- Thank you received: 486
phillc54 wrote: @Clive
As a test could you unlink plasmac.arc-ok-high and setp it to some ridiculously high value.
Edit: you could do that in Hal Show with "unlinkp plasmac.arc-ok-high" then "setp plasmac.arc-ok-high 10000"
Hopefully it will get you cutting so we can see some more halscopes.
Could you also include the pin plasmac.state-out.
Proma has only min voltage for arcok, if i remember correctly.
.Clive S wrote: First I must thank you all for helping to debug this.
..phillc54 wrote: @Clive
I will try this and report back: I actually already tried to increase the max volts to 900 but the software only defaults back to 300
Also re this:
rodw wrote:
Thats not 100 ms! Its one second.
The division is the minor tick. 10 minor ticks per vertical line.
That doesn't make sense to me, so in the first of Clive's Halscopes the sawtooth is 5Hz and the arc voltage is around 1400V or am I missing something?
I have always thought the full length line was the division and the minor ticks were a subdivision.
I would think that the arc voltage in the following scopes 100/div would = to about 210V ie ( two and a bit divisions high).
