Material Settings Glitch
- snowgoer540
- Thank you received: 907
16 Feb 2020 21:52 #157522
by snowgoer540
Material Settings Glitch was created by snowgoer540
When I save the changes with regard to the THC in the materials area, it sometimes reverts them back to what I had changed them from before I had pressed "Save".
In the linked example, I unchecked "Use Auto Volts" and clicked "Save", which causes it to recheck "Use Auto Volts".
Save Issue
Any ideas?
Save Issue
Any ideas?
- phillc54
- Thank you received: 2100
16 Feb 2020 22:50 - 16 Feb 2020 23:05 #157526
by phillc54
Replied by phillc54 on topic Material Settings Glitch
I haven't been able to duplicate that behaviour.
Could you check in your ini file for [PLASMAC]LAST_UPGRADE and report the version.
Edit: A better version check is:
Buildbot Installation:
Run In Place Installation:
$ man plasmacRun In Place Installation:
$ source ~/linuxcnc-dev/scripts/rip-environment && man plasmac
Last edit: 16 Feb 2020 23:05 by phillc54.
- snowgoer540
16 Feb 2020 23:08 #157529
by snowgoer540
Replied by snowgoer540 on topic Material Settings Glitch
Phil,
LAST_UPGRADE = 0.090
I believe I ran it last before you pushed this latest update.
- phillc54
17 Feb 2020 00:34 #157532
by phillc54
It may be worthwhile doing an upgrade although I can't see any changes since 0.90 that would have any effect on your issue.
This is the grasping at straws answer I know, but...
- snowgoer540
17 Feb 2020 02:48 #157551
by snowgoer540
I'm willing to try anything, and I certainly appreciate the things to try. The weird thing is that I had this problem before, updated, it went away for a bit and now it's back. I've no idea where to look, code wise, to see if there's anything that might cause the unexpected behavior. When it comes to breaking software, somehow I'm your man lol.
Thanks again.
-Greg
Thanks again.
-Greg
- phillc54
17 Feb 2020 02:50 #157553
by phillc54
Cool, you can be the bug finder...When it comes to breaking software, somehow I'm your man lol.
- snowgoer540
17 Feb 2020 11:24 #157583
by snowgoer540
I'm game. Just ask the PathPilot guys, I annoy...err...contribute there regularly. Always happy to help how I can.
- snowgoer540
18 Feb 2020 17:00 #157731
by snowgoer540
So I updated to the latest last night, and I was able to better define/replicate the issue.
As it turns out, it doesn’t do it on the 00000 default material. But it does on any of the added materials. If I switch back to the default the problem goes away. See the YouTube link below.
I know enough coding to be dangerous... if you point me where to look I’m happy to try to look line by line in the code and see if anything jumps out at me.
-Greg
-Greg
- phillc54
18 Feb 2020 22:30 - 18 Feb 2020 22:41 #157772
by phillc54
Edit: Actually it is wrong for everything below THC disabled/Auto/Enabled
Thanks for that, it does do the same here. I will look into it.So I updated to the latest last night, and I was able to better define/replicate the issue.
Last edit: 18 Feb 2020 22:41 by phillc54.
- snowgoer540
18 Feb 2020 22:48 #157777
by snowgoer540
Ah that’s good to know. Glad to know I’m not going crazy!
If I can be of any help, please let me know.
Time to create page: 0.148 seconds
