Another plasma component...
- Thank you received: 4152
- Dee436
- Thank you received: 13
I already have a separate hal that was kindly put together for me by Islander John, so from that point of view an update does not bother my hal customisations as I would copy the updated plasmac.hal across with all the other files, and my custom.ini references both the plasmac hal and my custom one. In my question I was thinking mainly of my ini file as that is also a custom file.
For instance If an update changes something in the plasmac.ini, it is a manual process to integrate those changes to the custom ini file.
Not a major deal, I just wondered if I was missing something that would make life easier when updating.
Darren
Re your other problems. Sounds like something is going wrong in the compile process. Follow the instructions I wrote and let me know how you get on. But:
1. Are you using a PREMPT_RT Kernel like the Stretch ISO?
2. Are you using mesa hardware or a parallel port?
My instructions were based on Mesa cards with their THCAD for voltage sensing so a PREEMPT_RT kernel is a prerequisite.
- Dee436
I am also using all Mesa hardware including thcad
I wasn’t aware the Mesa cards required preempt_rt?
My system runs perfectly on 2.7 with RTAI, I just have no thc configured.
Getting the thc working was the reason for moving to plasmac.
- phillc54
- Thank you received: 2100
So, skip-ihs-type 1 should be skip IHS if within skip-ihs-distance of last successful probe location?From what I see when the plasmac.skip-ihs-type == 1 the skip distance is calculated from the start of the last cut. This way the origin for distance follows with each cut instead of being fixed at the last successful probe (the last place we know where the material surface is). Once you start this it is very possible to chain many small cuts for a long distance before probing again. It is very likely that you can be several cuts removed from the last probing location and still be within the IHS skip distance.
I am not quite sure what you mean here.Sorry if I wasn't clear about what is needed here. If the logic is inverted then THC-enable and IHS skip type == 1 can mean work with THC (from end of cut) and == 0 no THC, work from last probe. If the logic is inverted then I don't need two signals from Gcode to control it only the THC-enable from Gcode.
Cheers, Phill.
- phillc54
plasmac does run with RTAI, that is how I have been doing all my probe testing.Dee436 wrote:
1 I am using Debian wheezy with RTAI
If you are using Mesa hardware then you will need PREEMPT_RT
Cheers, Phill
Sorry, my mistake PREEMPT_RT is only required for ethernet Mesa cards like 7i76e
John,
Cheers, Phill.
Phill, there may be a logic error in your thinking. It should not be the start of the last cut, but it has to be at the point the surface is last probed as thats the last place height was established. That could be a couple of cuts earlier if its all close together.
- phillc54
This was what I originally wrote...
I only did 1 and 4.I was thinking of four types:
1. within distance of end of last cut AND THC enabled
2. within distance of end of last cut AND THC disabled
3. within distance of start of last cut AND THC enabled
4. within distance of start of last cut AND THC disabled or enabled
This fix is:
0 = within skip-ihs-distance of end of last cut AND THC enabled
1 = within skip-ihs-distance of last successfull probe
Cheers, Phill.
- phillc54
What is a typical LinuxCNC tool table for plasma?
Cheers, Phill.
