PlasmaC torch starting problem (Solved with help from the famous three)
6 years 7 months ago #160529 by rodw
Replied by rodw on topic PlasmaC torch starting problem
Why don't you try a timedelay of say 0.2 to 0.5 seconds after torch on and use that as a ArcOK? Leave it on until the cut is finished.
It seems like your machine is not a candidate for synthesised ArcOK.
6 years 7 months ago - 6 years 7 months ago #160532 by Clive S
rodw wrote: Why don't you try a timedelay of say 0.2 to 0.5 seconds after torch on and use that as a ArcOK? Leave it on until the cut is finished.
Would you mind expanding how to achieve that, ie where would the time delay be put and how do I change it as ArkOK.
Before your post . I have been testing again and notice that the ArkOK stops on until the volts drop to zero which take a few seconds to do that. I can fire the torch using a push button across the relay contacts when the air is still purging
Edit: Is there anyway I could trick the THC into zero volts at the start. ?
Last edit: 6 years 7 months ago by Clive S.
6 years 7 months ago #160534 by phillc54
You would need to have Arc OK Low set to higher than this stray voltage you have.
If a pushbutton can fire the torch then the torch on signal also should.
6 years 7 months ago #160536 by phillc54
It would probably be worthwhile running Halscope on these pins plasmac:torch-on plasmac:arc-ok-out plasmac:arc-voltage-out
On another tack it may be worth trying the lowpass filter as explained here:
linuxcnc.org/docs/devel/html/plasma/plas...r-guide.html#lowpass
Again you would need to have Arc OK Low higher than the stray voltage.
6 years 7 months ago #160540 by Clive S
phillc54 wrote: It would probably be worthwhile running Halscope on these pins plasmac:torch-on plasmac:arc-ok-out plasmac:arc-voltage-out
Thanks for your time Phil. I am sorry to be a pain.
I have tried ArkOK at various volts up to 100.
The relay that fires the torch just briefly triggers but does not hold on.
I have tried the lowpass filter was at zero have tried 50,100,200 and with ArcOK_Low at 100.
it doe not change the hovering volts 0-20 after the cut
6 years 7 months ago #160541 by phillc54
What is your Arc OK High set at?
Time to create page: 0.105 seconds
