PlasmaC torch starting problem (Solved with help from the famous three)
- Thank you received: 7468
14 Mar 2020 23:09 #160231
Sorry, i am a bit behind on.......everything.
Oh BTW, my dog died a few days ago.
Regards,
Replied by tommylight on topic PlasmaC torch starting problem
Yup, that should be it.Thanks for the feedback Tom. I have already tried setting the "OK low volts" to 90v I take it that OK low volt IS the same as min arcok
Regards,
- Clive S
- Thank you received: 486
14 Mar 2020 23:22 #160234
by Clive S
Replied by Clive S on topic PlasmaC torch starting problem
Very sorry to hear that Tom as I know you was very fond of it .
- phillc54
- Thank you received: 2100
14 Mar 2020 23:39 #160236
by phillc54
I "think" this is a workflow thing.
When you save an array it creates a new file with the name you gave it. It keeps the original array which is a temporary file loaded in LinuxCNC so if you go Reload it will only reload the temporary file. If you want to use the file you created you will have to Open that file.
Replied by phillc54 on topic PlasmaC torch starting problem
I made 3 small circles with shapes and array I saved the gcode to the standard folder and then edited it with G4 P15 after the first cut to see if the 15 sec delay (ie long enough for the air to stop and volts get to zero) but when this was reloaded it purged the g4p15 out of the code. So how can I get a pause in the code between the cuts to test ?
- phillc54
14 Mar 2020 23:40 #160237
by phillc54
Sorry to hear that Tom.
15 Mar 2020 01:23 #160242
Thank you guys.
15 Mar 2020 01:33 #160243
It just did not get better, despite many visits to the Vet, it had lost weight by the time you visited, by the end it was pitiful to look at.
I never had to worry about leaving the house or the workshop alone, just the sight of a 100 pound Rottweiler is enough to make most humans have bad dreams, for a long time!Very sorry to hear that Tom as I know you was very fond of it .
- Clive S
15 Mar 2020 08:23 #160265
by Clive S
If I understand correctly the array is saved to a different folder than the standard NGC one. I saved the file under a different name to the desktop and edited that, I then shut the PC down and restarted and checked that the G4P15 was in the file on the desktop and opened that file.
Does the PlasmaC purge the G4P15 from the code?
- phillc54
15 Mar 2020 08:46 #160266
by phillc54
I didn't think it did and I have just tested it here and it works OK.If I understand correctly the array is saved to a different folder than the standard NGC one. I saved the file under a different name to the desktop and edited that, I then shut the PC down and restarted and checked that the G4P15 was in the file on the desktop and opened that file.
- Clive S
15 Mar 2020 08:53 #160267
by Clive S
Thanks for the feedback. I will go out and test again.
- Clive S
15 Mar 2020 11:16 #160281
by Clive S
Yes of course you are correct
But I was using pierce only and it was that, that was getting rid of the G4
I have now confirmed that putting a delay of 15 secs in the gcode between the cuts works fine. So the problems is with the plasma cutter.
Time to create page: 0.144 seconds
