          TRUE  lcec.0.state-op
    37  bit   OUT          TRUE  lcec.0.state-preop
    37  bit   OUT         FALSE  lcec.0.state-safeop
    37  s32   OUT             0  lcec.0.write.time
    37  bit   OUT         FALSE  lcec.all-op
    34  u32   OUT    0x00000001  lcec.conf.master-count
    34  u32   OUT    0x00000001  lcec.conf.slave-count
    37  bit   OUT          TRUE  lcec.link-up
    37  s32   OUT         43168  lcec.read-all.time
    37  u32   OUT    0x00000002  lcec.slaves-responding
    37  bit   OUT         FALSE  lcec.state-init
    37  bit   OUT          TRUE  lcec.state-op
    37  bit   OUT          TRUE  lcec.state-preop
    37  bit   OUT         FALSE  lcec.state-safeop
    37  s32   OUT          9424  lcec.write-all.time
    29  s32   OUT            38  motion-command-handler.time
    29  s32   OUT          2014  motion-controller.time
    29  float IN              1  motion.adaptive-feed
    29  float IN              0  motion.analog-in-00
    29  float IN              0  motion.analog-in-01
    29  float IN              0  motion.analog-in-02
    29  float IN              0  motion.analog-in-03
    29  float OUT             0  motion.analog-out-00
    29  float OUT             0  motion.analog-out-01
    29  float OUT             0  motion.analog-out-02
    29  float OUT             0  motion.analog-out-03
    29  bit   OUT         FALSE  motion.coord-error
    29  bit   OUT         FALSE  motion.coord-mode
    29  float OUT             0  motion.current-vel
    29  bit   IN          FALSE  motion.digital-in-00
    29  bit   IN          FALSE  motion.digital-in-01
    29  bit   IN          FALSE  motion.digital-in-02
    29  bit   IN          FALSE  motion.digital-in-03
    29  bit   OUT         FALSE  motion.digital-out-00
    29  bit   OUT         FALSE  motion.digital-out-01
    29  bit   OUT         FALSE  motion.digital-out-02
    29  bit   OUT         FALSE  motion.digital-out-03
    29  float OUT             0  motion.distance-to-go
    29  bit   IN           TRUE  motion.enable
    29  bit   OUT         FALSE  motion.eoffset-active
    29  bit   OUT         FALSE  motion.eoffset-limited
    29  bit   IN          FALSE  motion.feed-hold
    29  float OUT             0  motion.feed-inches-per-minute
    29  float OUT             0  motion.feed-inches-per-second
    29  bit   IN          FALSE  motion.feed-inhibit
    29  float OUT             0  motion.feed-mm-per-minute
    29  float OUT             0  motion.feed-mm-per-second
    29  float OUT             0  motion.feed-upm
    29  bit   IN          FALSE  motion.homing-inhibit
    29  bit   OUT          TRUE  motion.in-position
    29  bit   OUT         FALSE  motion.is-all-homed
    29  bit   IN          FALSE  motion.jog-inhibit
    29  bit   OUT         FALSE  motion.jog-is-active
    29  bit   IN          FALSE  motion.jog-stop
    29  bit   IN          FALSE  motion.jog-stop-immediate
    29  bit   OUT         FALSE  motion.motion-enabled
    29  s32   OUT             0  motion.motion-type
    29  bit   OUT         FALSE  motion.on-soft-limit
    29  bit   IN          FALSE  motion.probe-input
    29  s32   OUT             0  motion.program-line
    29  float OUT             0  motion.requested-vel
    29  u32   OUT    0x0039E4E4  motion.servo.last-period
    29  bit   OUT         FALSE  motion.teleop-mode
    29  float OUT             0  motion.tooloffset.a
    29  float OUT             0  motion.tooloffset.b
    29  float OUT             0  motion.tooloffset.c
    29  float OUT             0  motion.tooloffset.u
    29  float OUT             0  motion.tooloffset.v
    29  float OUT             0  motion.tooloffset.w
    29  float OUT             0  motion.tooloffset.x
    29  float OUT             0  motion.tooloffset.y
    29  float OUT             0  motion.tooloffset.z
    29  bit   OUT         FALSE  motion.tp-reverse
    30  s32   OUT         55100  servo-thread.time
    29  bit   IN          FALSE  spindle.0.amp-fault-in
    29  bit   IN           TRUE  spindle.0.at-speed
    29  bit   OUT          TRUE  spindle.0.brake
    29  bit   OUT         FALSE  spindle.0.forward
