- Thank you received: 486
That is to low, i have it set to 80V min and 150V max, wired to an ISKRA plasma source, i was pleasently surprised that it never failed to detect a valid arcok. The cut voltage is 125 to 135 depending on speed and thicknes.Clive S wrote: I have tried altering the OK Low Volts between 5-30 . I notice that after a cut the Ark Volts hover around 2-20v but when the air purge stops is then goes to zero
phillc54 wrote: I think bbsr_5a is correct, try increasing the Arc Retry Delay, maybe Arc Fail Timeout needs increasing as well.
