  • trackwhack
  • trackwhack
10 Sep 2026 11:54
Replied by trackwhack on topic Perpetual License CAM
Category: Show Your Stuff
Hi Juergen,
Thank you for your purchase and the kind word.
Step, STL and DXF work. DXF will be prompted for an extrusion thickness.
Hope you like the experience.
  • Plasmanfm
  • Plasmanfm
10 Sep 2026 10:47
Replied by Plasmanfm on topic Perpetual License CAM
I treated myself to these
Very easy installation super....
A basic question which drawing expot should I take from Freecad ???
King regarde
Juergen
  • grandixximo
  • grandixximo's Avatar
  • Todd Zuercher
  • Todd Zuercher's Avatar
10 Sep 2026 09:44
Replied by Todd Zuercher on topic Looking for consultant
I'm still here, but not quite as often as I used to be, I had to switch jobs and no longer have as much time at a computer and don't work with CNC routers daily any more. I can and will offer what advice I have for free here. So ask questions.
I live in NE Ohio. So unless you are local to me I will not be able to offer on site consulting/work. I simply do not have the free time between family and work commitments to do a lot of travel.
  • snowgoer540
  • snowgoer540's Avatar
10 Sep 2026 09:33 - 10 Sep 2026 09:34
Replied by snowgoer540 on topic Bug on new Install
Bug on new Install
Category: Plasmac
I apologize I didn’t get to this last evening, I’m off the next few days after today and I’ll have a gander.
What version did you roll back to?
I should have asked before, can you share your cut file as well?
  • Diegot
  • Diegot's Avatar
10 Sep 2026 08:06
Replied by Diegot on topic lcnc-suite — web UI for LinuxCNC
Category: Other User Interfaces
i just thought about this, a interface without the load of the display manager, searched i came to your project. I have a rpi4, a 7i90 and a 7i84, a 26pin conector and a sort 50pin cable. 7i90 flashed to spi. every thing to test it. i reply with my feedback, great project.
  • ruediger123
  • ruediger123
10 Sep 2026 07:38
Replied by ruediger123 on topic Ethercat random jitter fix
Category: EtherCAT
Hallo,
the linuxcnc-ethercat version is : linuxcnc-ethercat (1.42.2-1)
Gruß
Rüdiger
  • trackwhack
  • trackwhack
10 Sep 2026 04:05 - 10 Sep 2026 04:05
Depends how you define "basic". My paid-for Fusion costs me something like $400 a year and that includes indexed / wrapped 4th axis which allows me to do things like splines and gears. True simultaneous 4th axis requires the ruinously expensive manufacturing extension. That's always been a disappointment that rather limits the use of my 4th axis.
Exactly our point. For the same cost as a one year Fusion subscription of their basic CAD and CAM, you get Takshak for life which has an even larger rotary operations library than Fusion. If you buy it before 30th September, you get it at half that cost.
Anyone saying 200 USD is too expensive for that capability sounds rich enough to pay 1500 USD per year to Fusion and I have no beef with them.
  • trackwhack
  • trackwhack
10 Sep 2026 04:01 - 10 Sep 2026 04:09
No you got us wrong. The license has a launch offer of 199 USD. That offer is for 30 days from launch and ends on 30th September.
Post that the launch offer ceases and anyone buying from 1st October onwards pays 399 USD.
If you bought it before 30th September, its your forever at 199.
Irrespective of whether you bought it for 199 before the offer expires or 399 after it expires, you still get 30 days of usage to decide if you want to keep it. If you dont like it, you can ask for a refund.
  • Lcvette
  • Lcvette's Avatar
10 Sep 2026 03:08 - 10 Sep 2026 03:10
(Solved) Probe Basic - HAL pins not being created
Category: QtPyVCP
You can add multiple rules, use the right click rules dialog and add as you need, you can also add multiple channels to use in the expression. The expression can have multiple else continuation for each test to display.  There are examples in the ui, take a look at some of the labels and there rules.
