PlasmaC torch starting problem (Solved with help from the famous three)
  • Moderator
  • Moderator
21 Mar 2020 17:19 #161001 by tommylight
Replied by tommylight on topic PlasmaC torch starting problem
Re kerf, i never use it so i am not the best info source for that.
On 99.999999999% of what i deal with is cutting 3mm thick plates with decor, so a mm here or there is not important, and the only correction i do is add 3mm to outside dimensions to compensate the cut. That usually lands in the 0.2 to 0.4mm tolerance, as the kerf width depends heavily on the speed and current and thickness and humidity and ......
21 Mar 2020 21:26 - 22 Mar 2020 00:53 #161029 by phillc54
Replied by phillc54 on topic PlasmaC torch starting problem
Edit: Phil will using this method effect the THC ?
It has no effect on THS (EDIT: or THC for that matter), it is just a different method to get the Arc OK signal.
Re the over size and under size is that a kerf param?. to change. the gantry travels the correct distance over 1200mm
It would only be kerf if you used G41.1 or G42.1 in the GCode. When you drew the part did you have the torch on the right side of the cut.
@Tom. That reed switch is a great idea Tom. I think it might be worth adding to the appendix of the PlasmaC doc.
Last edit: 22 Mar 2020 00:53 by phillc54. Reason: oopsy
21 Mar 2020 22:20 - 21 Mar 2020 22:22 #161032 by Clive S
That part was drawn as a DXF and passed to sheetcam outside cut clockwise inside cut anti clockwise. First time using sheetcam
using the PP from Rod I think.
So I will check the code in the morning.
Phil I would like to thank you for the tremendous help you have given me throughout this trauma.
The magnificent 3 has got me through this.
Now to try and sort out the following errors :) that I keep getting.. New post
Last edit: 21 Mar 2020 22:22 by Clive S.
21 Mar 2020 22:22 #161033 by phillc54
Glad you are up and running Clive. Now for the fine tuning...
  • Moderator
  • Moderator
21 Mar 2020 23:09 #161035 by tommylight
Yup, i do agree, but please rip off the pictures from Clive as i am all out of working plasma sources for now, it looks like those 15 or more APC UPS's will come in handy these days, they do have some hefty transformers in them, will do just fine for testing but not for prolonged use, and i think i have some 3 phase 50A rectifiers and some 160A SCR's in the shop......hmm.... current controlled by Linuxcnc...... :) . TIMEEEEE, i need time, or 4 more copies of myself ! :)
Wait, did i say the rip of part out loud ? Oh cr..... :)
22 Mar 2020 00:47 - 22 Mar 2020 00:48 #161041 by phillc54
@Tom, does this look ok to you?
Last edit: 22 Mar 2020 00:48 by phillc54.
  • Moderator
  • Moderator
22 Mar 2020 02:12 #161051 by tommylight
Nice.
Thank you.
You could add at the very beginning that it is effective and very reliable, this never fails.
22 Mar 2020 02:24 #161054 by phillc54
No worries Tom, will do.
22 Mar 2020 03:37 #161061 by rodw
Replied by rodw on topic PlasmaC torch starting problem
I personally don't think build hints should go in the software manual. They belong in the Plasma primer which deals with hardware.
And its included in the latest update that as you know is coming soon! Pending the publisher now!
  • Moderator
  • Moderator
22 Mar 2020 12:52 #161093 by tommylight
Agreed. Just pointing it there should do.
Time to create page: 0.180 seconds
