Material Settings Glitch
- Thank you received: 4155
10 Jun 2020 16:15 #171001
Replied by rodw on topic Material Settings Glitch
AN explanation I wrote yesterday for somebody keen do add a Plasmac post processor to his software.
So the next problem is how does gcode tell plasmac to load a particular cutting chart entry? This code does that:
The custom M190 Pn tells plasmac to load cutting chart entry n from its GUI ( entry 12 in the example above).
But this loading is not instantaneous so when Plasmac has eventually retrieved the tool, it sets Digital Output number 3 true so M66 P3 L3 Q2 says wait for 2 seconds (Q2) for Digital input 3 (P3) go high (L3)
Then the gcode knows it can safely use the <_hal[plasmac.cut-feed-rate]> variable and all of the probe heights, pierce delays etc are set for the cut.
So you need to use the materiaverter to read your toolset and send it to PLasmac so the tools agree in the two systems
M190 P12
M66 P3 L3 Q2
F#<_hal[plasmac.cut-feed-rate]>The custom M190 Pn tells plasmac to load cutting chart entry n from its GUI ( entry 12 in the example above).
- snowgoer540
- Thank you received: 907
10 Jun 2020 17:59 #171003
by snowgoer540
Ok! I sort of figured that was what was going on nice to confirm. The problem is currently I only have 3 materials in plasmac, and it doesn’t seem to call material 2 if I use that for some reason. There’s definitely something going on here.
Replied by snowgoer540 on topic Material Settings Glitch
So the next problem is how does gcode tell plasmac to load a particular cutting chart entry? This code does that:M190 P12 M66 P3 L3 Q2 F#<_hal[plasmac.cut-feed-rate]>
- phillc54
- Thank you received: 2100
10 Jun 2020 18:15 - 10 Jun 2020 18:42 #171009
by phillc54
Replied by phillc54 on topic Material Settings Glitch
Can you post your material file then I can run that with your code.
EDIT: There is an issue with line numbers...
As a workaround can you change your PP so it doesn't print line numbers and hopefully that will work. In the meantime I will work on a solution.
Last edit: 10 Jun 2020 18:42 by phillc54.
10 Jun 2020 19:06 #171018
So what tools do you have in sheetcam? I think a lot of problems would be solved if you deleted your plasmac tool file and ran the materialverter so it agreed with sheetcam.
- snowgoer540
10 Jun 2020 19:46 #171028
by snowgoer540
Ah ok, sorry I broke it
Do you still need the materials file?
- snowgoer540
10 Jun 2020 19:47 #171029
by snowgoer540
To be candid, I didn’t know the materialverter was a thing. I’m open to suggestion for work flow for sure. Sheetcam is very new to me.
- phillc54
10 Jun 2020 19:51 #171031
by phillc54
Lets just say that you are more efficient at bug finding than most folk.Ah ok, sorry I broke it
May as well, you never know...Do you still need the materials file?
- snowgoer540
10 Jun 2020 19:53 - 10 Jun 2020 19:55 #171032
by snowgoer540
Haha, I actually consider that a compliment! If it's any consolation, sometimes I think I annoy the Tormach guys finding bugs with PathPilot,.. I truly wish I understood how to fix them, then at least I could propose solutions as well.
Attached!
Thanks Phill, as always!
Attached!
Last edit: 10 Jun 2020 19:55 by snowgoer540. Reason: 1too many pesky quotes, 2attaching for real this time
- phillc54
10 Jun 2020 20:03 #171034
by phillc54
Actually I find it difficult to find bugs, when I change something then I think I have tested every angle but there is always something I didn't try. It takes a LOT longer to test changes than it does to make them so having bug finders is handy...
- snowgoer540
10 Jun 2020 20:10 #171036
by snowgoer540
Well then I’m happy to do my part to help improve everyone’s user experience, it’s the least I can do. While I was running the job I had over the weekend I was thinking how insanely lucky we all are to have the Plasmac interface, and I was thinking about how incredibly good not only the software is, but also the group of people who support it. So thanks again to all involved. I feel that doesn’t get said enough.
The following user(s) said Thank You: phillc54, tommylight, Clive S
Time to create page: 0.562 seconds
