PlasmaC torch starting problem (Solved with help from the famous three)
6 years 7 months ago #160890 by tommylight
Clive S wrote:
tommylight wrote: Actual cuts, the pilot is working, but to know if the transfer is working, actual cuts have to be made.
Do you mean jog the z down to height then press the button and keep it down then jog to do a cut say about 50mm
Yes, at least 2 or 3 consecutive cuts of 10 to 20mm, or 50mm.
6 years 7 months ago #160892 by Clive S
Yes. Just tested. I can jog the Z down to cut height press the button (and keep it pressed) it will pierce and then I jogged for 150mm several times.
It will even pierce from 4mm above the 3mm steel and cut
6 years 7 months ago #160898 by tommylight
6 years 7 months ago #160899 by Clive S
tommylight wrote: Were those cuts or just pierces ?
Yes as I said above 150mm cuts
6 years 7 months ago #160900 by tommylight
Thank you.
Did you also fix the pierce and cut height, as Phill noted they were reversed.
Pierce height 2 to 3mm, cut height 1 to 1.5mm.
6 years 7 months ago - 6 years 7 months ago #160904 by Clive S
tommylight wrote: Thank you.
No. but I will cut height is 1.12mm for 3mm steel that give me a good cut with very little dross and a sq. edge.
I will make the pierce height 2.5mm.
Do you think that could make a difference.
Last edit: 6 years 7 months ago by Clive S.
Time to create page: 0.075 seconds