    29  bit   I/O         FALSE  spindle.0.index-enable
    29  bit   IN          FALSE  spindle.0.inhibit
    29  bit   IN          FALSE  spindle.0.is-oriented
    29  bit   OUT         FALSE  spindle.0.locked
    29  bit   OUT         FALSE  spindle.0.on
    29  bit   OUT         FALSE  spindle.0.orient
    29  float OUT             0  spindle.0.orient-angle
    29  s32   IN              0  spindle.0.orient-fault
    29  s32   OUT             0  spindle.0.orient-mode
    29  bit   OUT         FALSE  spindle.0.reverse
    29  float IN              0  spindle.0.revs
    29  float OUT             0  spindle.0.speed-cmd-rps
    29  float IN              0  spindle.0.speed-in
    29  float OUT             0  spindle.0.speed-out
    29  float OUT             0  spindle.0.speed-out-abs
    29  float OUT             0  spindle.0.speed-out-rps
    29  float OUT             0  spindle.0.speed-out-rps-abs
[/code]
[/code]
[code]
[/code]
  • TAKUYA
  • TAKUYA
11 Jan 2026 17:10
Replied by TAKUYA on topic StepperOnline A6 Servo
Category: EtherCAT
Hi Andrax,
I am also currently in the middle of converting the previously working build to run with the absolute encoders so homing is only required once and I am somewhat experiencing the same issue as you. You said you fixed the sporadic jumps after homing by setting the homing_absolute_encoder parameter to 2 which i am trying out aswell. Sadly, the drive somehow doesnt start its usual homing scheme after the ER87 error (and the corresponding axis jump), it either doesnt do anything or its suuper slow. Did you also encounter this?
  • cnbbom
  • cnbbom
11 Jan 2026 17:04
Replied by cnbbom on topic New and Working RTAI debs for 2.9
Category: Installing LinuxCNC
Yes, it works now, thank you.
It's a shame I don't have another CPU at the moment to test with. I carefully checked that when configuring a machine in the Step Config Wizard
I can test the xyz axes correctly, the motors rotate, I have a latency of 25000 with YouTube and 9 glxgears. I'm hoping they find a solution. I'll leave a hard drive with 2.92 preempt rt while I do my tasks, but without giving up on having Debian 13, which I really liked.
  • DerKlotz
  • DerKlotz
11 Jan 2026 17:02
Replied by DerKlotz on topic SolidCAM Which Mill operation(Feature)
Category: CAD CAM
Maybe you are right. I try it at that forum.
  • bobwolf
  • bobwolf
11 Jan 2026 17:01
[WIP] IO_decoder: A modular High-Density USB I/O system (up to 128 pins)
Category: Show Your Stuff
Hi everyone,
I’d like to share a personal project I’ve been working on: io_decoder.
It’s a modular system designed to expand LinuxCNC I/O capabilities via a High-Speed USB connection.
Important Note on Use Case: This system is specifically designed for Operator Panels (HMI), pendants, and secondary controls. Since it communicates via USB, it is not intended for hard real-time machine functions (like step/dir motor control). It is the perfect companion for those who need a massive amount of I/O for buttons, switches, encoders, and potentiometers without using up expensive real-time FPGA pins.
How it differs from DIY serial solutions: Unlike standard serial-over-Arduino projects, io_decoder uses a dedicated HAL component optimized for lower latency and handles complex tasks (like keyboard mapping and encoder scaling) natively at the driver level, rather than requiring complex HAL logic.
Key Features:
Scalability: Modular design from 8 to 128 Digital I/O pins.
Smart Inputs: Built-in support for keyboard emulation (mapping pins directly to keysyms) and toggle functions.
Encoders & Analog: Supports up to 4 encoders and 3 ADC inputs for joysticks or feed-rate overrides.
Robustness: Integrated Hot-Plug management (auto-reconnect if the cable is unplugged).
Special Functions: Digital outputs with "blink" functionality and DAC outputs.
Project Status: This is a "labor of love" in active development. I have already produced and tested the first batch of PCBs. They are "first-run" prototypes with some "growing pains" (youthful mistakes!) that I’m currently fixing for the next hardware revision. The software side is stable and I'm already using it for my own setup.
