- Thank you received: 486
phillc54 wrote: Wow, that is a mean spike you get 100mS after torch on for the second cut.
So there a maybe a few different ways around this.
- install a current sensor in the torch lead and use that for an Arc OK signal
- I could add a Arc OK on delay so the arc voltage needs to be within limits for nnn amount of time before Arc OK is true
- I could add a Arc OK off delay so the arc voltage needs to be outside limits for nnn amount of time before Arc OK is false
- I could add a Arc OK High inhibit so Arc OK won't go false if the arc voltage is too high
PCW wrote: Sounds like if it not already done, simply masking the high voltage test for
a settable period of time after the torch on command would fix the issue.
Also just setting the high threshold to a bit under the open circuit voltage
when waiting for arc OK seems like it would also fix the issue