  • spumco
  • spumco
10 Sep 2026 03:02
Category: QtPyVCP
Then you should not need any python code use just rules
This is what you meant when you mentioned the if/then/else rule statement earlier, right?  That gets me the three color states for the stopped/running/paused indicator.
To get the three text values, I'd need a second if/then/else rule for the widget... or the same status channel rule can do both appearance and text displayed?
  • FabLabRacing
  • FabLabRacing
10 Sep 2026 03:00 - 10 Sep 2026 12:50
FabScan - LinuxCNC Camera-Assisted Tracing / Scanning Project
Category: Plasma & Laser
A follow-up on **FabScan**, the LinuxCNC camera tracing/digitizing project I posted about earlier.
FabScan has now reached:
**v0.6.0-alpha.1**
Project:
github.com/FabLabRacing/FabScan
I am definitely not calling it finished, but I think it has crossed an important enough milestone to call it an alpha and, more importantly, to start asking the open-source community for help improving it.
## What Changed
The biggest change since my original post is the tracing architecture.
The earlier versions were basically:
detect local line
→ calculate correction
→ move
→ repeat
That worked surprisingly well on simple geometry, but corners eventually exposed the limits of that approach. I spent quite a while developing various versions of "Corner Assist", but eventually concluded that I was trying to solve an architectural problem with more special-case logic.
The current v0.6 approach is closer to:
Camera / perception
Persistent world-space path belief
Connected-path prediction / look-ahead
Planner
Controller / safety
LinuxCNC motion
The design principle that came out of that work is:
**Detectors observe. The model remembers. The planner decides. Motion executes.**
FabScan now tries to understand and follow the connected continuation of the profile rather than simply reacting to the latest local line fit.
## Record/Replay and Simulator
A fairly substantial development framework grew out of trying to debug the follower.
FabScan can now record complete physical tracing runs, including camera frames, calibration, planner state, motion, and diagnostics, then replay those runs deterministically.
Replay was extremely useful, but it has one unavoidable limitation: once a new planner chooses a different path than the old one, there are no recorded camera frames from that new location.
That led to an SVG ground-truth simulator using the exact A-G test geometry.
The simulator runs the real FabScan perception, estimator, and planner against a virtual camera that can move wherever the planner chooses. It also includes measured camera appearance, observation delay, and the actual configured motion limits from my LinuxCNC table.
That has become one of the most useful development tools in the project.
## Latest Real-Machine Result
The current hardest test geometry is shape **G**, which contains straight sections, tabs, a 45-degree corner, a radius, and several sharp direction changes.
The latest physical run completed:
**800 / 800 planner steps with no HOLD**
It stopped only because Count was set to 800, about **0.738" short of completing the loop**.
Some comparison numbers:
M5.6 simulator full path:    21.5182"
M6.2 physical implied path:  21.5091"
Physical RMS error vs SVG:   ~0.00446"
87.6% of path within:        0.005"
96.4% of path within:        0.010"
LinuxCNC itself followed the requested coordinated XY endpoints very closely, with an average endpoint miss of about **0.00045"**.
The remaining larger errors are concentrated around a few sharp vertices where the planner begins turning slightly early.
That is encouraging because the problem is becoming very specific rather than looking like general path instability.
## Where Help Would Be Useful
The biggest current planner question is how best to distinguish:
**continuous curvature / a radius**
**a true sharp connected-path vertex**
For a radius, normal look-ahead following should continue.
For a true corner, I think the planner needs to recognize it, commit to the actual vertex, finish the incoming leg, then latch onto the outgoing leg.
Other areas where ideas or contributions would be welcome include:
* state estimation / Kalman-style approaches
* connected-path association and branch scoring
* confidence models
* machine vision
* diagnostics
* eventual continuous/velocity-based following
* LinuxCNC integration
## HISTORY.md
I added a `HISTORY.md` file to the repository specifically for anyone interested in the development side of the project.
It is a bit longer than the normal documentation, but I think it is worthwhile reading before digging into the planner because it explains **why the current architecture exists**.