Video Demo & Documentation: I've recorded a short video showing the current prototype in action: Video Link:
In the video you can see:
0:05 - Digital I/O (Buttons and LEDs) reactivity and HAL pin monitoring.
0:50 - Analog potentiometer (ADC) and Encoder tracking.
1:20 - Hot-Plug Test: Watch the driver automatically recover after disconnecting the USB cable!
Links: Official Project Page: bobwolfrst.github.io/io_decoder-linuxCNC/  GitHub Repository: github.com/bobwolfrst/io_decoder-linuxCNC
I’m looking forward to any feedback, technical advice, or questions from the community!
Best regards,
bobwolf
11 Jan 2026 16:24
Replied by tommylight on topic New and Working RTAI debs for 2.9
11 Jan 2026 16:19
Replied by tommylight on topic SolidCAM Which Mill operation(Feature)
Category: CAD CAM
I am sure there is another topic started by you with pretty much the same question, so what gives?
It might be much better/easier to ask such questions on the SolidCAM forums, not much users here using it.
  • PCW
  • PCW's Avatar
11 Jan 2026 16:02
First time with mesa - no ping but blinking user led on card
Category: Driver Boards
Real time issues are usually network latency related.
Can you run this command?
sudo chrt 99 ping -i .001 -c 60000 -q 10.10.10.10
and post the results here
Also have you run a latency test and done all the standard things to reduce host latency?
(All power management and CPU speed switching disabled, isolcpus set to last CPU etc etc)
Also what Ethernet hardware in on the host ? (Realtek hardware often needs it driver changed to the DKMS driver
and Intel hardware should have IRQ coalescing disabled)
  • DerKlotz
  • DerKlotz
11 Jan 2026 16:00
SolidCAM Which Mill operation(Feature) was created by DerKlotz
Category: CAD CAM
Hi,i just started with SolidCAM.I need to remove material from a part (attached file). I tried a Curve feature and selected the sketches, surfaces, and edges (attached file). The tool removes an area that I did not select (Attached file). Where did I go wrong?
  • amanker
  • amanker
11 Jan 2026 15:57
I tried cutting the spi cable short. Now it's just 7cm or smaller. Tried to lower spi frequency to 50000. But nothing helped.
  • PCW
  • PCW's Avatar
11 Jan 2026 15:36 - 11 Jan 2026 23:01
Error on 7i73 emc Counter after Update to 2.9.7
I can't duplicate this with 2.9.8 or master (2.10-pre1)
sounds more like a hardware issue of some kind.
 I guess a software issue is possible but this is the first time I have heard of this.
There were some sserial driver changes (bug fixes)  but nothing specifically
in the sserial encoder section, and there have been no encoder related
firmware changes to the 7I73.
You might check if the encoder still counts when both flat cables are disconnected from the 7I73
Do the other 7I73 MPG encoders have the same error?
  • Skoudfut
  • Skoudfut
11 Jan 2026 15:24
Hello Tommylight, thank for your time and help !
After a good night, the ping 10.10.10.10 finally works (idk why), i managed to setup the pncconf wizard and open linuxcnc, but still a connexion issue i guess because i get several warnings at startup :
"Unexpected realtime delay on task 0 with period 1000000."
hm2/hm2_7i96s.0: error finishing read! iter=1598"
Moreover, my homing switch does light up the mesa board and flicker when i use them, but they appear as fixed in Halshow (show on but no flickering). I suppose the connexion break at startup of linuxcnc ? I can't figure out why and it so frustrating !
  • cnbbom
  • cnbbom
11 Jan 2026 15:05
would that be it?1 drive.google.com/file/d/1BwlJet6ZcWpXvAUzD2YcM9vvnPTuclaX/view   2 drive.google.com/file/d/1xICFF-2mq_rz-vi.../view?usp=drive_link 3 drive.google.com/file/d/14Z10IOZI5bvgmf_.../view?usp=drive_link 4 drive.google.com/file/d/1fwGb5Qo9pw8lGLp.../view?usp=drive_link
Possibly, though I would need to apply for access as I can't currently view them.
Is this what you were looking for? Were you able to download it after I checked the Google sharing option?
  • endian
  • endian's Avatar
11 Jan 2026 14:14
Replied by endian on topic LinuxCNC S-Curve Accelerations
spiking is present maily during movement at same vector .. when vector of speed is different, spikes are gone
Displaying 7906 - 7920 out of 13507 results.
Time to create page: 0.394 seconds
