  • endian
  • endian's Avatar
25 Dec 2025 14:26
Following error due 2³¹ 2 147 483 648 jump to -2 147 483 648
Category: EtherCAT
take a look at default resolution SDO .. it has to be something like 20 or 16 ... it is user resolution per revolution ... maybe it has some weird setup from factory ... you have maybe swapped bytes or something or wrong data type ....
you dont share anything ... maybe share more details for focused reply
  • Hakan
  • Hakan
25 Dec 2025 13:21
Category: EtherCAT
Never seen a several km long axis so I am out of clues, sorry.
  • Hakan
  • Hakan
25 Dec 2025 13:19
Replied by Hakan on topic Ethercat random jitter fix
Category: EtherCAT
I can only take credit for rediscovering the PLL code and write some lines of documentation.
Sasha Ittner made the PLL code back in 2018 and it hasn't changed since then.
Will be interesting to see what you come up with.
  • Ahmed.emara
  • Ahmed.emara
25 Dec 2025 12:03
Replied by Ahmed.emara on topic leadshine R3EC
leadshine R3EC
Category: EtherCAT
My problem. Is in PDO mapping, i was able to configure how to switch the IO module to OP state by using sdoconfig in XML to set some SDO to be able to switch to OP state, now my problem is with PDO mapping section, the manual says PDO 6000 is for inputs and PDO 7000 for outputs, when i ran sudo ethercat -p 5 pdos, i couldn’t find these PDOS
  • Ahmed.emara
  • Ahmed.emara
25 Dec 2025 11:57
Hello, I would like to add an EtherCAT IO device. What should I do
Category: EtherCAT
Hello, i have R3EC leadshine io + DI + DO
Are you having same io system , if so could you please help me in writing the xml, i am stuck in the PDO mapping section
  • Sandro
  • Sandro
25 Dec 2025 10:28 - 25 Dec 2025 10:30
Replied by Sandro on topic Surfacemap Z compensation with Probe Basic
Category: QtPyVCP
Really nice work thank you.
I’ve modified the interface so that the scanned surface can be visualized with a button press. The next step is to make the probing settings persistent across LinuxCNC sessions. These settings are stored in the .var file, but I’m not sure how to load them at startup and update the Qt widgets accordingly.
  • ts
  • ts
25 Dec 2025 09:14 - 25 Dec 2025 09:14
Replied by ts on topic Ethercat Motion Problem
Category: EtherCAT
try changing the value in the .hal file
setp cia402.0.pos-scale 1000
[code]Hi. Pardon for offtop. Please could you try to explain what will do linunxCNC when you using this scale, and reach the calculating maximum of +2^31, and momentary jump to -2^31. On my case system stops and there an error of following..
[/code]
  • ts
  • ts
25 Dec 2025 08:48 - 25 Dec 2025 10:58
Category: EtherCAT
Hi
I doing retrofit on machine, used etheecat delta.
i used in hal file scale parameter pos-scale to adjust lenght of movenent
today i catch an error, when linuxcnc receive value during moving equals +2^31 and became -2^31, system catch that prevous value pos of axis calculated in mm was 380mm, and after count +2^31 overflow became -67mm. So there an error.
I have no ideas, and stucked) How to solve this trouble?
thanks in advance!
25 Dec 2025 07:05
Replied by tommylight on topic Hard stop homing
Hard stop homing
Most probably they will not work, inductive proximity sensors react to metal by inducing a magnetic field, but do give it a try, they might react, and might be polarity sensitive....
  • JT
  • JT's Avatar
25 Dec 2025 06:50 - 25 Dec 2025 06:55
Replied by JT on topic HAL ERROR
HAL ERROR
Category: HAL
gtk-builder-error-quark: gvcp-panel.ui:72:38 Invalid property: HAL_Table.n_rows (11)
Warning: Forward kinematics must handle duplicate coordinate letters:yy
Embeded tab command "halcmd loadusr -Wn gladevcp gladevcp -c gladevcp -H gvcp_call_list.hal -x 58720684 gvcp-panel.ui" exited with error: 1
Different OS?
