Material Settings Glitch
- phillc54
- Thank you received: 2100
- snowgoer540
- Thank you received: 907
I have pushed a fix for this issue
forum.linuxcnc.org/plasmac/37233-plasmac-updates#157794
You're awesome! Thank you so much.
- snowgoer540
So, I looked at the things you changed on github to try to understand what the issue was. There's no shame in admitting that I couldnt follow. My question is, how did you all learn Python? Is there anything you recommend to push me further quicker than trying to read line by line and understand what is what?
- phillc54
All self taught, a LOT of googling.
A reasonable starting point developers.google.com/edu/python
- Thank you received: 4154
This is more than reasonable, the lectures are the best I think! If you force yourself to do all the lessons you will be off to a great start but it does assume you know another programming language before you start. That way you will know all about programming constructs and variables.
My trouble is I don't use Python enough so I forget it all before I use it again
- phillc54
I am like that with C. I really struggle when I have to do something with it.My trouble is I don't use Python enough so I forget it all before I use it again
I've used C since the DOS days. As a result I'm not very good with classes but everything else is good. To use C you need to learn how to use pointers (and structures). A lot of people avoid this but when you master them they are so powerful. But what blows me away is that what would take 1000 lines in C can be done in Python in 100!
A lot of the python stuff I've done has been using web based API's retrieving data from cloud based systems and its amazing at that. I have a project I'm interested in that will use Python, Raspberry PI's and AWS if you are up for a Python challenge! You can be my chief programmer and we'll share the millions!
- phillc54
You know me well...I've used C since the DOS days. As a result I'm not very good with classes but everything else is good. To use C you need to learn how to use pointers (and structures). A lot of people avoid this
Haha, I love $ almost as much as my MacsA lot of the python stuff I've done has been using web based API's retrieving data from cloud based systems and its amazing at that. I have a project I'm interested in that will use Python, Raspberry PI's and AWS if you are up for a Python challenge! You can be my chief programmer and we'll share the millions!
- Thank you received: 7501
I am getting worried ....Haha, I love $ almost as much as my Macs
- snowgoer540
Basically it was only saving stuff below the Cut Parameters if the Default Material was selected, that was the moving of the "if material" line. Plus THC auto/on/off was saving.
Thank you guys for the direction! I do have previous coding experience, and I'm usually pretty good at walking through the code and figuring out what's wrong. As far as writing code, I can plagiarize (aka take something someone else did that is close to what I want and then modify it to meet my needs via googling, etc) like a champ. I would struggle to write from scratch these days.
But python might as well be moon man language. Maybe it's a mental block.
Thanks again!
