- Thank you received: 486
Yes and I think it is okphillc54 wrote:
Yes, I believe this is correct. PlasmaC will only continue if both are true even though Arc OK is capable of being displayed without a Torch On signal.islander261 wrote: I may be missing something here. It seems to me that the PlasmaC generated Ark Ok signal should only be true when the plasmac torch on signal is true
@Clive.
Did you try a probe test?
I think you have your Pierce and Cut Heights reversed.
It may be worthwhile checking you gas pressure and setting it toward the lower end of the recommended setting.
.rodw wrote:
Clive S wrote: I have noticed that when the button is pressed it stops the air purge briefly
I'm not sure that firing a torch in the air without cutting something proves anything. Its the arc transfer is the issue.
Does this interruption of the air flow happen when the CNC triggers it with a relay? If not, what is different about your switch and the relay?
.Sounds like the air is halted to allow the pilot arc to fire when you press the button.
tommylight wrote: Did you try to do several consecutive short cuts by hand, see if it miss fires.
tommylight wrote: Actual cuts, the pilot is working, but to know if the transfer is working, actual cuts have to be made.