JT
  • medicusdkfz
  • medicusdkfz's Avatar
25 Dec 2025 06:24
ethercat driver for EL2564 was created by medicusdkfz
Category: EtherCAT
Hello and Merry Christmas to you all,
I have written a ethercat driver for the EL2564 (led driver) - since there isnt't one yet - and tested it so far. Everything can be found in the attached ZIP archive. A video shows how it works
Have fun with it and enjoy tinkering in your workshop,
Pierre
File Name: EL2564_Dri...e.tar.gz
File Size:21 KB
  • Hakan
  • Hakan
25 Dec 2025 05:05
Ver 2.9.4 iso clean install Trouble when disabling EOE
Category: EtherCAT
So, there is a much bigger issue with lcec supporting LWR and Yaskawa drives requiring LRD/LRW.
I followed some of your links and while there is some success, there are also very pessimistic opinions
on rewriting of lcec_main. Maybe it is possible to take some of the success and shoehorn it into something?
  • automata
  • automata
25 Dec 2025 04:21
Category: EtherCAT
For Yaskawa Sigma7 the issue with lcec (linuxcnc-ethercat) software component is not only EOE being enabled in the drive.
It also has something to do with modes LRD/LWR and LRW. In the sigma7, the PDOs in the syncMasters are not read-write, i.e., LRW mode is not supported by sigma7. To work with sigma7, you need to enable 2 domains in the lcec program. I am not sure how to do that yet.
This issue is documented in these forum threads:
forum.linuxcnc.org/ethercat/50245-yasikawa-sigma7-lcec-driver
forum.linuxcnc.org/ethercat/48110-etherc...-responding?start=40
I have tried using this program from github.com/nylon7 and fdarling (on the yaskawa thread in the linuxcnc forum) and have seen some success in enabling the sigma7 motor and moving it and reading the absolute position register over ethercat.
github.com/nylon7/Igh-Ethercat-master/bl...ples/user/main_yas.c
For doing this, I am using the IGH Ethercat master 1.6-stable with EOE disabled as documented by Hakan.
I think we need to make some changes in lcec to enable the use of two domains.
-automata
  • grandixximo
  • grandixximo's Avatar
25 Dec 2025 03:46 - 25 Dec 2025 04:08
Replied by grandixximo on topic Ethercat random jitter fix
Category: EtherCAT
I have used your syncToRefClock "true" option, the random jitter issue persisted. The issue is not just sync, it is also phase, by simply drifting to match the DC epoch, you can get in phase. Only after the fix I am NOW finally able to create the jitter at WILL by setting a sync0shift of 10~30us this is expected, as preempt_rt has 20-60us jitter, if you move the sync0shift window in the jitter you should get jitter, this was not the case with just syncToRefClock "true" the servo was in sync, but the phasing was random. I will further test tomorrow, but this is something that has escaped the community for a while.
Sync is also important, but phasing was completely overlooked, I think the current code assumes phase alignment happens automatically, this might be because of ethercat's docs not explaining this well, or because of how linuxcnc is structured the servo thread is started completely separate from the lcec, the servo thread phasing has to be done manually to match DC epoch, even if DC epoch was written by lcec, the moment when servo-thread addf's lcec is practically random, the phasing will be random. Not sure if you understand, I am very deep into testing this for days now, and I can assure you, I have it fixed now, but it was not before.
  • Hakan
  • Hakan
25 Dec 2025 03:44
Category: EtherCAT
It can be that linuxcnc-ethercat disturbs the process. It must be removed too.
I think this way is the best after all. The other way with changing a bit in the eeprom is even more complicated with ned tools.
I went through the disabling of EoE on a development system I have. Here is the list of commands
sudo apt purge ethercat-master ethercat-dkms linuxcnc-ethercat
cd ~/src
cd ethercat/
make clean
./bootstrap
./configure --sysconfdir=/etc --disable-eoe
make all modules
sudo make modules_install install
ip a                                      # for mac address in next step
sudo vi /etc/ethercat.conf    # insert mac and "generic" driver
sudo systemctl start ethercat
ethercat slaves
sudo dmesg | tail -20
sudo apt install linuxcnc-uspace linuxcnc-uspace-dev     # probably already installed
cd ~/src
git clone https://github.com/linuxcnc-ethercat/linuxcnc-ethercat    # if it isn't installed already
cd linuxcnc-ethercat/
make
sudo make install
At this point you should be able to start linuxcnc.
Check syslog for EoE appearances.
Take it step by step.
Displaying 9781 - 9795 out of 11222 results.
Time to create page: 0.362 seconds