It covers:
* the original local follower
* the Corner Assist experiments and why that approach was abandoned
* the move to persistent path state
* why record/replay was added
* why replay eventually led to the simulator
* what the simulator is intended to prove
* what the first physical tests exposed
* the A-G test geometry
* simulation vs real-machine results
* the major open design questions
There is also a condensed decision tree showing how one development problem led to the next.
I am hoping that gives potential contributors enough context to avoid having to reverse-engineer months of experiments from the commit history.
## Alpha Status
The safety philosophy has not changed.
FabScan only commands controlled X/Y tracing motion. It does not control Z, the torch, spindle, THC, Cycle Start, or any cutting process.
The real-machine follower is still deliberately conservative and uses bounded coordinated moves with independent safety checks and HOLD behavior when it cannot identify a continuation it trusts.
I am calling this **alpha** because I think the basic architecture has now been validated well enough in simulation and on the real machine that outside review would be genuinely useful.
If anyone has experience with LinuxCNC, machine vision, robotics, controls, state estimation, path planning, OpenCV, or simply sees a better way to approach part of the problem, I would appreciate comments, criticism, testing, ideas, or pull requests.
The goal is still pretty simple:
**A practical open-source LinuxCNC camera tracing tool that can capture real shop-floor geometry and produce useful DXF without trying to become a CAD system or machine controller.**
It is not finished yet, but I think it is getting close enough to be interesting.
  • Lcvette
  • Lcvette's Avatar
10 Sep 2026 02:36
Category: QtPyVCP
  • spumco
  • spumco
10 Sep 2026 02:26
Category: QtPyVCP
there is no 3 states only on off because you only have on and off hal output and this can only use a single hal reader
That's a StatusLabel connected to the status channel, not a hal bit pin.  And the logic is in the user_button.py file.
just an fyi why are you destroying the format and look of the ui.. your better than that!
I thought I was keeping the look quite true to your original.  Same background colors, container shapes, borders, padding, etc for everything but the DRO.  I wanted a bigger display for the main DRO and had the real estate.  I even used the exact same halbar color scheme for the axis load indicators as you did on the spindle load bar.
As for format, I've mentioned a number of times (in other threads) I don't want/like any controls in the user interface that can cause physical machine movement.  If I could get rid of the cycle start/stop buttons, jog panel, go-to-home/zero buttons I would... but those are in the base probe_basic.ui files I cant touch without going way off the reservation.
I understand having on-screen control buttons for the ATC and probing - those are just too convenient and would take up a massive number of physical inputs to replicate.
My physical control panel has all the 'standard' controls I need for routine machine operations: start/stop/feed-hold, jog, FRO/SRO/JRO/RRO, spindle control, flood/mist/blast/wash, plus man/mdi/auto mode and a home-all button plus a few undesignated spares.  I like tactile controls and think touchscreens are dangerous... same opinion about modern cars, in fact.
So my compromise is to accept what's in the base ui, but change everything I can to indicators vs. buttons/controls. And get rid of the 'danger' buttons (DRO auto-zero HAD to go).  Your somewhat-recent modification to permit keyboard jog disable was a huge win in my book!
I just pushed the changes to qtpyvcp for the halbutton flash option property in qtdesigner
You rock.  I'll have a go at it tomorrow evening and report back.
  • Lcvette
  • Lcvette's Avatar
10 Sep 2026 02:03
Category: QtPyVCP
here is the flashing stylesheet code:
QPushButton {
    color: white;
    border-color: black;
    border-style: solid;
    border-radius: 5px;
    border-width: 1px;
    background: rgb(0, 255, 133);
    font-family: "Probe Basic Bebas Mono";
    font-size: 15pt;
QPushButton:checked[flashState="true"] {
    background: red;
    color: white;
QPushButton:checked[flashState="false"] {
    background: yellow;
    color: black;
QPushButton:disabled {
    color: white;
Displaying 871 - 885 out of 12224 results.
Time to create page: 0.281 seconds
