- Thank you received: 486
Sorry I need some more guidance as my head is blowing up :laugh:phillc54 wrote: Yes, that is the correct file.
It wouldn't be in your original file because you had mode 0. You can just add the line in and put in your 7i96 pin that you connect the signal to.
You would need to change PlasmaC to mode 1 in the in file and you would need to enable the following in your connections.hal file.
#net plasmac:arc-ok-in ***YOUR_PLASMA_ARC_OK*** => plasmac.arc-ok-in
tommylight wrote: Waiting patiently.......
