Another plasma component...
07 May 2019 04:58 #133022 by rodw
Thats actually a separate userspace module written in Python. You should be able to control it from sheetcam settings from your post processor.
See here: forum.linuxcnc.org/plasma-laser/33783-po...with-linuxcnc#106083
Neither, Phill, John or myself have a RS485 machine.
07 May 2019 04:59 #133023 by rodw
Actually, with Pedro's consent maybe it could be deployed with plasmac to master.
  • phillc54
  • phillc54's Avatar Topic Author
  • Platinum Member
  • Platinum Member
07 May 2019 05:28 - 07 May 2019 05:28 #133024 by phillc54
Well, tool handling is crap.
There is something that is causing the loaded tool to be one tool change ahead of what it should be. At this stage I have no clue as to what is causing this.
If you do not change a tool during cutting you will not notice this problem, it only becomes apparent when you change a tool during a job.
If you want to play it safe you can disabled it by commenting out the following line in the ini file.
#REMAP                   = T prolog=plasmac_tool_prolog ngc=plasmac_tool epilog=plasmac_tool_epilog
I bet Phill might like to finish his machine some day instead of chasing new features in Plasmac
John, you win that bet.
Cheers, Phill.
Last edit: 07 May 2019 05:28 by phillc54.
07 May 2019 05:43 #133026 by rodw
Phill, can you post the gcode you are using? Let somebody else check it out in case you got something wrong just to be safe.
  • phillc54
  • Platinum Member
  • Platinum Member
07 May 2019 06:31 #133029 by phillc54
Rod,
I am using metric_tool_change.ngc in the nc_files directory.
If definitely has problems, seems like something to do with remapping, I must be doing it wrong.
You can see when you press run that the second tool loads, it actually does load the first one but goes straight through and loads the second.
Cheers, Phill.
07 May 2019 09:37 #133041 by rodw
Rod,
Cheers, Phill.
Phill, I'm no expert on gcode but according to the docs
linuxcnc.org/docs/devel/html/gcode/other...html#sec:select-tool
M6 T4
Should be
T4 M6
It is valid to call tool prepare (T4) well before the tool is used to give the magazine time to get ready
I'm just looking on Git so have not tried this.
07 May 2019 21:26 #133098 by andypugh
Replied by andypugh on topic Another plasma component...
As you say this is not a milling machine, its a plasma machine.
Which is why I have been speculating on whether replacing "task" makes sense.
linuxcnc.org/docs/2.7/html/config/ini-config.html#_task_section
The code is here:
github.com/LinuxCNC/linuxcnc/tree/master/src/emc/task
I don't know how much is relevant, redundant or reusable.
I revisited your SQL wiki page recently to see if it could be incorporated into a plasma model and there was not one relevant data entity for plasma.
Well, one point of a database is that anyone can add their own dates items, and as long as the expected ones also exist, there is no problem. (whereas adding new items to the current tool table is a problem)
07 May 2019 21:58 #133101 by rodw
The code is here:
Andy, I could see how a plasma task would work so its food for thought and a pretty big Task to implement I think. But it would get access to start spindle to do all of the touch off stuff and total control over what the tool table looks like so its food for thought.
As far as changing the tool table fields, its more than that as the tables themselves are not applicable to plasma (eg totally wrong data entities)
Imagine if all the user had to do to implement a plasma machine was change one line in the ini file!
If I had more time at my disposal, I might even be tempted to try. How would the plasma task be incorporated into the build process?
07 May 2019 22:19 #133104 by andypugh
Milltask is created as a named binary by the submakefile:
github.com/LinuxCNC/linuxcnc/blob/0f91c5...emc/task/Submakefile
(I made up the phrase "named binary" as I am not particularly accomplished with build systems, all my LinuxCNC work has slotted into the existing build)
08 May 2019 01:08 #133105 by rodw
Well Andy this turned out far simpler than I imagined. It took all of 10 minutes.
1. Copied the src/emc/task folder to src/emc/plasma
2. Edited the submake file to compile plasmatask
3. Commented out these lines in the sub make file as I was getting a duplicate main() function between plasma and task
EMCSVRSRCS := \
	emc/task/emcsvr.cc
4. added the new /emc/plasma folder to the main Makefile in the /src folder
5. Compiled using make
6. changed my ini file to use plasmatask instead of milltask
And my machine ran as normal with the new task system!
How could we add new pins from here? It would be nice to alter the iocontrol module to provide plasma specific signals.Could we make a new module for plasma iocontrol in a similar way to what I've just done? (eg. ioplasma)
I might mention it would be really nice if the StateTags branch was merged to master as then we should be able to save the user commanded feedrate and do away with remapping totally!
So now, I think we could alter the whole tool handling system to suit plasma. I'm not sure Phil will be up to the challenge when he's staring at the finish line.
Time to create page: 4.309 seconds
