PlasmaC torch starting problem (Solved with help from the famous three)
6 years 7 months ago #160267 by Clive S
phillc54 wrote:
Clive S wrote: If I understand correctly the array is saved to a different folder than the standard NGC one. I saved the file under a different name to the desktop and edited that, I then shut the PC down and restarted and checked that the G4P15 was in the file on the desktop and opened that file.
Does the PlasmaC purge the G4P15 from the code?
I didn't think it did and I have just tested it here and it works OK.
Thanks for the feedback. I will go out and test again.
6 years 7 months ago #160281 by Clive S
Yes of course you are correct :) But I was using pierce only and it was that, that was getting rid of the G4
I have now confirmed that putting a delay of 15 secs in the gcode between the cuts works fine. So the problems is with the plasma cutter.
6 years 7 months ago #160358 by phillc54
Clive S wrote: But I was using pierce only and it was that, that was getting rid of the G4
Yes, it only looks for spindle on signals and does it own thing.
That also explains the G1 X 0.000001 you referred to before, LinuxCNC needs to have some motion otherwise it won't turn the torch on.
If you had saved the Pierce Only file then added the G4 codes in then loaded it and run it in Pierce and Cut mode it should work.
6 years 7 months ago #160367 by Clive S
Yes I now understand what was happening. What this has now shown me is that the G4P15 after the first cut works but it is not good with a 15 sec delay before each cut . This looks like a problem with the cutter not fire-ing until the air stops.
I have tried it with THC off to no avail. So my next move is to have a temporary button to see if the torch will fire manually as the air is still purging (when it is purging the volts are hovering around 0-18 then when the air stops it is rock steady on zero)
6 years 7 months ago #160369 by phillc54
Have you tried a long Arc Fail timeout?
6 years 7 months ago #160370 by Clive S
phillc54 wrote: Have you tried a long Arc Fail timeout?
What would you call long , 15 secs ?
Time to create page: 0.482 seconds
